Question about HP Compaq Presario V2000 Notebook
DVD/CD-ROM DRIVE DOES NOT SHOW
MY DVD/CD-ROM DRIVE DOESNT SHOW. ON THE DEVICE MANAGER IT SAYS THAT THE WINDOWS SUCCESSFULLY LOADED THE DEVICE DRIVER BUT CANNOT FIND THE HARDWARE DEVICE. IS THERE SOMETHING WRONG WITH MY DEVICE? HOW CAN I TEST THE DEVICE IF IT IS STILL WORKING OR NOT? THANK YOU VERY MUCH.
  • 520 Answers
It'll be there,just stick a cd in drive ,if not autostart click start,run.in box type d: and enter.whatever is on the disk will show up in a window.to write to disks youll need software like nero or roxio
Posted on Mar 04, 2008
    Genius:
  • 3,587 Answers
Open control panel, system/device manager, and click on it to ensure it's no conflicts
Posted on Mar 02, 2008
Computer doesnt detect drive
Not exactly The computer detects the drive but windows does not detect the driver. Uninstall the drive in the Device Manager and Restart the computer. This will reinstall the driver..
Nov 29, 2013 | Panasonic (CF-VDRRT1M) CD-RW/DVD-ROM...
Installing DVD-RW LiteOn iHAs124-04 b AL0L with Windows 7 64bit but getting "Device driver software was not successfully installed." General Device Properties show:" Windows cannot load...
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or the drivers may have been corrupted or you might have a virus run your antivrus program you might have to physically unplug the leads for this cd/dvd drive restart your computer then plug them back in this should activate the found new hardware wizard or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Apr 26, 2011 | Lite On LiteOn IHAS124-04 Black 24X SATA...
Hi, The DVD/CD Rom Icon has dissapeared on My Computer. When I go to control panel - device manager and click on the dvd/cd rom drive icon I get the following message in the genaral...
You will need to re-install the driver. Right click the device in device manager and select properties. Navigate to the driver section and uninstall all existing drivers. (It may *not* give you the option to do that, depending on how corrupted the driver is, but it should.)
Reboot the PC.
Upon reboot, Windows should find the new device and install generic drivers. It will probably ask you to reboot a second time.
Apr 07, 2011 | LG GSA H62N Super-Multi - Disk drive - DVD...
Driver for dvd-r 8801 need a driver for dvd player windows won't recognise it
The drivers for DVD ROM drives are built into Windows and there is no download.
If Windows does not recognize th drive then it could be a hardware issue or possibly a BIOS setting is wrong.
Does the Windows Device Manager show an un-recognized device?
Apr 14, 2010 | LG (GCC4521BK) CD-RW/DVD-ROM (Combo)...
DVD/CD Rom Drive - Cannot find hardware devide
i think you have the motherboard to rom drive cable problem, plz change your cable and try again....
Nov 11, 2009 | E-Machines eMachines Desktop PC
Windows unable to locate cd drive
you reformat your hard disk and install guienuine microsoft window xp your problem will be fix
Oct 26, 2009 | Computers & Internet
DVD-ROM and DVD+RW
Did you do a system "Restart" after the driver install? Sometimes that is all that is required to enable the device to work.
Sep 11, 2009 | Intel DG31PR Motherboard
Laptop DVD-CD-ROM wONT WORK
the connection wire of your laptop with DVD ROM has been got tampered . nothing to worry it is just alittle problem go to any repair shop & get it repaired.
pls rate my solution
thankyou
Feb 12, 2009 | LG GWA-4082N DVD RW Dual Layer Burner
CD-ROM Driver Problem
CD-ROM error codes cdr101, cdr102, cdr103 Test the CD-ROM drive.
Device Manager information and help Later versions of Microsoft Windows renamed this category to DVD/CD-ROM
Installing a IDE/EIDE CD drive Ensure you have a working bootable floppy diskette with CD-ROM drivers.
Click on the above links, Follow instructions.
Should get ya back in/ Please dont for get to Vote.Thank you.
Dec 14, 2007 | Compaq Presario R3000 Notebook
HP Compaq Presario V2000 Notebook Logo
77 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
