Question about LaCie External USB 2.0 500GB 7200 RPM 500 GB Hard Drive
Lacie hard drive nonfunctional
Doesnt appear on my desktop no matter which wire i use to connect it.  turns on, whirs and everything, but it won't appear on my desktop. i have important information in there and now i can't ever seem to be able to access it again.
my hard drive was working fine for about two weeks now i cant get it to show up in my computer. how do i get it working again?
  • 11 more comments
  • gilstrapt Mar 03, 2008
    i am using the same port i used before but i have tried other ports. the sound comes on that it has been plugged in but the desktop icon doesnt come up anymore
  • BigMuff Mar 03, 2008
    i plug my Lacie into my mac mini and turn the Lacie on.the orange light comes on and you can hear it working except all the computers i try it on,never register that anythings there.this problem started about 1 and a half months ago and i have been searching for repair in surrey or a way to fix it ever since.i have tried lots of usb cables.any help?
  • ronald2000 Mar 18, 2008
    wont show up on desktop or on the computer file comes on but makes beeping noise and wont show
  • Celidor Apr 06, 2008
    I have the same type of hard drive and it shows up fine under mac os and I used Disk Utility to make the file format FAT32 so I could use it on windows but it still shows up fine on Mac and says it is FAT 32 format but when I plug it into windows it makes a beep noise notifying that a device has been plugged in but nothing shows up,
  • chrishale53 Apr 18, 2008
    I have used the La Cie drive to back up OS Leopard Time Machine: now it refuses to appear on the desktop. No idea what to do!!
  • Marieheihei May 03, 2008
    my lacie harddisk has been working fine for 6 months but all of a sudden my computer won't recognize the harddisc. When I turn the lacie harddisc on it starts working, but make weird sounds and after a little while the yellow light turns red and stays that way.
  • bexstar May 22, 2008
    I have a 1TB lacie external drive that we have been using for about a year now with our mac mini. This has been working fine & all iphotos & itunes and certain applications are stored on the device. I am also running leopard which we upgraded to around xmas time and we have been using time machine to backup onto the lacie. As of monday - time machine would not work and we could not download to itunes - and the amount of songs were about a 5th less then we know we have in itunes. tried to get time machine to work but wouldn't. shut down the mac thought about it and went back to it last night - now the lacie cannot be seen by the mac - I have gone into disk utilities shows it's there and I can eject it but I cannot repair or verify .... don't know what to do PLEASE HELP
  • honkyza Jun 23, 2008
    Hi, hard drive not appearing in "my computer" when plugged in so cannot access it
  • teppisb Jan 17, 2009
    have the same problem
  • Anonymous Feb 16, 2009
    I have a new Lacie hard disk 750GB for storing from a PVR. It records and plays with ease. When plugged into USB port on my computer the computer does show anything in the port even after a new hardware search.
    R.L.
  • Anonymous Feb 23, 2009
    pwr lite comes on and does not show up on the computer, plud into the same port
  • guystefan Mar 15, 2009
    My Lacie external drive has been working fine for a couple of months, since I bought it, but now when I turn it on a pane comes up entitled "Disk Insertion" explaining, "The disk you inserted was not readable by this computer." and then shuts itself off.
    I have important audio multitrack recordings stored on my Lacie and need to retrieve them.
  • Anonymous Apr 12, 2009
    hard drive comes on,but doesnt show up in desk top,using a mac.
I ran into this issue this week with my lacie big disk 500G external. Unit would power on when plugged into a pc blue light would flash and nothing no connection ding from windows.
Blue front light would flash repetedly slight ticking sound from drives but no connection i finally fixed this and gained access to my data by opening up the case and pluging my pc 12v connectors into both drives to power them up but leaving them connected to the lacie internals worked instantly and ive since copyed all my data off my 500 and will just transplant the drives to internal use on my pc. you cannot connect the drives internally and then copy the data due to the fact that they are raid 0 stripped drives so this hybrid setup works if your external case isnt powering up the drive correctly as mine wasnt.
Posted on Oct 02, 2008
Can firewire port be burned out if light is on but don't see Lacie on desktop?
Mike
Posted on Dec 02, 2008
Solution #6 wokerd for me, I only han to power the external case also in order to get the USB working, also the LaCie Ethernet Agent proved helpfull in getting a connection the the hard drive.
Posted on Feb 19, 2010
I connected a Lacie external HD usb by neil poulton to my dell 64 bit system. It the tone announcing that new hardware was added. I don't see it on my desktop and can't see it anywhere. I have downloaded the software. Can you give me some options.
Posted on Oct 18, 2008
I CANT GET LACIE TO HELP ME WITH PRBLM HAVE SINCE TORE DOWN DRIVE AND SCRAPPED IT WILL NEVER BUY A LACIE AGAIN CAUSE THEY R TOTAL JUNK IF U HAVE TO HYBRID Y BUY IT WHEN U CAN JUST BUY A 500GB DRIVE AND PUT IT INTO COMPUTER WILL BUY A WESTERN DIGITAL NEXT TIME HAVE ONE THAT CAME OUT WHEN HIGH SPEED DRIVES FIRST CAME OUT AND HAVE NEVER HAD A PRBLM WITH IT THANKS FOR THE SUGGESTIONS AND HELP ANYWAY.
    Problem Solver:
  • 6 Answers
What plug are using to plug it up? a usb plug? try another port.
some wires or cables are rated for higher frequency and speeds.
windows xp plug and play gives that sound as it sees a port being plugged into then a desktop comes up asking you what you want to do.
I had a ethernet port on my compaq go out while under warrenty but just put in a new linsky card in it. they wanted me to send it to them.
hope this some help
Posted on Mar 02, 2008
    Scholar:
  • 173 Answers
The manufacture should have a techline and they can walk you through it and find the problem on the phone ... via hardware or software.
Posted on Mar 15, 2008
2 Suggested Answers
ginko
  • 19396 Answers
SOURCE: lacie hard drive nonfunctional
You can try buying a new HD enclosure, then removing the HD from inside the one you got and mounting it inside the new one. Try also disconnecting completely the power cable from your computer for five minutes and then plug it back to the power and restart it. I know it sounds weird, but sometimes usb mass storage devices suffer troubles caused by electrostatic charges.
Hope
Posted on Feb 13, 2008
My mac laptop suddenly won't recognize it
you may need to swap the usb port it's plugged in
Jun 11, 2012 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
I think I've plugged in the wrong power adapter. Now, once connected, my Lacie makes one whirring noise and fizzles out.
If the wrong power adapter was plugged in the electronic circuitry has been damaged. The only option is to replace the whole hard drive system.
Sep 18, 2011 | LaCie Rugged All-Terrain (301017) Hard...
Hard drive does not always appear (mount?) on my desktop (Mac) I hear humming sound from inside. Has been going on for at least 6 months with increasing frequency. Is happening more than 50% of time now. 2...
Your hard drive is toast. If the computer doesn't recognize the hard drive and/or you hear a constant turning sound then your drive is broken and can't be repaired. You'll have to have it replaced.
Aren't you glad you backed up everything?
Jul 09, 2009 | LaCie (300728U) 250 GB Hard Drive
Lacie HArd drive not accessible
Start > Control Panel > Administrative Tools > Computer Management > Disk Management
Find the drive on the bottom section, right-click it and assign an unused drive letter of your choice. It should then appear in windows explorer.
Jun 30, 2009 | LaCie (300770) 250 GB Hard Drive
How to correct connection problem for two LaCie Desktop Hard Driv
Here is the support website for the LACIE products.  As far as I knowthis site simply answers questions. Sounds like the hard drives are bad to me.
http://www.lacie.com/support/
Jan 07, 2009 | LaCie Computers & Internet
Hard drive motor just cant get a full head of steam going
When the motor and the heads start getting noisy, clicking and whirring, and the hard disk access time gets abnormally longer than usual, that means that the disk can fail at any time.
Better saving all your data and get a replacement drive.
If this happened on two Lacie and they did not receive any shock, then call Lacie to complain : Contact Support
Nov 22, 2008 | LaCie External USB 2.0 500GB 7200 RPM 500...
Lacie 1TB external hd won't mount!
check wires connecting them together first, ok?
then, turn off the LaCie, connect to your MacPro, and then turn on the drive..
that should show as a mounted drive.
need printer drivers update?
Mar 09, 2008 | LaCie Big Disk Extreme with Triple...
Hope
Feb 13, 2008 | LaCie Design by F. A. Porsche 160 GB Hard...
LaCie External USB 2.0 500GB 7200 RPM 500 GB Hard Drive Logo
4,197 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
