Question about Microsoft Xbox 360 Console
Took my 360 carefully apart to clean the eye. Put it back together light turns on then off.
Took my Xbox 360 carefully apart to clean the eye. Put it back together light turns on then off.
  • licuta
    licuta Mar 04, 2008
    its not OLK
Its olk
Posted on Mar 02, 2008
I took my xbox 360 slim apart to clean the fan heat sinks etc and put all the connections back into the disc reader and put the whole xbox back together but now the controller will not connect. the...
I havn't had the chance to work on a Slim yet, but from my experience with Phat 360s, you should clean out the connectors for the Ring of Light board with alcohol before reattaching it to the motherboard.
Feb 14, 2014 | Microsoft Xbox 360 Console
Xbox 360 elite wont turn on no lights power cord lights up
Hmm... it seems it's a problem with the power adaptor. Have you tried to replace it?
Mar 23, 2013 | Microsoft Xbox 360 Elite Console
Cleaning disc areas, now 360 won't turn on when restarted
First of all I highly recommend not opening your Xbox 360 unit unless you are certain you know what you are doing. It's very easy for someone to make a problem worse instead of better.
Have you checked the light on your power brick? It should be yellow when the console is off. When you hit the power button does it turn green, stay yellow, or turn red? If it turns red, you have a serious problem and need a qualified technician to look at your machine immediately.
Jan 01, 2010 | Microsoft Xbox 360 Console
Its not reading disc
you need to take your Xbox apart and get to the DVD driver and open it make sure that the tray is open. the eye is on a gear rod, all you need to do is turn that rod a few times so that the eye moves forward. put it all back together and try it. i am 99.99% sure it will work, hope this helps u
Nov 11, 2009 | Microsoft Xbox 360 Console
My xbox 360 wont play discs - keeps repeating open tray, I can play demos and xbox live but not discs or movies, any tips?? Thanks!
I just found a post on this and it worked for me. My warranty is past. So I took matters in my own hands. I took it apart which was fairly simple cleaned the lens and surrounding areas but it didn't work. But this is what I found out its not reading the disk because the disk isn't spinning. With the box apart and drive open I put it back in the system and turned on the power I noticed the drive would spin slowly I then while the disk was trying to load I spun the disk by hand to help it along and wala it started spinning I powered down put it back together and as of 10:45 2night my gaming nightmare is over. I hope this was helpful. Good luck all!!
Jul 14, 2009 | Microsoft Xbox 360 Console
My xbox wont read my game disc
if you can't send the xbox back to Microsoft this worked for me.
The 360 would spin the game up and say reading but than stop and do nothing.
I took the case apart, took out the cd drive, took that apart so i could get to the laser.
put a little big of very clean water on a q-tip, wipe the laser lens down and use the dry side to dry it off.  put it somewhat back together and test, this worked fine for me, it read a disk no problem.
Feb 21, 2009 | Microsoft Xbox 360 Console
Picture jumps when i turn on my console
it could be your laser needs cleaning, strip the machine down and take apart your dvd drive casing. get a cotton earbud and spit on it a little, in a very careful clockwise motions (dont put too much pressure on) clean the laser eye with the cotton earbud (with the spit on it). you can also use alcohol but i dont like this as it can sometimes leave a little film over the laser.
put everything back together then try again if its ok you have fixed it, if its still the same let me know and ill find a guide on how to adjust your laser unit and put the power up slightly.
www.fixmyconsole.co.uk
Jan 30, 2009 | Microsoft Xbox 360 Console
Xbox 360
i order to fix the 3 red lights on your 360 u must take it apart all of it and then clean it from top to bottem and then put back together when the light s flash it does not mean your 360 is broken ight it just means you need to clean it
Oct 31, 2008 | Microsoft Xbox 360 Console
360 wont turn on
The disk tray button on the unit is probably being pushed in from the outer cover. When you took it apart and put it together you may have pinched the button in. Very carefully inspect the disk tray button area. The button needs its full range of motion. The faceplate is pushing the button in and that is why it works without it. Or the face plate is making the top cover to press in on the button. Go over the area and watch what the pieces are doing when you assemble the front in regards to the tray button. I had the same problem. Remember these pieces are plastic and after being run (heat) the plastic may want to warp a little since new.
Sep 27, 2008 | Microsoft Xbox 360 Console
"Unplayable Disc"
First of all clean the disc, use warm water and a soft rag. after cleaning the disk, very carefully take apart your XBOX and use the rag to wipe off the eye touch nothing else. Place the XBOX together the same way that you took it apart. Hope this helps!
Feb 19, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
183 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
