Benq lcd Displays only white
I have a BenQ FP791 17 in LCD. I was working until one day I turned it on and it now only displays an all white screen. I plugged it in to another computer, same problem. I can add it as a second monitor to windows but all it displays is white. Windows finds it and the mouse can move over to it but I do not see anything. I am handy with a soldering iron, but not nessisarily diagnosing electronic problems. Any suggestions.
  • Anonymous Apr 22, 2008
    Hi all, I have the same problem with a DELL 1707FPt LCD display.
    Thanks
    Chinepoh in CAMEROON
  • MatrixNet Oct 26, 2008
    I ended up replacing the bulging capacitors on the board inside, and now it works. Thanks for all the comments and help.
  • 105 Answers
Most often the all white screen is the result of a missing voltage to the LCD panel. We usually find an open fuse on the panel circuit board. Unfortunately replacing the fuse does not usually fix the problem.
Mike
Posted on Aug 14, 2008
I have a acer al1711 with same problem can i do something?
Let me know write on my msn address masmaster@hotmail.it
Thanks
Posted on Oct 25, 2008
Greetings, I repaired one of these LCD display by replacing all 4 of the 5707 transistors but now the screen turns to complete white and no image is seen.
Please advice
Chinepoh
Posted on Sep 15, 2008
It is possible that you have a dry solder joint on your monitors mainboard somewhere around the power input. That is on thing that can cause that on LCD Displays. Power is going to the backlight only and not to displaying the image data as well.
If you are able, remove the housing from the lcd display, and look at the mainboard. Look out for leaking capacitors and dry solder joins.
- TimeMeddler
Posted on Jun 27, 2008
I have a Gateway FPD2275W monitor and once in a while it shows an all white screen for no apparent reason but will work other times...for instance if I reboot my machine the screen will go all white (when the BIOS screens are displayed) and I have to turn it off and on again (maybe a few times, once the Windows welcome screen comes up) for it to work again...I'm not sure what the problem is that would cause it to go all white only sometimes...If it was a problem with the panel or board wouldn't it not work at all?
Posted on May 12, 2008
    Champion:
  • 220 Answers
Normally a white screen is a problem with the panel or main interface board.
Check if this is under warranty,normally BenQ has a three year warranty.Check out www.benq.com under support after selecting your region.
Posted on Mar 04, 2008
Benq lcd monitor
The monitor requires an input before it can decide what the input is.
Nov 05, 2013 | Computers & Internet
My laptop benq r56 work with wierd coulours white screen
Here are some steps which you can try.
- Plug in an external monitor and check if you get the same colors on the external display.
- If you get the same display, install an updated driver for your video card. But if still the same, your video card needs to be replacement (if dedicated) or your motherboard needs to be replaced (if integrated).
- If you external display works fine then the problem is narrowed down to the LCD. Either the LCD inverter or the LCD cable is failing and needs to be checked/replaced.
Hope this helps.
May 27, 2011 | BenQ JOYBOOK R56 154 WXGA CCFL Glossy LCD...
Problem with color monitor BenQ G900W лblack tsvyan almost gone? and the predominant red hue! how to fix it
BenQ 19" monitor GENERIC pnP lcd
displays upper part (a 12 cm wide band) lighter than the down part which is normal
the cursor when in the lighter part becomes ghosty and very white
Oct 27, 2010 | BenQ G900W Monitor
My BENQ monitor blacks out
Use the remote to access menu mode
then try inputs through the remote
Jun 16, 2009 | BenQ FP71G 17" LCD Monitor
MY SCREEN ON MY LCM-17v8 MONITOR TURNS COMPLETELY WHITE AFTER FIVE MINUTES!
Generic problem for all Monitors Benq lcd Displays only white var g_tryMail = 0; MessageRate.ThreadID = 421124; MessageRate.ProductID = 689784; function addthschng() { if($i('at_email') != null) { addthis_sendto('email'); } else { g_tryMail++; if(g_tryMail Report abuse shared by 2 users posted by MatrixNet on Mar 02, 2008
Comment posted on Oct 26, 2008I ended up replacing the bulging capacitors on the board inside, and now it works. Thanks for all the comments and help.
Feb 20, 2009 | Westinghouse 22" Widescreen LCD Flat Panel...
Half Display
That Seems to be a panel problem.Benq provides 3 year warranty,Try contacting local BenQ service centre in your country.
Samir
Aug 11, 2008 | BenQ FP71E 17" LCD Monitor
Dark disp-lay
sorry mate,that is dreaded power interter board inside lcd,read about similar benq model dramas here http://www.electronicrepairguide.com/benq-t705-lcd-monitor-repair.html
Jun 03, 2008 | BenQ T705 17" LCD Monitor
BenQ FP7IB LCD monitor, turn black aftr BenQ logo
Try to plug into another computer and wait to see.
If it turn up to be same it somewhere defect from the main board of the lcd.
If if not the same turn up to be, you should reinstall the OS because the software is corrupted or your display card problem.
Apr 16, 2008 | MPC Computers AOC 7F 17" CRT Monitor
Screen displays fine for a second, then goes blank
Dor, BenQ has a 3yr warranty on their monitors. I would contact their tech support and receive an RMA to return it for repair. It will cost you shipping out there but they will ship it back. I has a BenQ FP731 myself and it blew a capacitor inside that allowed the screen to stay on. Fixed it and had it back in 5-7 days. Good luck.
Aug 15, 2007 | BenQ FP737S-D 17" LCD Monitor
Computers & Internet Logo
1,585 people viewed this question
Alun Cox
David Payne
David Payne
