Question about Lexmark X8350 Print, Scan, Copy and Fax All-in-One Multifunction Printer Plus Photo w/USB Printer ...
Paper jam I don't see any paper that is jamed. looks like paper is not getting pulled in. turned off & on & comes up with same error..paper jam clear jam & press check I took all paper out of try & same error shows up
  • paul5015 Mar 02, 2008
    this printer all in one is new, just out of the box. I left it unplugged over night & now the error message is "papper out, load paper & press check"
    I had it print 2 coppies, one from top load copy & one from opening cover & laying flat.......they both worked. Then I tried to print a photo from a flash card & it didn't work. now it shows out of paper. With the photo I just used typing paper.
    to me it looks like it is not picking the paper up
    Scholar:
  • 148 Answers
Hi this is some small pieces of paper which had gone inside in ur printer when u prints. this one have to contact printer engineer to clean the printer
Posted on Mar 02, 2008
PRINTER IS JAMMED SHOWING ERROR
I had a similar problem, my printer was chewing the paper and then I was getting a jammed paper message. I looked inside but couldn't see much anything. I then removed (unscrewed) all the panels, and next I know, a culprit materialized, in other words, something fell inside the printer. I then managed to put it all back together, ended up with a few extra screws, but heck it works like a clockwork. God bless screwdrivers with magnetic tips, they made my life so easier.
May 23, 2012 | HP Photosmart C6180 All-In-One InkJet...
Jamed paperc86 paper is jamed
Epson Stylus InkJet Clear a paper jam in printer
Jan 05, 2012 | Epson Stylus C86 InkJet Printer
My paper keeps jaming
paper keeps jaming - Brother MFC-3240C All-In-One InkJet Printer
Nov 09, 2010 | Brother MFC-3240C All-In-One InkJet...
Paper Jam cleared but?
It sounds like the paper sensor in the paper try is broken or jamed. Remove the paper tray and locate the paper sensor. Check if it is jamed in the up position or if it is broken.
Jan 21, 2010 | HP Officejet Pro L7780 All-In-One InkJet...
Paper jamed
Hi
Thanks for using FixYa. Perform the steps below in order to solve this incidence:
  1. Disconnect the power cord or power supply adaptor from the rear of the HP All-in-One product.
  2. Remove the paper pack remaining in the input tray.
WARNING - Do not try to remove the jammed paper sheet yet. Trying to clear a paper jam from the front of the device can damage the print mechanism. Always clear paper jams through the rear access door.
  1. Open the rear access door or the two-sided printing accessory.
  2. Gently pull the jammed paper sheet out of the rollers.
  3. If the paper tore when it was being removed from the rollers, check the rollers and wheels for torn pieces of paper that might remain inside the device. If not all the pieces of paper are removed from the device, paper jams are likely to occur again later.
  4. Replace the rear access door or the two-sided printing accessory.
  5. Restart the printer to continue the current job.
Please seee this link for more details--
HP Photosmart C5280 Paper jam error
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 14, 2009 | HP Photosmart C5280 InkJet Printer
Paper jam in printer
Check the path path by pulling out the cartidge/ drum unit, the tray(s), and check the fuser(hot, turn off the printer and let it cool!) in the rear of the printer there is an access door(green/ blue tabs show where to open and look:).   If your still showing jams sometimes a sensor (small black arm) is dirty (blow with compressed air), out of place, snagged, or faulty.
 Blow compressed air around the arms and look at the sensor arms. They should be able to move freely. (paper can get torn and wrapped around the sensor arm causing a fault: tweezers and patience)
Turn on the printer and see if that works for ya.
The only other jams come from the feed tires not being able to pick up the paper or the resist pad/roller being worn out and letting two sheets or more in at once (but this doesnt sound like your problem).
Much luck
Mar 19, 2009 | Dell Office Equipment & Supplies
Printer erroneously reports a paper jam
Perform a hard reset of printer and see if that clears up the situation. Also uninstall and reinstall drivers.
Sep 04, 2017 | Office Equipment & Supplies
Paper jam
Remove the paper following the procedure below.
(1) Load a single sheet of the same paper in the Auto Sheet Feeder in portrait orientation.
Do not load it in the landscape orientation.
(2) Turn off the machine.
(3) Turn on the machine.
The paper is fed and then pushes out the jammed paper as it ejects.
If you cannot remove the jammed paper or the paper jam error continues after removing the paper, contact your Canon Service representative.
James Mac
Sep 09, 2008 | Canon PIXMA MP600 all-In-One InkJet...
HP 6210 All-In-One
Open up the top and look into the cartridge/paper print area. Look in the corners, Sometimes little pieces of paper can still be stuck there. Once you are convinced that the paper and cartridge path is clear then...
Pull out the paper tray. Look inside the opening. If there is paper there then pull it out.
Take all of the paper out of the paper tray.
Turn it over (paper on top is now on the bottom of the tray)
Try it now.
Jun 20, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Papper jam.
There should be a door on the back of your printer, scanner, copier. Open that door and see if you have a paper jame there.
Apr 20, 2008 | Office Equipment & Supplies
Lexmark X8350 Print, Scan, Copy and Fax All-in-One Multifunction Printer Plus Photo w/USB Printer ... Logo
173 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
