Question about LG VX6100 Cellular Phone
Camera flash stays on...
After I dropped my phone in the bathroom sink; water was running...the flash was intermittent and now it is on all the time...draining my battery and the phone is hot. I have taken out the battery to dry, although it does not appear to be wet.
  • PWW in CA Mar 02, 2008
    Thank you Trifect7, I will try that.
  • Clicker44 Sep 03, 2008
    I have the same problem... my phone landed in the washing machine! When I took it to the store they claimed they had never seen such a thing and couldn't fix it, so I had to get a different phone...which I don't like as well. Thanks so much for the info, but is there anyway a normal person could fix the "Fused contact point?" There would be no loss as it's unusable now.
  • 57 Answers
You probably have a short somewhere in the phone. Open any access points, take out battery, mop up any visible liquid with a q-tip. Keep it in warm very dry area for 3-4 days (lots of air movement will help) and it will probably dry out inside. Connect battery again briefly, if flash still burns, leave for another few days. Fan heater on very low may help here, put the phone about where you would put a baby. Still not right, you probably have a fused contact point and need a repair.
Posted on Mar 02, 2008
Getting salt water in bathroom sink
the only way to get 'salt water' from any tap in your home is to have a water softener operating there. Most likely the culprit is calcium from your hot water heater as a result of local hard water.
If this is in fact the case, the aforementioned water softener may be your solution. You can also periodically flush out your water heater to dispose of mineral build up inside it, or reduce the tempurature it operates at.
Aug 24, 2014 | Plumbing
Richmond water heater
The water inlet to the heater must be plugged.
May 16, 2017 | Water Heaters
Bathroom sink smells strongly like sewer when water runs fast.
Suppose you plugged the drain of the sink and filled the basin with water, then removed the plug. I must think that only after the basin empties you would get the sewer smell, and the smell would persist until you slowly ran some more water. If you try this, and this is the result, then the problem is that the sewer vent (that is supposed to prevent the water in the trap under the sink from being sucked down the drain) is not working right. If this is a new problem then you may be able to clear what is probably a blocked vent pipe. If this bathroom has always had this problem, then you have a poorly designed or executed vent pipe setup that you can only fix it with some surgery to your plumbing. However, to clean the vent you can try pouring a good bit of drain cleaner down the vent pipe on the roof, followed by water. But because there may be several vent pipes sharing the same vent stack out the roof, the drain cleaner may not get to your blockage and may simply go down a different path. Good luck.
Oct 15, 2012 | Plumbing
My bathroom faucet leaks a drop of water every 30 seconds
If you live in a hard water area, you probably have some buildup on the seals. You might be able to clear it by just running water through it, but most of the time, you might have to take the faucet off and soak in vinegar or replace the seals/cartridge.
Sep 26, 2011 | Moen Bathroom Sink Faucet - 4-inch...
Have a Rannai R75LS and getting hot water everywhere except my sink in the bathroom. System doesn't come on with only bathroom sink running.
I think these have a water pressure s/w or water movement s/w id replace the aerator 1st to a non water saver one or if possible remove water flow reducer looks like a metal washer .. if this not help you may need to replace the pressure s/w...in tank..
May 01, 2011 | Rinnai Water Heaters
When do you need to vent a bathroom sink?
You always need to vent a sink. If you do not vent the sink it will create a vacume and **** water, or air from the nearest fixture.. example, if you connect to the sewer line near a bath tub, when you run the sink water it will **** air from the bath tub drain. If it sucks a lot of air, you will smell the sewer odor since the water is no longer blocking it.
If you cannot run the vent to the roof, there is an in wall vent valve called a studor vent that may work. Get with someone at Lowes or Home depot to show you one.
Feb 09, 2011 | Home
I have a Moen Monticello bathroom faucet. I am
Moving left to right: I am not an expert, but I have installed a fair number of faucets. Seems like a basic issue of just getting under the sink and tightening up. Make sure someone is topside to assure the faucet stays straight and does not move as you tighten up below. It is never easy to get a wrench and your hands in the proper position to tighten up the nut, but don't give up try a smaller Channel lock wrench if necessary.
Sink Stopper: http://www.lowes.com/lowes/lkn?action=howTo&p=Improve/PopUpStop.html
Jan 02, 2010 | Moen Bathroom Sink Faucet - 4-inch...
PORCELAIN SINK UNDER GRANITE
Hi just unscrew from under sink use construction grade clear silicon screw it back in do not use for 24 hours and it will be ok
Apr 06, 2009 | Oxo Porcelain Pedestal Bathroom Sink,...
LG VX6100 Cellular Phone Logo
130 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
