Question about Frigidaire 20 cu. ft. / 566 liter Upright Freezer FFU20FC4A
The buzzer is loud
I have un freezer ffu20 and now has one loud (buzzer) what is it ? and how fix the problem.
  • Anonymous Apr 24, 2009
    I have the same freezer that is 18 months old. Last nite the loud buzzer sounded and we unplugged it. When I checked it, I found and removed the buzzer.. MY question is what was it indicating?
    Temp problem, defrost problem?
  • robert samples May 11, 2010
    hows it cooling is there frost on the back wall or ice in the bottom and can you hear a fan running when you open the door and if you look at the bottom kick plate there is a hole there that you can turn the alarm off with a pencial eraser are the sides hot and last is the compressor running
    Problem Solver:
Frigidaire # LFFH2067DoW2 # WB52430831 upright freezer (frost free commercial)
Freezer is still freezing. The alarm sounded and I switched the switch off to turn off. The manual says that the temperature isn't at the right temperature and once it reaches the correct freezing temperature the light will come back on or the sound would go off after at least 4 hours. This was since last night about 6:00 and if i switch the switch the alarm is still sounding. The left side of the freezer is a little warmer than usual. Any suggestions
Posted on Jun 02, 2008
Frigidaire Model FFU20FC6AW4 My freezer conditions are same as those stated in reply by ymmat per clarification request of tech17.
Posted on Dec 13, 2008
Kenmore freezer buzzer
I would need to model number to check if you have a on/off for you over temp alarm. That "Buzzer" is a over temp alarm. If you fridge uses a 9volt battery then you might need to replace the battery. Please post your model number.
Mar 13, 2013 | Kenmore Freezers
What would cause an intermittent buzzer noise from a Samsung RF217ACRS refrigerator? It otherwise works fine.
That's the icemaker cycling.Ifya don't have water connected,it's still think'n its filling trays and dumping frozen cubes and all that stuff.Turn off the icemaker.Rigger said that.C-YAAaaaaaaaaaaaa
Aug 28, 2012 | Samsung RF217ACRS - 20 cu. ft. French Door...
Alarm buzzer went off and the yellow and redlights are "on."
The on/off switch is only for the alarm. Some people do not want the buzzer to sound for them. If your buzzer is going off then the temperature in the freezer is too warm. It usually means the door was not closed all the way or there is a malfunction in the cooling system. Check the door and seal, make sure it is closing all the way around. If it is and the alarm does not stop on it's own then you will need service done on the unit.
May 08, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
My freezer just keeps buzzing non stop very loud but seems to be still working how can i stop the buzz
I think you will find that your freezer is warming up. Check the temp inside the freezer. It should be between -10 and 0 degrees. If not, your buzzer will go off until this is repaired.
Sep 15, 2009 | Frigidaire Freezers
Upright Frigidaire Freezer
The Amber light is the Power 'On' indicator. The Red light is a Temperature Alarm indicator. THe Red light comes on if the freezer compartment rises above 20 degrees F (for example a freezer malfunction or someone left the door open). You also probably have a rocker switch (or two holes that are over a rocker switch) that is in between these two indicators. If you do, that's an audible (loud buzzer) alarm when the red light comes on. The rocker switch is a simple on-off switch to silence the alarm or turn it back on.
Jul 07, 2008 | Frigidaire 20.6 cu. ft. / 583 liter...
Frigidaire 20 cu. ft. / 566 liter Upright Freezer FFU20FC4A Logo
1,188 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Dan Webster
Dan Webster
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
