I have an error 5100 on my Canon mx320 printer what do i do?
    President:
  • 2,306 Answers
5100 says the carriage is not moving freely from side to side, or there is grease on the clear plastic encoder strip behind the carriage. You can clean the grease with a Q-tip and alcohol, but also look inside on the far right and left sides for anything like paper scraps that can stop the carriage.
Posted on Feb 25, 2010
Error 5100 - I got this error because I forgot to remove the tape and packing from the printer cartridge carriage!
Posted on Dec 06, 2010
SOURCE: CANON IP 1300 SERVICE ERROR 5100
ERROR 5100 means that there is some foreign object blocking your ink cartridge carriage that disables it from moving. It may be a piece of paper or a scotch tape or a staple wire. You may try cleaning also the encoder strip with a moist tissue paper. Furthermore, you may also try cleaning CAREFULLY the contact points of the cartridge holder and the cartridge itself (those shiny bronze pins) with a moist lint-free cloth.
Posted on Oct 29, 2009
SOURCE: Service error 5100 on my canon Pixma mp110
Had the same problem, i just replaced the black ink cartridge which was finishing at that time and resetted the counters. No problems after that. Not sure whether this will help though.
Posted on Aug 31, 2008
alpug
  • 1961 Answers
SOURCE: Canon MX320 Printer getting code
Please reset the printer
1. Turn off your printer
2. Press and hold the STOP/RESET button
3. Press and hold Power ON button
4. While holding the Power ON button, release the STOP/RESET button
5. While holding still the Power ON button, press twice the STOP/RESET button
6. Release the Power ON button
7. Wait until it display an "idle" message. It will take about a minute.
8. When "idle" appear, open the top cover to expose the cartridges.
9. Lift up the cover for cartridge holder and take out both the black and color cartridges
10. Return the cover of cartridge holder and turn off the printer
11. Return the top cover and turn on the printer again
12. After the printer initialize, return the cartridges.
1. Press and Hold the STOP/RESET button and wait until it self restart.
2. Release the STOP/RESET button the the printer is restarting.
3. Wait for a few seconds
Posted on Oct 22, 2010
  • 412 Answers
SOURCE: Canon Pixma MP830 error 5100
As a technician, I have worked on tons of printers. This particular error had stumped me for a while, but I finally found the cause. As others had pointed out before, it can have alot to do with some obstruction in the print path, the gears, or ink on the clear plastic encoder strip. You're on the right track - I found the the purge cap (the white sliding mechanism that the print head parks to when it's not in use) was not lubricated well enough from factory. If you lubricate the sliders with some white grease (don't get it on the small wipers or the black caps) the mechanism can now slide more freely, and the unit can park the head properly without giving you the dreaded head homing error 5100 (or E-2-2 on the LCD display) Keep in mind that this repair will probably require you to remove the right panel off of the printer to gain access to the purge mechanism. There are two screws behind the printer, and two in front for each corrosponding side panel (the front screws are behind the grey front panel of the printer - open the top cover to see the clips which hold the front cover on) Hope this helps some of you out.
Posted on Mar 09, 2009
  • 1126 Answers
SOURCE: Canon mx330 Error 5100 Error 5100
Cancel printing, turn off the machine. Then clear the jammed paper or protective material that is preventing the FINE cartridge holder from moving, and turn the machine on again. If not remedied, turn off machine, unplug the power cord of the machine from power supply. Plug machine back in and turn power back on. If problem is not resolved, please contact service center. This info is from Advanced Guide Troubleshooting Section under An Error Message is Displayed on the LCD....error code 5100. This is a link to Canon to download Guides.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=18120
Posted on Nov 04, 2009
How to remove Error Message 5B00 from my Canon PIXMA MX420 Printer.
Not A GOOD printer engineer. This video tells you how to clear and reset that error.
How To Fix 5B00 Error On Canon MX Series Printers MX320
How To Fix 5B00 Error On Canon MX Series Printers (MX320 ...
? 1:39
https://www.youtube.com/watch?v=0waX_GF-h7U
Jul 26, 2012 - Uploaded by Internet-Ink
This video from Internet-ink.co.uk will instruct you on how to cancel the 5B00 error on the Canon MX series ...
How to Fix Error 5B00, Canon Pixma MX410, Solution - YouTube
? 1:57
https://www.youtube.com/watch?v=jLicZcZUmRY
May 5, 2017 - Uploaded by MJC
12:57. Canon Pixma MX420 Printer 5100 Error and Loading Ink - Duration: 5:57. Dustie Meads 228,823 views ...
SOLVED: My cannon printer mx420 has a error 5b00 how do i - Fixya
www.fixya.com/support/t22097789-cannon_printer_mx420_error_5b00_fix Dec 10, 2013 - Error 5B00 means that your ink absorber is full. you need to reset the counter protection and replace the ink absorber inside the printer. Visit the link below for instruction on how to reset the canon mp450 printer EEPROM http://pcmediks.blogspot.com/2010/09/how-to-reset-canon-mp450-printer.html. 5B00 printer error code, what is this?
24 Mar 2016
fix canon printer error 5b00 Questions & Answers (with Pictures)
12 Feb 2015
SOLVED: How to solve error code 5b00 on printer mg
18 Jun 2014
SOLVED: How to solve the error 5b00 on cannon ip 7240
5 Sep 2013
More results from www.fixya.com
How to get rid of the 5B00 error message on Canon printers ' en ...
www.en.rellenadodecartuchos.com/.../how-to-get-rid-of-5b00-error-message-on-cano... May 20, 2014 - The Canon printers are known to be one of the best printers on the market, recently with the adoption of the Continuous Ink System on several models, these Canon printers have more error message appearing. Today we are going to talk about the 5B00 error message and how to eliminate this error.
Canon Knowledge Base - LCD Error Messages - MX420
https://support.usa.canon.com/kb/index?page=content&id=ART109274 Please be advised that Canon shall not be liable for any malfunction or trouble caused by continuation of printing under the ink out condition. Note .... If the error is not resolved, connect the machine to the computer and align the Print Head on the printer driver. ... For example: 5B00, 6800, B200, 5700, etc. 5100 is displayed:.
How do you reset error 5b00 on mx420 - JustAnswer
https://www.justanswer.com > Computer Repair Questions > Printer Troubleshooting Jul 29, 2015 - The ink absorber is a series of pads/tanks, which catch drips from the printhead when parked, and is also used for maintenance tasks like cleaning and purging.Eventually this absorber fills up, and the printer shuts down operations, as continuing to operate it can result in ink overflowing the system, ... Error Message 5B00 from my Canon PIXMA MX420 Printer Google Search
Apr 21, 2018 | Canon Office Equipment & Supplies
What does 5100 code mean?
What is error code 5100 on the MP460? - Canon Community
community.usa.canon.com/t5/Personal.../What...code-5100.../103212
Jul 7, 2014 - Please remove foreign objects so that the print head holder can move: ... closet and hooked it up this morning, I was getting the 5100 message.
How to resolve error 5100 on an MX452 / MX459 - Canon
https://support.usa.canon.com/kb/index?page=content&id...
There are several reasons for error 5100 to appear. ... If the above recommendations donot help you resolve the error, the printer will need to be repaired.
How To Fix Canon Printer Error 5100 - YouTube
? 2:23
https://www.youtube.com/watch?v=rJQVwwRxPv4
Mar 14, 2013 - Uploaded by ITJungles
Learn how to fix the Canon printer error 5100, and have your printer running again. ... Reset error Canon ...
Jan 05, 2016 | Canon PIXMA MX340 Wireless Office...
Error 5100
1) Smearing or scratches on the timing
**** film;
clean the timing **** film.
2) Foreign material or paper debris that
obstructs the carriage movement;
remove foreign material.
3) Ink cartridge conditions;
re-set the ink cartridges.
4) Cable connection
5) Part replacement:
- Timing **** film
- Carriage unit
- Logic board
- Carriage motor
Aug 22, 2011 | Canon PIXMA MX320 Color USB InkJet Printer
Canon mx320 printer getting code error 5200
I have a canon Mx320 and I am getting the error 5200 how do I fix it ?
Aug 11, 2011 | Canon PIXMA MX320 Color USB InkJet Printer
How do you fix error message 5100 on my canon mx320 printer. I just went and bought new ink cartridges for it and put them in and now it doesn't work and this error message shows on my laptop
error 5100 means that the printer cartridge carrier can not move freely.
see inside the printer and find the one causing the cartridge carrier to stop. It could be a piece of paper or a dried ink on top of the absorber pads.
Apr 18, 2011 | Canon PIXMA MX320 Color USB InkJet Printer
My canon mx320 says paper jam when there is clearly no paper jam. How can i make this stop or reset the printer?
I have a Canon MX320 and am getting the same error message. It appears as if one wheels that aids the paper is not turning? I would also appreciate any help concerning this issue.
Dec 18, 2010 | Canon PIXMA MX320 Color USB InkJet Printer
Canon pixma mx328 error 5100
This error is one of the most common issues with Canon printer. Let me share my experience and how I used to fix this error.
First, turn off the printer, unplug the usb cable and power cord. Now, also turn off the computer (it needs to be restarted since the error is showing on the computer and will never go until you restart the system).
I hope you are not using longer usb cable other than the one that came with the printer. Sometimes long and defective cable causes this problem.
When you turn on the machine, open the lid (front panel door) and help move the cartridge carriage with your hand so that it'll move sideways. Sometimes when the carriage stuck, this happens.
If the above tips don't help, you need to call Canon and ask them your problem. If you are in the U.S. use this number to call Canon "1-800-OKCANON" or you can write using this form (Click here)
Good luck.
Thanks for using FixYa.
Sep 28, 2010 | Canon PIXMA MX320 Color USB InkJet Printer
4,996 people viewed this question
k24674
Marvin
Marvin
