Question about Dometic Rooftop RV Air Conditioner
Coleman RV Rooftop Air conditioner
The unit comes on run cold then the comperssor shut off (I think that's what shuts off) then a few minutes later it tries to come back on to make cold air but trip the breaker.
  • Rich Bo Mar 05, 2008
    I was able to try you solution the other day. I did the cleaning and found that I have no filters, (so I will get some). I did the cleaning and ran the unit while I had the covers off and it ran great. After I replaced the covers it started to cycle to often and I remembered that I read a solution for this, the return is sucking cold air from the output so I will need to make sure they are sealed from each other better. Thank you very much, I am sure you saved me many dollars and will share this site with others.
    Sergeant:
  • 288 Answers
If the compressor is tripping the breaker, then its 1 of 2 things. First clean the coils and change the air filter. If the coils are dirty and/or the filter is clogged, it will make the compressor overload and the high amp draw will make the breaker trip. If this doesn't solve the problem, you need to check the compressor itself. remove the connections at the compressor, leaving only 3 posts on it. You will need a meter to check for continuity to all 3. They should all have continuity to each other. While there check the wires. Sometimes a burnt wire will come off and arc on something causing the breaker to trip, if you are lucky.
Posted on Mar 02, 2008
My airconditioner on my 5th wheel comes on, but no fan or cooling happens
take it to an air conditioner repair shop it possibly needs recharged
Jul 17, 2015 | Dometic Rooftop RV Air Conditioner
Rooftop rv air conditioner unit will run but will not shut off. Have cleaned both filters.
Sounds like the thermostat is faulty. To check it turn it up to the max temp. It should shut off in a few minutes (providing the interior room temp is lower then the max temp setting). If it still does not shut off remove the t/stat from the wall. Pull off one of the wires it should stop. Re-attach the wire, if it starts up again soon as you re-attach the wire, replace the t/stat..
Jul 29, 2014 | Dometic Rooftop RV Air Conditioner
I have an RV with a duo therm rooftop air conditioner... when i turn the air on.. the compressor will run for a few minutes.. it blows cold air and then the compressor shuts down. Low freon??
Quite possibly low on refrigerant. Sounds like a pressure switch is shutting the comp. down after it pumps down for a few minutes. Someone will have to check the refrigerant with guages if you don't have any of your own. There should be ports to connect a set of guages near the compressor under the cover.
Apr 13, 2011 | Dometic Rooftop RV Air Conditioner
Coleman RV Rooftop Air Conditioner - cage fan making a noise like it is hitting on something as it goes around. The motor works as it should, low and high fan and cool, the air is cold. The only thing...
Those squirrel cage fans have a habit of coming apart, or getting dirt in them and going out of balance...then they wobble and hit the sides of the fan housing...
Make sure the fan is clean and also move it around a bit to make sure it is not coming apart....
Often the only way to fix them is too replace the sqirrel cage part...
heatman101
Mar 06, 2011 | Dometic Rooftop RV Air Conditioner
Motor still runs after cool air stops coming out
See if helping the fan turn will get it going thrn let it run awhile.. The fan motors rake a set if not used often enough.
Sep 16, 2009 | Dometic Rooftop RV Air Conditioner
Ice forming on inside of unit air not cold
clean the filters and check the drain, to clear the drain run a jug of warm water down the pipe
Aug 19, 2009 | Dometic Rooftop RV Air Conditioner
We have a Coleman 7300 rooftop ac unit. When the
The fan motor is getting hot and going off on the internal overload in the motor.
This is caused by either a low voltage, a bad capacitor, or tight or dry bearings in the motor.
To check the bearings turn the power off to the unit, then spin the fan blade if it spins freely then the bearings are ok.
To check the capacitor you will need some kind of
tester or you can buy a capacitor and replace it, that's what a lot of people do. They usually don't cost very much.
To check the voltage you will need a voltmeter and measure the volts at the unit.
Jun 07, 2009 | Dometic Rooftop RV Air Conditioner
Have a coleman rooftop unit a/c unit, after about an 1 hr. unit hums no air comes out
COLEMAN R.V. AIR CONDITIONER SERVICE AND REPAIR QUESTIONS
COLEMAN R.V. PRODUCTS
GO TO rvcomfort.com
Click on RVP (RV PRODUCTS)
Click on type of AC, if you can’t find the information you want there,
then click on contact us on the Green Bar.
You can get Service Support or Email address and Phone numbers.
Dometic Rooftop RV Air Conditioner Logo
559 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
