Question about Compaq Deskpro EN PC Desktop
Compaq deskpro how to remove cover of the CPU case
    Scholar:
  • 148 Answers
Use the following steps to open the case: WARNING: The edges of metal panels can cut skin. Be careful not to slide skin along any interior metal edge of the computer. CAUTION: This product contains components that can be damaged by electrostatic discharge (ESD). To reduce the chance of ESD damage, work over a non-carpeted floor, use a static dissipative work surface (like a conductive foam pad), and wear an ESD wrist strap connected to a grounded surface.
  1. Unplug all cables except for the power. Write down each cable location if you do not already know where it connects.
  2. Unplug the power cable and with the power cable removed press the Power button on the front of the PC.
  3. Remove the screws that attach the side panel to the computer. Do not remove other screws, such as the power supply screws, that are also located on the back of the computer. compaq deskpro - c00371492.jpg
  4. Slide the left-side panel towards the rear of the PC to remove it.
  5. If the front of the drive is blocked by an extra door that is part of the case, remove the front cover. You may have to remove the opposite side panel in order to access the front cover. Press in on the tabs that retain the front cover, there should three to four on each side of the cover and gently pull forward. It helps to have a friend help with this process. Carefully detach any cables that may also be attached to the front cover.
Posted on Mar 02, 2008
Compaq deskpro en case opening
Look at the back of the computer. One side panel removes. (Access Panel) There are two Thumbscrews to loosen on the Access Panel, then the panel is lifted off, or brought straight out.
http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?contentType=SupportManual&lang=en&cc=us&docIndexId=64180&taskId=135&prodTypeId=12454&prodSeriesId=96266#2
On this HP Support page click on -
Deskpro EN Series of Personal Computers Maintenance and Service Guide
Regards,
joecoolvette
Jan 20, 2012 | Compaq Deskpro EN PC Desktop
How to remove the top cover of compaq deskpro p3?
Press both tabs on the front plastic of the case, and pull in forwards. You can then lift the top off.
To replace, sit on, slightly forwards, and bang backwards with force.
Oct 19, 2010 | Compaq Deskpro EN PC Desktop
Tried swapping pIII 550 mhz slot one processor for Pentium III P3 1GHz Slot 1 CPU 1000MHz /256/133 SL4BS in deskpro en p550.It wont do anything, screen is blank.Compaq told me i could go as high as...
This isn't a sure fix by any means, but...
You could try unplugging the unit from the wall socket and opening the case. Touch a metal component inside the case for a few seconds to equalize static charge between yourself and your machine.
Next, remove the battery on the motherboard, and wait 5-15 minutes before reinstalling it. What this will accomplish is to reset the computers' BIOS (Basic Input Output System) settings to the defaults for the motherboard, which may let the machine figure out what processor you installed.
If it works, your machine will boot up, and you'll get an error message telling you that there is a checksum error or simply that a BIOS setting is wrong. You'll have to read the message and press the appropriate key to get into BIOS, then reset the date and time.
I hope this helps in some small way- It's rough attempting to set up a machine if you have no visual output to let you know what's going on.
If my solution gets you up and running, please let everyone know by writing a testimonial.
Oct 18, 2009 | Compaq Deskpro EN PC Desktop
Compaq Deskpro-P3 : While Starting Compaq Logo Appears,red light
its may ur cmos battery problem u can replace ur cmos battery and check that prolem
Jan 29, 2009 | Compaq Deskpro EN FC 6450+ Model 10000...
Compaq Deskpro - video problem?
i got ur answer that is once remove the ram and clean it and keep again. Maximum it works other wise check the load is comg frm smps or not 5v to mother board r not
Jan 12, 2009 | Dell Optiplex GX280 (99301) Motherboard
Compaq deskpro en model 0688h
More Ram,more RAM more RAM!!! Computer recyclers have it.
Jan 16, 2008 | Compaq Deskpro EN 6350 Model 4300...
CD BURNER REMOVALE
in first step you should bee off the power cable from plug
now you can open your case cover and remove the cd burner,
open the case cover for anther pc or pc what you wont install cd burner,
install the cd burner and close cover case'
play your new pc with cd burner .don't forget power cable and data cable for cd burner (it's same the old one)
Dec 16, 2007 | Compaq Deskpro 2000 PC Desktop
Compaq Deskpro EN PC Desktop Logo
404 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
