Question about Sakar 62150 Keyboard
Wireless keyboard i changed the batteries in my keyboard and mouse now it will not pick up the keyboard i have miss placed the manual can anyone help me get my keyboard up and working again?
    Scholar:
  • 148 Answers
Wireless keyboards and in wireless mouse devices, use the following methods in the order that they appear in.
Method 1: Try different ports loadTOCNode(2, 'moreinformation'); Warning If you have to change a PS/2 connection, shut off the computer, make the changes, and then restart the computer. Do not plug a PS/2 device in the PS/2 port while the computer is running.
To determine whether the problem is related to the ports on the computer, use only the two cables that are included with the wireless desktop receiver, or the single cable that is included with a mouse.
USB keyboard and USB mouse loadTOCNode(3, 'moreinformation'); If the USB cable is currently connected to a USB hub, disconnect the device from the hub, and then connect it to a USB port on the computer. If your device is already connected to a USB port on the computer, try to connect the device to a different USB port if one is available.
Note Only one USB connection to the computer is required, even if your device has two USB plugs. If the problem persists, disconnect other USB devices and connect only the USB plug from the receiver to a USB port on the computer.
PS/2 devices loadTOCNode(3, 'moreinformation'); If your devices are connected to PS/2 ports on the computer, verify that you have the following configurations: • Verify that the USB plug for your mouse is connected to the green USB-to-PS/2 adapter and that this adapter is plugged in the mouse PS/2 port on the computer. The mouse PS/2 port on the computer may also be green. If you are not sure which PS/2 port is the mouse PS/2 port, see the documentation that came with the computer. • Verify that the USB plug for the keyboard is connected to the purple USB-to-PS/2 adapter and that this adapter is plugged in the keyboard PS/2 port on the computer. The keyboard PS/2 port on the computer may also be purple. If you are not sure which PS/2 port is the keyboard PS/2 port, see the documentation that came with the computer.If you have to change your configuration, shut off the computer, make the changes, and then restart the computer. If your mouse or keyboard has both USB and PS/2 connections, try using the other connection.
PS/2 keyboard and USB mouse loadTOCNode(3, 'moreinformation'); Verify that the USB mouse is plugged in a USB port on the computer and that the purple keyboard PS/2 plug is connected to the purple PS/2 port on the computer. If you have to change the PS/2 connection, shut off the computer, make the changes, and then restart the computer.
Method 2: Install fresh batteries loadTOCNode(2, 'moreinformation'); Both the wireless keyboard and the wireless mouse rely on AA alkaline batteries for power. If the problem persists, install a fresh set of batteries in the device that you are experiencing problems with.
Method 3: Resynchronize your device to the receiver loadTOCNode(2, 'moreinformation'); To resynchronize the mouse or keyboard to the receiver, follow these steps.
Note When you synchronize the mouse or the keyboard with the receiver, put the device near the receiver and put other wireless keyboards and mouse more than six feet away. 1. Press the button on the receiver, and then verify that the light on the receiver starts to blink. 2. If a dialog box appears on the screen in several seconds, follow the instructions that appear on the screen.
Otherwise, go to the next step. 3. Press and release the Connect Channel button on the bottom of your mouse or keyboard. 4. Check the green light on the receiver. A steady green light means the synchronization was successful. If the problem persists, try steps 1 through 4 again.
Clean the mouse lens loadTOCNode(2, 'moreinformation'); This problem may occur if you are using an optical or laser mouse and the lens on the mouse is dirty. To clean the lens of an optical or laser mouse, follow these steps: 1. Use a dry cloth to clean the bottom surface of the mouse. 2. Check to see whether the mouse functions correctly. 3. If you see dust on the bottom of the mouse, use a can of pressurized de-ionized air to blow away the dust on the lens. 4. Check to see whether the mouse functions correctly. 5. If the pressurized air canister is not available, blow dry air on the lenses by using your mouth one or two times. 6. Check to see whether the mouse functions correctly. 7. If these steps do not resolve the problem, use a cotton bud to clean the lens without scratching it.
Posted on Mar 02, 2008
Is there a battery in the mouse that I need to change?
The wireless mouse is a great piece of peripheral hardware that enhances the ease of clicking for dragging and dropping, copying and pasting--even scrolling A mouse with a wire will most likely always be charged, whereas a wireless mouse is battery operated; therefore, the battery will need to be changed on occasion. It's a simple process if you have the tools you need. ----- Flip your mouse over and remove the battery cover. Gently pull it up and set it down in a safe place. 8ab1230.jpg
Carefully remove each battery---- Insert the new AA batteries into the mouse. Make sure the positive and negative connectors are lined up correctly. Do not force or jam your batteries into place.----- Place the battery cover over the opening and click it into place. Flip your mouse over. If your particular mouse has a charged or not-charged display light, make sure it is showing full strength.----
This will help. Thanks please keep updated. please do rate the solution positively .thank you for using fixya--.
Mar 20, 2010 | Dell Wireless Keyboard Optical Mouse w0147
Toshiba Wireless Mouse (PA3706E) not working
just install new battery and press the conncet button in mouse .
Dec 18, 2009 | Toshiba Wireless Mouse PA3205U-1ETC
98811 mouse wont work
The GE 98811 ergonomic Wireless mini mouse is a HID compliant mouse you will need to change the setting to use this mouse. This is what I would suggest:
Go to device manager
Go to the unknown device
Manually pick a driver
Mice and other pointing devices
***Change to a HID compliant mouse***
Then press the connect buttons on both pieces of hardware and the mouse should work
Hope this helps, it took me over two hours to get the mouse working. Very frustrating!!
Sep 03, 2009 | GE Wireless Optical Mouse
My computer stopped recognizing my wireless keyboard & mouse. Says it's missing a driver or that the device is malfunctioning. Don't think it's a battery prob. Do I need a new driver?...
Uninstall the Keyboard driver.
Unplug the Logitech keyboard.
Restart the computer.
Plug the Logitech keyboard back into the computer.
Windows should recognise the keyboard and/or the mouse.
Place Logitech setup disk in drive.
Reload the drivers...
The drivers sometimes corrupt themselves..
You might download the latest drivers for your keyboard/mouse.
Jun 28, 2009 | Logitech Wireless Access Duo Optical...
Wireless keyboard and mouse freeze more and more frequently
Try pressing the green button on the mouse receiver and the green button on the bottom of the mouse. I believe that they serve to connect to each other. Mine went out when I changed the battery. Sometimes I think that my computer acts funny when the wireless parts pick up some stray signals from the neighbors. At least that happened to my garage door when the neighbors installed some new wireless computer equipment!!
Mar 30, 2009 | Dell Wireless Keyboard Optical Mouse w0147
HP wireless optical mobile mouse
Try changing the batteries or charging if it is rechargeable or try re-syncing using the syn button.
Nov 26, 2008 | HP Wireless Optical Mouse
Wireless mouse not picking up
Normal 0 Try disconnecting the Mouse Receiver from the USB port and reinstall the CD software program. When the program asks you to connect the Mouse Receiver to the USB port, do so and it should work.
Hope this helps. Bud
Feb 25, 2008 | Fellowes Manufacturing 99666...
Wireless mouse won't work on hp multimedia cordless keyboard and mouse
Try changing the batteries in the mouse and then press the little sync button of both the mouse and the wireless receiver.
Nov 09, 2007 | HP Multimedia Cordless Keyboard/Mouse...
Sakar 62150 Keyboard Logo
474 people viewed this question
Top Sakar Computers & Internet Experts
micky dee
Ravi
Are you a Sakar Computer and Internet Expert? Answer questions, earn points and help others
