Question about Intel D865GBF Motherboard
PC RESTART ANY TIME
DEAR,
I have a pc which is assembled with intel mother board & P4 processor. I am facing the problem of pc restart any time. Previously this problem was existing many times when I start the pc. Then I have complaint the vender & as per my complaint vender has replaced the mother board & done the some other activities. Problem has solved but now pc is restart one time.
Can you help me to sort out this problem?
With regards,
Baljinder Pal Singh
    Scholar:
  • 148 Answers
Important Note: Only a computer professional should perform assembling, disassembling, upgrading and troubleshooting computers since the electronic devices may cause serious damage to the installer, the system, or its components if it is done improperly. Before attempting to disassemble or assemble computers, install components in a computer or troubleshoot computers, carefully review the documentation specific for the computer and its related components. Lastly, make sure to follow Electrostatic Discharge (ESD) procedures.
  • Determine if the system worked before. Determine if there have been any recent changes. Often if a recent change is been made, the recent change is the cause of the problem.
  • Check to see if your system feels warm and check the processor for overheating. NOTE: Use extreme caution when checking for heat, since you can be easily burned.
  • Make sure that the power supply fan is running properly and any other external case fans are running properly. Make sure that the air intakes for the external fans are unobstructed and have at least several inches away from walls and other items.
  • Make sure the fans on the processor are connected properly and running.
  • Make sure that the thermal interface material or the thermal grease is applied properly.
  • Disable thermal measurements and power saving features in the BIOS setup program.
  • Update the system BIOS to the newest version. In addition, check to see if your system has a firmware that could also be updated to the newest version. Refer to your motherboard documentation.
  • Check the BIOS using the BIOS/CMOS setup utility, particularly the boot order. Make sure that your system is detecting all of the drives and make sure that the drive you are trying to boot is listed.
  • Do not overclock your system. Your system can become unreliable, may shorten the life of your PC components, may damage your PC components and may void your warranty.
  • Check the BIOS using the BIOS/CMOS setup utility, especially the RAM settings.
  • Suggest running ScanDisk to see if your hard drive has a lot of lost clusters and other anomalies. If you don't properly shutdown your computer using the Start button shutdown option, you may see some lost clusters and possible bad clusters.
  • Suggest running an updated virus checker to see if your system is affected by a virus.
  • Suggest reloading the OS, drivers or program.
  • Suggest reformatting the hard drive and reinstalling everything
  • Verify that your chassis/case and power supply is appropriate for the processor model and frequency and the motherboard you are planning to use. For Intel Pentium® processor 4 based systems, you should be using an AXT12V, SFX12V or PS3-12V power supply.
Posted on Mar 02, 2008
I have installed windows 7 on my PC.I have DG43NB mother board with core2quad processor.I am facing very irritating problems. 1: after some time if i am not on my PC my PC goes in a standby or hibernate...
Have you checked to see if there are any pending software upgrades that have not been done or have started and not finished. A lot of the time that is the problem. Also check to see if your security is scanning and is not finished.
May 03, 2017 | Intel DG43NB Motherboard
I have assembled PC with Intel P4 boxed processor & Intel 845 GV moteher board.Now it is not not working.There is no display & PC is not booting.I refered to local technician but he is telling that...
you have to take you pc to a pc specialist who will check the problem and notify you of what has to be don whether replacements or just a small error that can be fixed.
good luck.
wonder
Oct 08, 2009 | Intel D845GBV (BOXD845GBVL) Motherboard
Pc run ok.Os ok,no Virus, Problem when turn it shutdwon it become restart
You can change the pc from the dealer where you have bought. Since you have used only 2-3 days your computer can be replaced.
May 23, 2009 | Intel Desktop Board D845WN Motherboard
I have p4 3.06 ghz processor on mother board it is written P5P800-vm/s i require VGA and sound drivers(realtek ac97 sound driver} i have i P5P800 VM motherboard and i was wondering if i can upgrade it's...
NO. you cannot install DUO to *********** board. the DUO is pinless and the P4 3.06 is pin type if you want to upgrade your PC you have to replace the mother board too.
May 18, 2009 | ASUS P5P800-VM Motherboard
Restart my computer at rendering time.
GO ON LINE TO THE FOLLOWING SITES
WWW.X86.ORG
WWW.X86.COM
WWW.CSIF.CS.UCDAVIS.EDU/-WEN/INTEL.HTML
WWW.MOTHERBOARD.ORG
WWW.TOMSHARDWARE.COM
GO ON LINE OR ADDRESS BAR TYPE
INTEL SE7520JR2 MOTHERBOARD DG33 ERRORS
OR
INTEL MOTHERBOARDS DG33 RENDERING TIME
ENTER
SEE IF OTHERS ARE HAVING THE SAME PROBLEMS, IF IT IS BOIS, CURCIUTRY ERROR
OR RECALL ON MOTHERBOARDS.
ROD
Feb 09, 2009 | Intel SE7520JR2 Motherboard
MY system is not read OS from CD drive
is the bios set to boot from the cd drive 1st?
Jan 20, 2009 | Intel D845GVSR Motherboard
Windows Xp sp 2 installation problem
check the cpu fan or remove it then put it again
Nov 08, 2008 | Intel D845WN (KD845WNPAK10) Motherboard
848P-A mother Board P4FSB 800 INTEL CPU PENTIUM 4 PROCESSOR
If by "Reboot" you mean turn-off and restart, your CMOS battery is probably bad and not able to supply enough power to the bios to retain your time settings. Replace the CMOS battery.
Many web sites require the proper date and time on the surfer's PC. For example, Microsoft Update will not allow downloads if the surfer's PC date and time are far out of syncwith the real time. Ironically, even the Update Time function on the surfer's PC will not work if it is too far out of sync.
Oct 31, 2008 | VIA ECS PM800-M2 PM800 P4FSB 800 Supports...
UPGRADING P 3 PC
THE SE440BX2 MOTHER BOARD CAN SUPPORT P3,P2 PROCESSORS(P3 850 MHZ)....,BUT NOT P4 AND HIGHER VERSIONS...THIS MOTHER BOARD SUPPORTS UPTO 768 MB OF RAM,NOT MORE THAN THIS...
Aug 19, 2008 | Intel Pentium 3 , 450 MHz Pentium III...
PC Freezing !
Update BIOS to P25 http://downloadcenter.intel.com/Detail_Desc.aspx?agr=N&Inst=Yes&ProductID=948&DwnldID=10130&strOSs=44&OSFullName=Windows*%20XP%20Professional&lang=eng
Reset BIOS to default settings.
Check CPU Temperature, Prescott CPUs run hot.
If board is under 3 years old and was a retail box package, it will be under warranty, contact Intel.
Jun 29, 2008 | Intel Motherboard
Intel D865GBF Motherboard Logo
90 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
