Question about Car Audio & Video
ALPINE MDA-W966J I have this unit but i'm not too sure on a couple of the wires. Do you know where i can find a wiring diagram? I really appreciate all your help! Thanks, Dwayne
  • 175 Answers
SOURCE: Asko W6021 front load washer door stuck!
there is a little red loop that you can pull on to release the door manually. it is located behind the little door on the lower left of the machine. Pop that door open and take the phillips head screw out of the lever hen pull on it and the door will open.
Posted on Feb 24, 2007
  • 156 Answers
SOURCE: wiring diagram
Red: voltage source controlled by the ignition key Yellow: constant voltage source Black: ground Blue: power antenna activation wire (if equipped) Blue/white: amplifier activation wire (if equipped)
Posted on Jun 06, 2007
  • 626 Answers
Users Manual is here;
Wiring info is on Page 23.
Best of Luck.
Posted on Nov 11, 2007
  • 359 Answers
SOURCE: stero wire diagram/ 1995 dodge Intepid
use a test light with ignition off when u find power connect it to yellow(memory) then on acc when u find power conect red connect black to earth blue is optional (power antenna) find the speaker wires colors at the back of each speaker and connect the two of the same color to each speaker striped wire + no stripe - hope this helps
Posted on May 26, 2008
  • 14 Answers
SOURCE: 917.271021 Wiring Diagram
here's one, not very good. Let me know if this doesn't help and I can clarify the locations of numbers. 4x4papa
Posted on Nov 15, 2008
Looking for wiring diagram for a duo therm by dometic rooftop air conditiner. I have one small wire unhooked and am not sure where it connects.
There are several models out there. Here are a couple of manuals with wiring diagrams that I believe will help you regardless of the model number. However, if they are unable to help you, let me know the exact model number and we'll search for the wiring diagram. :-)
Link #1
Link #2
May 19, 2010 | Dometic Rooftop RV Air Conditioner
Wiring alpine amp and sub
To wire your 4 ohm dual voicecoil to a 2 ohm mono load - all positives to + on amp.... all negatives to - on amp.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Dec 29, 2009 | Alpine MRP-M500 Car Audio Amplifier
Wiring diagram
Well for a wiring diagram there isnt one. Really all you need to know is how to wire it properly. You can put it up to 8 ohms and all the way down o 2 ohms and possible 1 ohm. Check this website:
Dec 27, 2009 | Alpine SWS-1043D Car Subwoofer
Need wiring diagram ktp445 to be installed on a NON alpine unit
please, I need wiring diagram for a alpine ktp445.... to be installed on a NON alpine unit.
Dec 06, 2009 | Alpine KTP-445 Car Amp
Wire diagram
The top half of this pdf is for a factory stereo wiring diagram for models up to 1990.
Let me know if you need extra assistance.
Mar 20, 2009 | Alpine Car Audio & Video
Car amp wont turn on
I'll assume that you've checked the amplifier's on-board fuses.
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp (not on the point where the ground wire connected to the vehicle) and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
Jul 29, 2008 | Alpine PDX-1.1000 1000W x 1 Car Amplifier...
Amp problems
The main thing that comes to mind is whether you've checked the in-line fuse on the positive wire. Most amp installations are supposed to have a fuse within 1ft of the battery terminal for just such a reason. Next, if you have a voltmeter of some kind (or know someone who does), check to see if you still have 11VDC-14VDC at the power terminals of the amp. If you do, then check the remote turn-on lead (which is supposed to connect to either your head unit or the ignition). If my memory serves, the remote wire should be high (about 12V) when the amp is being told to turn on and low (less than 2V) when it's being told to turn off.
About scheme
Try another repair shop. We repair stereos everyday without schematics.
Sep 08, 2007 | Alpine MDA-7755
Car Audio & Video Logo
531 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
