Question about LG WM1812C Front Load Washer
LG Front Loader WD-8074FHB
Hi There,
Our LG Intello Front Loader accidentally got door locked or child locked and we are unable to open the door. Do you have any idea how to open it. We have tried everything and do not have a manual
Thank You
  • nkostal Mar 02, 2008
    Thanks very much. It's open!!
  • lauriermclea
    lauriermclea Jan 12, 2013
    Ours' had a clogged drain filter, so it could not drain properly. The solution was to turn the machine off and drain the whole tub through the drain hose on the front bottom of the machine. This ended up being about 5 gallons of water or more. Once it was drained, I removed the filter and found it full of fuzzy debris and I cleaned that and put it all back together, then turned on the machine and set it to rinse and drain cycle. It finally was able to unlock and then relock itself and run the drain cycle and spin. I think I'm back in business, hopefully, once the cycle completes.
    Sergeant:
  • 351 Answers
Sometimes you just have to force the door but first try hitting the machine near the door lock sometimes this helps the door interlock may be stuck in the closed position
Posted on Mar 02, 2008
Hi you need to turn off at power point for 5 min then turn back on as it clears the memory.
Posted on Nov 03, 2011
Press temp and time delay buttons simultaneously to turn on & off child lock.
Posted on May 23, 2008
  • Oluchi okeke Jun 09, 2016
    Plz what side is the Time delay botton? And How can i unlock it , bcz my Washing is bringing so many sounds at the same Time when trying to set it for Washing.
Hi my LG 7.5 kg (10165fu)front loader washer has just stopped functioning. It shows on screen a big "CL".What do i do? Pls help. Griffiths
CL means that your washing machine's CHILD LOCK is ON. You can find two buttons Temp and Options in the panel. Turn ON the machine, press these two buttons together for 3 seconds and thats it. It might have a little kids face above a lock key, inbetween the wash and rinse buttons, hold these for 3/5 seconds and it should work
Dec 03, 2016 | LG Washing Machines
My lg intello front loader washing machine door is stuck the machine will not wok as the de keep flashing any ideas how i can open door to get clothes out
put outlet hose on ground drain water out ,then between the handle and the manchine theres a hook put something there to pull it towards u and it will open but its not easy , but is for me
Jan 17, 2013 | LG WD-1080FD Front Load Washer
LG frontloader WD-1238c door locked
Unfortunately it as to be open from top take power off open top normally two screws at the back slide cover off look inside front loader for door catch unscrew and done open door replace with new one same model connect wires as disconnected take pics before disconnect screw it back on done.hope it helps you
Jan 10, 2018 | Washing Machines
My lg intello wd 8074fhb washer will be in the middle of wash cycle and an error message comes up se ..Can you tell me what this error message means..
LG's 'SE' means 'sensor error'. Sorry but you will need a repair visit I fear ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Jun 12, 2011 | Washing Machines
Can you provide a link to a LG Front Loader WD-8074FHB service manual
checked this site for your LG washing machines..
http://www.manualsonline.com/ex/thread/view/idThread/1035082
Mar 05, 2011 | LG Washing Machines
LG-INTELLO WASHER 7kg WD-8074FHB
"de" means door is open you have to close the door titly then press the start bottom or check door switch if its out of order or not with digital multi meter.
Apr 10, 2010 | LG WM1812C Front Load Washer
Lg intello washer error code cl
fault code "cl".you have your child lock function on.push the two child lock buttons together on the control panel,hold them for a few seconds till the "cl" icon dissapears
Jan 29, 2009 | LG WM-2277HW Front Load Washer
Error display "CL" - what to do?
THe child lock is on. Mine came on for some random reason. On my LG front loader there is a button on the right hand side with a cartoony picture of a child and a padlock. Press this.
Jul 04, 2008 | LG WD-1280FHD Front Load Washer
LG WM1812C Front Load Washer Logo
1,562 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
