Question about Magellan RoadMate 2000 GPS Receiver
Magellan roadmate 2000
Turned on unit. Small window opened up and said low battery and going to sleep mode. I plugged it into outlet to charge. I came back 8 hrs later. Turned on unit, but unit screen only showed a very low light glow.
Thank you for your time.
Jim
I Reset the unit by switching reset switch on and off.
The switch is on left side of my gps.
Posted on Mar 03, 2008
My magellan Roadmate 5220-LM powers on but will not go past the first screen. I have tried to use the reset button but it still will not work
Hello Liz, You may have two problems. If your unit is several years old, the battery may need to be replaced. First charge the battery overnight. To get the screen unfrozen , you need to remove the screws on the back, open the case, and unplug the white battery connection . Reconnect the battery connection after a few seconds. If this works, it is usually a temporary fix . Either your battery does not hold a charge or your charger connection is poor at best and can not deliver a full charge to the battery. It could be both.
Mar 17, 2014 | Magellan RoadMate 5220-LM GPS Vehicle...
Tip
Problem charging MAGELLAN GPS.
I found there are select 120v AC adapters that will work on Magellan GPS. When a working 120v or 12v adapter to mini USB adapter is plugged into the unit, the battery bars will be 'scrolling' and therefore charging.
When your adapter, or even USB cable from your computer, is plugged into the GPS unit, and the battery goes to FULL, it is NOT CHARGING. The battery bars must be SCROLLING for the unit to charge. In this case, get a different adapter until it works.
This was tested on a Magellan 1412, and may apply to other Magellan GPS.
on Dec 28, 2008 | Magellan RoadMate 1412 Car GPS Receiver
Free map update fpr magellan roadmate 2000
There is no longer any map updates or accessories available for the Roadmate 2000.
Magellan has obsoleted this unit and no longer has support for it or any accessories.
I talked to them online as well as on the phone.
So basically when you get the message on your Magellan Roadmate 2000 that you maps are out of date and your unit no longer functions correctly because of this, there is no fix and the unit is now a useless paper weight.
And there are no sites online that has any software to upgrade maps for this unit.
So keep your plugs because they work on other units, but take a baseball bat and hit a home run with your roadmate 2000.
Thats all its worth now.
Oct 31, 2012 | Magellan GPS
It is shutting down while we are using it. it is plugged into the lighter outlet and has power, does not show a low battery
try a hard reset first using a paper clip, innsert it in the little pin hole on the side to reset the unit. if that fails, get the 3.12 update off the magellan site..you must register the unit with magellan before you can download the update.
Jul 29, 2009 | Magellan RoadMate 1430 GPS Receiver
My Magellan Roadmate 1412 does not seem to charge. I cannot use the device unless it is plugged into a wall outlet or car charger. Does this model not have a battery? Please help. Thanks!
does it appear to be charging when its plugged in....go to the system folder then the power option..the power bar should be moving left to right...if its all green and its not scrolling left to rigth , its receiving power but not charging. possibly because the charge port is damaged or the battery is either shot or disconnected.
Jun 24, 2009 | Magellan RoadMate 1412 Car GPS Receiver
My Magellan Roadmate won't turn on
THere is nothing wrong with it. On the left side of the unit pull up the rubber cover. You will see a very small switch and a button above it or below it.
With a a pen slid the switch, and push the re set button. Then slid the switch back. and turn on the unit the way you normally do. If it doesn't light up
either you did it wrong, the unit is discharged, or there is something wrong with it. If nothing works call Magellan and if it is still under service, they will help you. Good luck to you.
Dec 27, 2008 | Magellan RoadMate 2000 GPS Receiver
Battery question
Oct 08, 2008 | Magellan RoadMate 1412 Car GPS Receiver
Your best bet is to contact Magellan directly. Their website is not the easiest place I've ever navigated. I did not see a specific listing for the Roadmate 2000, but when I queried them about upgrades for your unit, the response was Roadmate 2000/2200T. Manuals are available, but again nothing was noted about supporting the 2000.
I've provided their phone # is below. Good luck.
800-707-9971
Feb 29, 2008 | Magellan RoadMate 2000 GPS Receiver
Magellan RoadMate 2000 GPS Receiver Logo
105 people viewed this question
Top Magellan GPS Experts
Marvin
Marvin
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
