Question about Janome Harmony 2041
Re Janome 2041
The needle still wont go up and down
  • 1 more comment
  • viela Mar 02, 2008
    Thanks for the advice. I cannot move the needle bar up or down manually....it seems to be stuck. When i try to turn the balance wheel- it still wont move.
  • viela Mar 05, 2008
    Trifect7
    Thanks so much you are a genius... I followed your direction and discovered a piece of thread and once removed the balance wheel does turn and the machince is now operational.
    With Best wishes
    Viela
  • Steve Duddy
    Steve Duddy May 11, 2010
    Can you move the needle bar (where the needle goes) up and down manually? Or does it seem to be stuck? What happens when you turn the balance wheel?
  • 57 Answers
Okay, so there is a jam. Take out the bobbin case and the hook. Remove the bobbin from the bobbin case if you haven't already.
Try and turn balance wheel now. if it is still stuck than you have a pretty big problem. Chances are the timing has been thrown so far that something is bumping something else and keeping it from revolving. Repair probably required.
If you're really lucky and the balance wheel does turn do this:
Clean bobbin case and hook gently with a tooth bush or some such. Make sure the bobbin doesn't have a bit of needle jammed in it. Examine the bobbin case and hook, looking for any damage. There has to be something preventing the normal revolutions of the machine from happening.
Good Luck and if this was helpful please vote for me. Thanks
Posted on Mar 02, 2008
My needle wont go all the way down
check to see if the needle is bent or if you have it in back words take the needle out and make sure the arm goes all the way down when you turn it by hand if not take the bobbin out then try again if it goes down there be something wrong with the bobbin good luck
Jun 05, 2016 | Sewing Machines
Machine stops when needle is moved up or down
Five Common Sewing Machine Mistakes + How to Fix Them
www.tillyandthebuttons.com/.../five-common-sewing-machine-mistakes-...
Sep 23, 2014 - Sometimes the needle will push the edge of the fabric down into the ....also helps stop that problem, too .... makes for very frustrating sewing .... handwheel wont turn and so the needle doesn't move up and down, please help.
Trouble Shooting a Sewing Machine - YouTube
? 2:35
https://www.youtube.com/watch?v=A2QqmEh5qcw
May 25, 2009 - Uploaded by MonkeySee
my machine needle won't go up and down on a white sewing machine. ... won't go up and down it'll go but then it will stop moving after i push ...
Nov 30, 2015 | Sewing Machines
My needle wont thread!
hi, i need the make and model please ?
Regards
www.electronicrepairs.co
Dec 28, 2013 | Baby Lock Ellure
The needle keeps breaking and the thread wont stay threaded. the needle is not going straight up and down but it goes down and gets stuck almost
usually a 3-5 inch thread tail is helpful to keep the thread from coming out of the needle & pull the thread(top & bottom) behind the needle
flat side of needle goes to the back of machine
some needles & thread are not compatable----try this
Cut 6-8 inch piece of thread of the spool you are going to use for your project
Take the needle you are going to use for the project
& insert the thread thru the eye of the needle
& lift one end of the thread to a 45 degree angle
& if the needle is the right size for the thread it will slide down the thread
But if the needle hangs on the thread you need one size larger needle for the thread
on some machines the presser foot can't do a zig zag stitch
Oct 25, 2010 | Singer 3116 Simple
Needle wont go up and down wont stich
Rethread your machine, I think that your thread is caught somewhere, If you need help call Euro Pro customer service
Aug 24, 2010 | Euro-Pro 9120 Computerized Sewing Machine
When drawing thread up from the shuttle needle wont go down
Sounds like your hook to needle timing is off. When you sew through thick materials, a lot of machines have issues where the needle sticks in the fabric but all the internal parts shift and this causes the hook to needle timing to go out. The begging signs of this is skipping stitches. You will have to have you local independent sewing store do this adjustment for you
Hope that helps :)
Chris
Jun 05, 2010 | Brother XL-2230 Mechanical Sewing Machine
Needle wont move up and down.
Check the settings for bobbin winding to be sure they are not activated.
May 08, 2010 | Brother LS-2125 Mechanical Sewing Machine
Janome mylock 634D overlocker
this very same thing happened to my flat machine turned out to be a piec of material jammed in the workings also wrong oil used or it might be thread jammed try and see
Feb 25, 2009 | Janome MyLock 634D Mechanical Sewing...
Janome Harmony 2041 Logo
321 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
