Question about Philips Magnavox 27MS343S 27" TV
Model 27mt5005d37 magnavox
Tv turns on but only have 3\4 picture 1\4 of tv at top has red white lines
  • Son-In-Law1 Jun 03, 2008
    It sounds somewhat similar. The top of the picture starts down maybe 3" for the top of the screen. It seems to overlap at the top like the image is folded over. This can look like lighter and darker lines of whatever is on the screen. If the top of someone's head is in this area it folds over and is seen upside down and distorted on top of the ok portion of their head. This issue started gradually as just a brighter line at the top but has progressed to this. I've had the TV for about 1 and a half years. What is the standard warranty on it? I've gone through the various menu items for the TV but saw nothing that would address something like this. I've tried unplugging the set for over a minute and then plugging it back in again to see if it would reset anything.
  • 1duckplucker Oct 20, 2008
    the problem i have is pretty well described in danters problem . however my tv is a magnavox model 27mt3305-17 chassis L03.iuaa -- thank you !!!!!
You have 3 or 4 capacitors in the video section that are bad, 2.2uf , 4.7uf, 3.3uf and maybe a 10uf all at different V's.
Best to take it to a reliable repair facility where they know what section to look in. Be safe as the tube can knock the LIFE out of you if you don't know what you are doing.
ECSC
Posted on Mar 28, 2009
No solution, but looking for one
Posted on Nov 02, 2008
  • 24 Answers
I believed Tv has a vertical resolution problem. Some components is fauly and needed to change.Well refer to your nearest repair shop or agent.
Regards
alan
Posted on Mar 02, 2008
How do I connect my Magnavox DVD/VHS player to my Element Flat screen TV?
Do you have a newer TV or a older one lets start with a newer models does your tv have 3 or more jacks on the back or front you should see a RED, YELLOW and WHITE if you have a HDTV you should see more. (LETS HOOK UP) Did your DVD/VCR come with a cables if not you will need to buy at least 2 they are called RCA cables Lets start with the dvd/vcr combo on the back you should see a (LINE OUT) this is where playback or your picture and sound come out. On the back of the TV you should see a (LINE IN) this is where you plug it in to. RED goes to RED, WHITE goes to WHITE and YELLOW goes to YELLOW. To Record you will need to hook up the line in on your combo and the line out to your tv. ( IF YOU HAVE AN OLDER T.V WITH NONE OF THOSE JACKS ) you will need to buy a RF- MODULATOR the are cheap it is a box that let you hook a cable wire to a little box and the RCA jacks to you combo and you will turn your tv to channel 3 or 4
Jul 15, 2009 | Philips Magnavox DVD/VCR Dual Player
My 60" Magnavox projection tv has verticle double vision giving a red line across the top of eveything. All titles and captions are red over white.
hi
this type of problem occurs because of 3 issues..
1.colour wheel
2.jungle 45e3 ic on D- board
3.cathode ray tube...
check them...
thank u..///please rate it
Jul 04, 2009 | Philips Magnavox 9P6034C 60" Rear...
Help Me!
My tv has several video inputs & this is the way I did mine. I ran the red,white & yellow cable from the dish box to "video 1" on the tv. For the Magnavox I ran a coax cable from the dish receiver out to the rear of the Magnavox & the red,white,yellow from the magnavox to the tv "video 2". Check the dish box to see if the switch in the back reads channel 3 or 4 & set your magnavox to the same. Make sure in the setup you have it set to rear connections. If you have picture on both video settings on the tv everything is golden. Hope this helps.
Mar 24, 2009 | Philips Magnavox MWR10D6 DVD Recorder
Not able to adjust red convergence on top or bottom
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Dec 24, 2008 | Hitachi Director's Series 65XWX20B 65"...
Hazy, washed out picture on Magnavox 51mp6100d
Remove back see if you can get to tubes top lenses clean all 3 from dirt/dust/ After cleaning off lenses there is a black control box has 3 controls on top 3 on bottom these are to adjust each tube R-G-B Tubes screen/ focus adjust one tube at a time--- Like to adjust red turn g,b.screen drive off turn red up adjust focus to a clear picture ,then green same and blue If you turn screen up to much it will either shut off or you will see Drive lines adjust back down.OK after doing this turn color off in menu adjust all 3 screen controls untill you have Black and white picture try to adjust as close as you can to get bl/wt picture when that is done now turn color on and you should have alot better picture.
Dec 19, 2008 | Televison & Video
Rear screen projection tv
Projection TV sets have two very common problems listed below.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jun 30, 2008 | Samsung HCL4715W 47" Rear Projection...
White lines
These are retrace lines. This may be a fault in the blanking circuits. On some occasions a weak CRT can also cause blanking lines to show.
This is something you would not be able to service yourself. I would suggest to have an estimate done on the TV set for you to decide if it should be serviced or not.
Jerry G.
Apr 07, 2008 | Philips Magnavox 27MS343S 27" TV
Philps TV problem
When I turn the TV on, I get a horizontal line across the screen approx 1/3 from the top. My TV make is Diamond and is approx 6 yrs old
Mar 14, 2008 | Philips Magnavox 27MS343S 27" TV
Audio out problem (magnavox MWD200G)
yellow to yellow that is video and that is ok.
red and white are the audio chanels left and rigt try to change it and your soun will be ok
Feb 07, 2008 | Philips Magnavox MWD200G DVD Player
Philips Magnavox 27MS343S 27" TV Logo
71 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
