Question about HP Pavilion dv2000t 14.1" Notebook Laptop PC (Intel Core 2 Duo T5500 1.66 GHz, 1GB RAM, 100GB HDD, D... PC Notebook
Cant able to open windows media center and quick play from the remote control
Hello. i have a hp pavillion 2000. i cant open the windows media center and quick play from the remote control but after opening the programs, i can operate them through remote without any problem.
  • Anonymous Mar 04, 2008
    dfdf
  • moraezinho Jan 27, 2009
    I have the same problem. I cant open Windows Media Center and Quick Play with HP remote control. can someone help me?
    Genius:
  • 1,226 Answers
Hello!
the ultimate solution of your problem is to reinstall the windows operating system of your system. I am sure this will resolve the issues.
After install installing the OS, you should install all the drivers.
May this help!
best regards, melnavz
Posted on Mar 02, 2008
  • Emelio Navaja
    Emelio Navaja Mar 05, 2008
    Los los nimo! dili ka balo.
I need a user manual for HP P N 5069 8344
The HP 5069-8344 is a remote control that came with some HP Media Center PCs. A quick guide to the buttons on the remote and its use can be found in the HP Digital Entertainment User's Guide, http://h10032.www1.hp.com/ctg/Manual/c00237784.pdf , on pages 15-16. This quick guide indicates that the full directions for use are included in the HP Media Center Software Guide. See http://h10032.www1.hp.com/ctg/Manual/c00385551.pdf for one version of this guide. Note: the software guides that I found are all for systems with Microsoft XP (Media Center). They may not apply to other versions of the MS operating system, even though Media Center was available in them (Windows 7, for example).
I hope the helps.
Apr 17, 2018 | HP Office Equipment & Supplies
HP TSGH-IR02 Remote Control how to install
This document pertains to HP Media Center computers with Windows XP, Media Center Edition.Use this document when the remote control does not work correctly with the Media Center software.Troubleshooting the remote controlUse the following items to troubleshoot when the remote control does not respond or when the remote control does not work properly. For example, when a key is pressed the selection moves all the way to the top or bottom of a list, or moves a selection many different places instead of the item you were trying to select.Before attempting these steps, make sure that PC has been updated with all of the latest Windows updates. Many updates for Media Center, like Update Rollup 1 for eHome Infrared Receiver, can be downloaded easily through the Windows Update software Tool.
Make sure that the batteries for the remote control are installed correctly and charged.Make sure that the front of the remote sensor is unobstructed, within a 45-degree range, and is less than 26 feet (8 meters) away. Disconnect all devices that use a USB connection except to the receiver, keyboard, and mouse. Restart the PC, and then try the remote again.If a pressed button repeats itself (sticks), unplug the IR receiver from its USB connection, wait one minute, and plug in the IR receiver. If the pressed buttons continue to repeat, alter the lighting conditions in the room or move the location of the IR receiver. Other remotes and HP Media Center PCs within range can also cause this issue.Try pressing the Enter key on the remote after changing a channel.If the remote control works when using the media center software, but does not work when changing the television channels, re-configure the Media Center software settings for the cable set-top box or satellite receiver
Point the remote control towards the IR receiver and press a button. A faint red light should appear on the IR receiver. If the light appears, then the problem is probably in the software that is using the remote control (most likely the configuration of the Media Center software). Close the software, restart the computer, and then re-open the software to solve this issue.
Troubleshooting the IR receiverThe IR receiver is the small device that receives the signals sent by the remote control. Use the following steps to test and reset the IR receiver.Disconnect the IR receiver from its USB port on the computer, maximize the Media Center window if it is open, and then reconnect the IR receiver. Test again.Point the remote control towards the IR receiver and press a button. A faint red light should appear on the IR receiver. If the light appears, then the problem is probably in the software that is using the IR receiver (most likely the Media Center software). Close the software, restart the computer, and then re-open the software to solve this issue.Click Start , right-click My Computer , and then select Properties .Click the Hardware tab and then click the Device Manager button.Click the plus sign next to Universal Serial Bus Controllers.If the eHome Infrared Receiver is listed under Universal Serial Bus controllers, Windows is properly detecting the IR receiver. If eHome Infrared Receiver is not in the list, or there is an exclamation mark or a question mark on the device, perform the following until eHome Infrared Receiver appears correct in Device manager:Unplug the end of the USB cable on the IR receiver from the computer and plug it into the same USB port.Plug the end of the USB cable on the IR receiver into the front USB port on the computer.Disconnect all other USB devices, leave the IR receiver plugged in, and then restart the computer. Plug in other USB devices after the IR receiver shows up in device manager.Figure 1: IR receiver listing in Device Manager
Testing the remote controlUse the following steps to check the responsiveness of the remote control:
  1. Open the Media Center software by double-clicking the Media Center icon the desktop or by pressing the green Start button on the remote control.
  2. Click Settings , and then click General .
  3. Click Check Your Remote , and then click Next .
  4. Press the numbers on your remote control. The corresponding numbers on the numbers on the screen should glow when each button is pressed. A faint red light should also glow inside the IR receiver each time a button on the remote pressed.
  5. Click My control is working properly , and then click Next . Do not click I am having problems with my remote control as this will not do anything.
  6. Click Finish after you are done.
Dec 17, 2011 | HP Computers & Internet
I have a HP Pavillion dv6000. I cant seem to play blu ray dvds on my laptop, even though it says blu ray disc on there. Can you help with this please??
Windows Media Player does not play Blu Ray discs. You need 3rd party software such Cyberlink Power DVD. Follow that link and you can download a 30 day trial.
Mar 23, 2011 | Computers & Internet
I cannot play a sound because i don't have a sound
Click on the links below if your computer has that particular operating system on it.
Microsoft Windows 2000 s.gif » Microsoft Windows XP s.gif » Microsoft Windows XP Home Edition s.gif » Microsoft Windows XP Media Center s.gif » Microsoft Windows XP Professional s.gif » Microsoft Windows XP Tablet PC Edition
Jun 06, 2010 | HP Compaq nc6000 Notebook
Remote control for windows media center doesn't work. batteries are fresh, both the computer and remote show blinking lights when buttons pressed but no other reaction. computer is an HP running mce 2005...
Check the remote control for its infrared emission. Check it with fresh batteries. Check it by pressing all the keys. You can detect the presence of infra-red emission from the remote control, using a cell-phone camera. If you wish to get more details about how to check a remote control, please visit this site. One among the posts has details about it. In some cases, the remote control might need to clean.
http://remotesearch.blogspot.com/
http://homenol.blogspot.com/
Search the site by type in this key phrase "how to test a remote control "in the "search box at the top right of the display window of the Homepage" to get the related post quickly.
https://youtu.be/wUpnETSm6_k
https://www.youtube.com/watch?v=jsSCNCW3IbQ [open and clean]
https://www.youtube.com/watch?v=Qp-l1uh-5gE [open and clean]
Oct 06, 2017 | Microsoft Remote Control for Windows Media...
How can i use rc6 remote on my computer
The remote control which ship along HP notebook works with only Windows Media Center ..... all you need to launch Windows Media Center application and use the remote to control on notebook, hope this help u.
Jul 23, 2009 | HP Pavilion dv2000t Notebook
HP Pavillion m7177a, no sound
just installed the motherboard cd of your hp pavillion
Dec 16, 2008 | HP Pavilion Media Center a1330n - AMD...
Windows vista live audio/video streaming problem.
vista doesn't come with 16 bit, it is 32 or 64 bit. use media center utility for watch live streaming. media player 11 is also capable for playing the live video. realplayer is the best tool for playing live videos
Oct 28, 2008 | Microsoft Windows Vista Ultimate Edition
Help me plz
i hv purchsed HP Pavilion tx1000 notebook pc. it was getinig vy heat due to this region pc was getting shut down. i hv given it to my near by service center. but still it is not working properly. its web cam as (HP pavilion Webcam Driver for Vista v061.001.0005- chicony) driver is also not loaded properly. when opens with net it gives error.
pls help me wht to do?
Apr 10, 2008 | Microsoft Windows Vista Ultimate Edition
HP Pavilion dv2000t 14.1" Notebook Laptop PC (Intel Core 2 Duo T5500 1.66 GHz, 1GB RAM, 100GB HDD, D... PC Notebook Logo
124 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
