Question about Samsung Super-WriteMaster SE-S164L DVD?RW Dual Layer Burner
The hard disk in drive D: is not accessible
Local Disk(D:) is not accessible Access is denied D: is not accessible, It says "D: is not accessible, Access Denied". D:/ is not accessible. Incorrect funtion. Can't write files to cd
  • 2 more comments
  • Tiffinypie Jun 07, 2008
    Im having a problem that my drive is not accessable, and cant burn files to cd, , i lost the instalation cd and my computer not recognize it
  • kyo4u Jun 30, 2008
    It can not read any kind of disc, it says please insert a disc. When i run D: into command it says, "The device is not ready", and I have no disc driver for it, can i download a driver for these. T.Y.
  • Anonymous Aug 28, 2008
    i have same problem please solve
  • Anonymous Nov 01, 2008
    I can`t run some disks,it says to insert a disk into drive d when it`s already in.Some of my disks run automatically what can i do?
My Toshiba lap top when i try and copy pictures to a disc it will not let me it says D:/is not accessable.incorrect function
I also tried downloading pictures from a cd and it would not read it though it did read a pdf file for documents on another disc
Posted on Sep 19, 2008
Check for admin privilages
Then run virus scan
or run chkdsk (check disk)
Posted on Jul 16, 2008
If access is denied, right click on the drive and set administrator rights to gain access.
Oct 10, 2015 | Computers & Internet
I cant access the d partition on my hard drive
Hi...
Do you want to access the drive d and get your files. You can not access it when you double click the drive. The drive will says access denied. To access the drive d open My Computer you can see there a address, there is and arrow there just click. Chose the drive d to open i am sure that you can open it.
Regards
PCmania
Aug 27, 2009 | Computers & Internet
In my system have c,d, e, and f drives.i can access c,d,e and but i can't access the f drive..while accessing my f drive ''f: drive is not accessible''.access denied.but it appeare in local disk manag on...
just format the drive and check . After that if the drive not opened then go to disk manager and delete that drive and again creat the drive then check
Jun 08, 2009 | Computers & Internet
Hope I can help you with your problem. If your hard drive was installed to be used as D: in your old computer then you will have to set it up to be D: in the new computer. This may be why it is not being recognized. You can do this by connecting it as a slave on the primary IDE cable.
Also you will need to check the jumper on the hard drive to make sure it is set in the slave position.
Dec 03, 2008 | Maxtor Hard Drive
"Access is Denied"
you need a file called takeownership which when run installed to the reg it gives you the option of taking ownership removing that anoying Access Denied screen.
google for it I did and it works a treat.
good luck
Jul 07, 2008 | Computers & Internet
first u have format the c:drive the problem is solved
if not u should format all over the system
Feb 20, 2008 | Computers & Internet
I recently had this problem. Whenever I clicked on any of the drives a window appeared with warning which said drive not accessible. Access is denied. Previously I thought that it is a virus which has edited my registry and is not allowing me to enter or even view my content. So I formatted the whole system but that didn't help. Now I am sharing this with you.
  1. Open My Computer. Goto Tools>Options. Goto View Tab Pane. Uncheck the last Option in the Advanced Setting which says Use simple file sharing(Recommended). Apply the setting.
  2. Open the properties window of the drive you are unable to access.Goto Security tab pane.
  3. Goto Advanced.
  4. Now click on the Owner tab pane.
  5. It's very rare that the ownership of the drive changes. But it happens once in a while.
  6. So if you are the user say Admin then select Admin(ComputerName\Administrator).
  7. Click on the box which says Replace owner on subcontainers and objects and click over Ok.
  8. Apply the changes.
  9. Now you should be able to access the drive.
Feb 18, 2008 | Samsung (SP0822N) 80 GB Hard Drive
Well this message can be two things(if not more) One of them being that the disk has security set and you wil need to change those settings if you want access to the drive the other scenario being that a program has locked the disk for exclusive access. Assuming you are using Windows XP. To check the security go to the properties of the disk then click on security(Tf the security tab isn't there, Open my computer then click Tools->Folder Options then the View Tab. Scroll to the bottom/last option then uncheck Use Simple File-Sharing press OK/Apply) Now back to Properties of the disk then Click the security tab. You'll need to try this first and tell me what's there, or if u got any error message etc. My explanation might be to long if i try to explain every possibility. regards, babb
Sep 26, 2007 | Seagate Barracuda 7200.7 40 GB Hard Drive
Samsung Super-WriteMaster SE-S164L DVD?RW Dual Layer Burner Logo
605 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
