Question about HP Color LaserJet 2600n Printer
Printing envelopes What are the correct settings for printing envelopes. I use Pagemaker 7 and what comes out on the envelope as far as location is concerned looks nothing like what appears on the screen I change the settings in the printer dialogue box to the envelope size and in Pagemaker also.
    Problem Solver:
  • 13 Answers
Try setting the page setup to 8.5x11 and adjust the margins to landscape, top and left margin approx 4". A lot of times the envelope templates are afterthoughts.
Pagemaker programmer's supervisor, "Forget that template, nobody will ever print envelopes in Pagemaker"
Hope this helps!
Posted on Mar 28, 2008
PRINT RUBS OFF
When printing envelopes ensure you set paper/media type to Envelopes, and feed via tray 1/bypass . Paper type setting sets correct fuser temp, the fuser is the hot bit at the rear that "melts" the image into the paper.
If paper type is set correctly then I recommend you change the fuser unit.
Ensure envelopes are standard type. ie you are printing on paper envelopes
Feb 11, 2008 | HP LaserJet 5p Printer
Envelope jam HP Officejet 8500
Try to print envelope through Microsoft Word
Steps:-
1) Click Tools , click Letters and Mailings and then click Envelopes and Labels .
2) Type the Delivery and Return address information.
3) Click Options .
4) On the Envelope Options tab, set the following options:-
  • Envelope size : set to match the loaded envelopes.
  • US only : if desired, select the Delivery point barcode to make it easier for mail sorting machinery to correctly route the envelope.
  • Return address : for Size 10 envelopes only, set the Return Address position .8 inch in the From left section.
5) Select the Printing Options tab and verify that the following settings are selected:
  • Select the Feed Method option that shows the envelope on the far right side with the short edge first.
  • Select Face down .
  • Examine the selected feed method image and verify that the envelope flap is on the left side of the envelope. If it is on the right, select or deselect Clockwise rotation.
6) Click OK and then click Print .
As envelop can not feed correctly every time, it depends on the weight, flap design, paper type and other factors & cause jam, To prevent those you can do.
  • Print envelopes at a higher quality setting so envelope is pulled through the unit more slowly. e.g:- Switch fast to slow mode or slow to best mode.
  • Tuck the flap inside the envelope before loading it into the printer.
Have a nice day...don't forget to rate the solution.
Feb 20, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
How do I print addresses on #10 envelopes?
    1. Click Tools on the menu bar in Microsoft Word, and then do one of the following:
    2. Word 2000: Click Envelopes and Labels .
    • Word XP: Click Letters and Mailings , and then click Envelopes and Labels .
    1. Type the Delivery and Return address information.
    2. Click Options .
    1. On the Envelope Options tab, set the following options:
    2. Envelope size : set to match the loaded envelopes.
    • S. only: if you want to, select the Delivery point barcode to make it easier for mail sorting machinery to correctly route the envelope.
    • Return address: for Size 10 envelopes only, set the Return Address position to .8 inch in the From left section.
    • Click the Printing Options tab and verify that the following settings are selected:
      • Select the Feed Method option that shows the envelope on the far right side with the short edge first. For example, in the graphic below, the fourth image shows the envelope in the correct position.
      • Examine the selected feed method image and verify that the envelope flap is on the left side of the envelope. If it is to the right, select or clear Clockwise rotation .
      • Click OK , and then click Print .
  • Jul 22, 2009 | HP Officejet 5610 All-In-One InkJet...
    Envelopes
    you sure you have the model correct???
    as far as I know Sharp DM-3551 is multi-task machine but, it is not capable of printing envelops.
    Oct 17, 2008 | Sharp DM-3551 All-In-One Printer
    Why cant i print envelopes
    Well that depends, additional info would be great.
    Here's an example:
    PRINTING ENVELOPES from Microsoft Word
    The envelope should be fed into the printer using the short side, all the way to the right, flap to the back and to the left.
    Please follow the steps below to print envelopes in Microsoft Word:
    1. Open Microsoft Word.
    2. Click on TOOLS, then ENVELOPES AND LABELS.
    3. Ensure the ENVELOPES tab is selected. Click on the OPTIONS button.
    4. Select your envelope size under ENVELOPE OPTIONS (ie: #10).
    5. Select PRINT OPTIONS.
    6. Under FEED METHOD, from the six options available select the FOURTH icon from the left. Select FACE UP.
    7. Ensure CLOCKWISE ROTATION is selected.
    8. Under ENVELOPE OPTIONS, ensure you choose the correct envelope size (ie: #10).
    9. Click OK, then PRINT.
    The envelopes should print correctly now.
    Sep 11, 2008 | Kodak Office Equipment & Supplies
    Envelope printing
    You need to insert the envelope in the manual feed area and open the exit door at the back this allows the envelope to go straight through the printer hopefully limiting creasing. Check the envelope settings in windows make sure that you are using the correct size and feed selection.
    Thanks J
    Feb 03, 2008 | Brother HL-2040 Laser Printer
    Envelopes
    CLEAN YOUR DRUM WITH COTTON SWAB. (AND BLOW OUT PRINTER IF YOUR DARING.)
    Jan 29, 2008 | Brother HL-2040 Laser Printer
    PIXMA 830 Smudges when printing envelopes
    On my MP780, be careful to select the appropriate paper type; I was getting black smudges on the left side of my envelopes until I explicitly set that my paper type was "envelope" from "plain paper".
    Another idea is to adjust the "ink drying wait time" to a higher level.
    Dec 09, 2007 | Canon PIXMA MP830 All-In-One InkJet...
    Envelopes and labeles
    Go the "print" dialog and select "settings". Ensure that the paper size, margins and orientation are not set for 8.5x11.  You did not mention the software you are using to print the envelopes/labels so this is the only guess I can give.   I have seen software that made me have to override the settings before.
    Oct 15, 2007 | Samsung ML1740 Laser Printer
    HP Color LaserJet 2600n Printer Logo
    407 people viewed this question
    Seeker5211
    Seeker5211
