Question about LG RU-52SZ51D 52" Rear Projection HDTV-Ready Television
End of lamp Life
We have the end of lamp life note coming up on out screen.Where can we purchase a new one,how much does it cost and can we install it ourselves??????
    Sergeant:
    Champion:
  • 250 Answers
Try partstore.com for a new lamp.
Posted on Mar 02, 2008
What does it mean by projection lamp is nearing end of life? how can i fix this?
Ur tv have bulb,it a lamp that project the picture.It have life spans about 1400 hundred hours.It come close to the time near the end.Change another lamp when the front LED lamp indicator flashes.
Mar 17, 2010 | Sony KDF46E2000 46" Projection HDTV
Still getting "Projection lamp is nearing end of life"
KDF46E2000 - Change Lamp Warning - Reset
Bulb is most likely OK. Original bulb in Sony TV is Philips, label on bulb usually says Philips. Sony don't make bulbs. Sony Cost is usually 1.5 times other sources. Many shopping cart operations sell condemned, reject or poor quality electronic service items because cost of return and fooling with them is excessive. This is obvious and widespread with convergence ICs and other parts.
Lamp timer needs reset. This is usually an automatic function. TV detects Increased lamp current from previous failed bulb or weak bulb condition and resets automatically. TV must be unplugged for lamp replacement for this to work. Occasionally it must be reset manually, as below:
1. TV must be in standby mode. (Power off).
2. Press the following buttons on the Remote Commander within a
second of each other:
DISPLAY Channel 5 Volume + POWER .1. Access Service Adjustment Mode and select the Service Menu that
contains the Category with the Adjustment Item you want to change.
2. To change the Category, press 2 or 5 on the Remote Commander.
Note: Pressing 2 or 5 only changes the categories within the
Service Menu displayed. To change a Category on one of the other
Service Menus, press the JUMP button until the correct Service
Menu is displayed.
3. To change the Adjustment Item, press 1 or 4 on the Remote
Commander.
4. To change the Data Value, press 3 or 6 on the Remote
Commander.
Note: To go back to the last saved Data Value, press 0 then ENT
on the Remote Commander to read the memory.
5. To save the changes, press MUTING then ENT to write into
memory.
6. To exit service mode, turn the power off by pressing POWER .
Wait 2 minutes before restarting the set to allow the fans to
completely shut down or the Service Menu will appear on the screen.
easyab
ConvergenceRepair.com
__________________
Feb 27, 2010 | Sony KDF46E2000 46" Projection HDTV
Well...it will be about 5 years now with this tv....2nd bulb....was 2,000......ends up costing 2250....and counting...id buy another tv ....but to buy a bulb is simply cheaper....short end
I can't believe a lamp would cost that much. I service LCD and DLP projectors and the cost of lamp range between 250 to 500 max. Lamps will lose alot of life if they are turned on and off alot. The mfg's rate the life of a lamp if it is turned on and remain on till they burn out. THe lamp is given a high voltage when they start. This cuts the life down. Try searching for lamps to see if you can find a cheaper price online.
Feb 09, 2010 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Eiki LC-XG110 lamp going off
Lamp is near end of life. Try reseting lamp timer and order new lamp if unit stays on
May 13, 2009 | Eiki LC-XG110 Multimedia Projector
Projection lamp nearing end of life replace lamp still coming on
Along with the instructions for the lamp installation, you should have revceived instructions on how to reset the lamp counter. If not, this operation is listed in the owner's manual. If you can not locate that manual, please confirm your model number and I will post the instructions. Since the counter has not been reset, the TV will continue to show the "error" message.
Dan
Mar 09, 2009 | Sony KDF46E2000 46" Projection HDTV
Toner life end message flashes
did you reset the toner life?
open the front cover, press the option button, on the screen will display ''reset toner life 1 yes 2 no ''
press 1 and close the cover.
toner life reseted
May 06, 2008 | Brother MFC-7820N Laser Printer
Lamp goes out after about 20 minutes of operation, does come back on after pressing the power button again, but not for long.
how old is the lamp? If old then at end of life and projector shuts down automatically to avoid damage. If new bulb reset lamp in OSD menu
Dec 27, 2007 | BenQ PB6110 Multimedia Projector
New lamp, still says "Lamp Approaching End of Life" message
Is there a light sensor in the unit?.Could be dirt/scum on glass,top and underside,reflectors or mirrors.Clean with glass cleaner. Dave,, Ulster,, Northern Ireland,,
Mar 23, 2007 | Optoma EzPro 739 Multimedia Projector
Phaser 6250 transfer roller
Hi clwest: I hope that this will help you.
Transfer Roller is at End of Life
■ Print the Supplies Usage page to verify the remaining life and Transfer
Roller install date.
■ Cycle printer power.
■ If the problem persists, follow the procedure below
Note
Look at the clear plastic window on the Transfer Roller. If toner is present in the
center of the window the Transfer Roller is at end of life and needs to be
replaced. If no toner is visible, try cleaning the CTD (ADC) Sensor.
The “Transfer Roller is at End of Life” is a warning. “Replace Transfer Roller” is
a hard stop.
Dec 15, 2006 | Xerox Phaser 6250N Printer
LG RU-52SZ51D 52" Rear Projection HDTV-Ready Television Logo
Computer Repairing
Computer Repairing
