Question about HP PSC 2355 All-In-One InkJet Printer
RED MIXED IN WITH BLACK PRINTING
When I request status of ink etc. it says not available. I just replaced the 94 cartridge. Des it need the color cartridge replaced? After replacing the black cartridge, I got a message to refer to my manual - which I can't find. Also, the printer is going through a 94 cartridge every two weeks (I print about 250 - 500 pgs/month). I have a MACG5
  • 25 Answers
Did try to download the most updated driver from hp web site
Posted on Jul 08, 2008
Even though my black cartridge is full, my black and white documents are so light they are unreadable. My color cartridges are close to being empty. Can this be the cause?
printers use all cartridges to get the correct colour even black
best get a new colour cartridge then realign the printer with a test pattern
Apr 05, 2015 | Office Equipment & Supplies
QUESTION FOR DON_FARR
whenever you print greyscale what actually happen is that the printer mixes the red, blue and yellow to give the output in gray scale. See if you mix red, blue and yellow ink in the right proportion it gives you very close to black. just try to print your greyscale with your black ink finished you will still get the same print quality as when the black has ink in it. Or find a way seal the nuzzle of the black in and print your greyscale. check what results.
Dec 12, 2009 | Canon PIXMA MP610 InkJet Printer
Red light on steady
If the ink light is on steady red, that means the black or color ink cartridge is nearly empty. Obtain a replacement black or color ink cartridge. To know which cartridge is out of ink, check the ink levels using EPSON Status Monitor 3 (Windows) or EPSON Status Monitor (Macintosh). If you just replaced the cartridges before you got the error light, that means that the replacement cartridge is not recognized by your printer. Please reseat cartridges. Then turn the printer on and off. The cartridges maybe bad also.
If the paper light is on steady red, try to reload 10-20 sheets of regular paper into your printer. When printing on CD/DVD, CD/DVD tray is not inserted in the printer. Insert the CD/DVD tray in the printer and press the paper button.Could also be that the printer has loaded more than one sheet of paper at a time. Load paper in the sheet feeder, and then press the paper button to resume printing. If the CD/DVD guide is open, close the CD/DVD guide, load paper and then press the paper button.
May 17, 2009 | Epson STYLUS R230 InkJet Photo Printer
Changing color cartridge on my epson stylus color 980 printer.
If you need to replace an ink cartridge in your printer, please follow the instructions below:
To confirm which ink cartridge requires replacement, please use the printer's control panel (there is a black ink out indicator, as well as a color ink out indicator ), or the Status Monitor in your computer.
Red light flashing - Low ink
Red light solid - Out of ink
1. Open the printer cover and press the INK (Cleaning) button for 3 seconds. The print head moves to the center and the lights flash.
2. Lift up the ink cartridge clamp. The cartridge rises up from its holder.
3. Remove the cartridge and dispose of it carefully. If ink gets on your hands, wash them with soap and water. If ink gets in your eyes, flush them immediately with water.
4. Unpack the new ink cartridge and remove the yellow tape. You must remove the yellow tape from the top of the cartridge. Do not remove the clear seal underneath the cartridge. Do not touch the green circuit board on the back of the cartridge, or you may inhibit normal operation and printing.
5. Tilt the new cartridge toward you slightly as you insert it. Lower the cartridge so that the tabs rest on the hooks. Do not place the cartridge tabs under the hooks.
6. Press down firmly on the ink cartridge clamp until it snaps in place.
7. If you need to replace the other ink cartridge, repeat steps 2 through 6 before continuing with step 8 (to move printhead over to color (if black was replaced first) press the cleaning button once).
8. Press the INK (Cleaning) button once, and close the printer cover. The printer begins charging the ink delivery system.
9. Wait until ink charging is finished (the power light stops flashing and the red error light goes out).
May 11, 2009 | Office Equipment & Supplies
I Need to Print
Sadly in a word, 'No'.
Here is the exact answer from Brother:
Your Brother machine is designed to stop ALL printing operations
(printing from the pc, printing received faxes and printing copies or reports) when any of the ink cartridges are empty. This is to ensure the life of the print head and maintain premium print quality. If the unit were to continue printing, print jobs and cleaning cycles would suction air from the dry cartridge and damage the printhead. Even if you print in black only or change the print settings to MONO or GRAYSCALE to avoid printing in color, the programmed cleaning cycles would still suction the dry cartridge, because they are programmed to clean ALL the ink nozzles.
The only way to continue printing is to replace the empty ink cartridge or cartridges.
While memory is available, black and white faxes will continue to be received into memory. If a color fax is being received, the Brother machines HANDSHAKE will request the fax be sent as black and white fax.
All faxes received into memory will automatically print once the ink cartridge is replaced.
NOTE: Brother strongly recommends that customers do not use generic ink or refill their Brother ink cartridges. Using non-Brother supplies may affect the hardware performance, print quality and machine reliability since the ink formulation in genuine Brother ink cartridges prevent smearing and clogging of the print head. The Brother limited warranty does not apply to any problem that was caused by the use of unauthorized third party ink and/or cartridges.
Nov 26, 2008 | Brother Multi-Function Center MFC-240C...
Not printing after color cartridge ran out - new black cartridge installed.
Yes, this printer has fixed printheads and must have ink in each color to prevent damage to the printheads. Even when printing black only each color is spit in the servicing area to keep the printhead unclogged.
Regards,
Bob Headrick, Microsoft MVP Printing/Imaging
Jul 18, 2008 | Epson Stylus C60 InkJet Printer
Can we print with other three Color ink cartridges when Black Ink cartridge is emptied?
hi,
as u have ran out of ink you cant print anymore... you have to replace a new ink cartridge.... this is because when u print something, the colors will get mixed to print the exact color.... even if u are printing only in black, some other colors wil get mixed to produce the black color on the paper... so u need to change the ink cartridge.... u cannot run with a blank filled ink cartridge.... and the selection of your printer is very good...
thanks and regards
agnel
Mar 19, 2008 | HP Officejet Pro L7580 All-In-One InkJet...
Black printing morphs into red after black ink cartridge installation
Your printer creates it's black by using ALL the colours together. This effectively gives a very dark purple rather than black.
It sounds like you have a colour cart that is drying up or may be struggling to get enough air into the cartridge. Make sure you have removed any tape over the vent holes if you are using compatible inks. If not then try running a couple cleaning cycles via the button panel/driver.
If you alter the settings in the driver by going into START - PRINTERS AND FAXES and then right click on your 2610 and select PROPERTIES - the changes you make in here will be set as the default settings for each print job.
Oct 17, 2007 | HP Photosmart 2610 All-In-One InkJet...
It will not print.
Hi Greenhorn, Your info is slightly conflicting - I think. As I remember the C60 has just 2 LED's: 1 - Green for Power 2 - Red for Error The third button - Cartridge exchange - has no LED Now it is a while since I looked at a C60 and my brain leaks like a sieve, but that's the way I remember it and feel free to correct me if I'm wrong. The error codes I remember are: Printer status - Indicators - Priority Power - Error Power ON condition On - Ink sequence Blink - Ink Cartridge change mode Blink - Data processing Blink - Paper Out *1 - On Paper jam condition *1 - On Ink end (Black) *1 - On -> Blink Ink level low (Black) - Blink-> Blink Ink end (Color) *1 - On -> Blink2 Ink level low (Color) - Blink-> Blink2 Ink end (Black and Color) - On -> On No Ink Cartridge (Black or Color) *1 - On Maintenance request (Ink Overflow Countererror) *1 Alt Blink Alt Blink Fatal error *1 Off On Special setting Blink2 Blink2
Mar 27, 2007 | Epson Stylus C60 InkJet Printer
HP PSC 2355 All-In-One InkJet Printer Logo
42 people viewed this question
Seeker5211
Seeker5211
