Question about Bang and Olufsen Beosound 2000 Shelf System
Besound 3 2720 Radio touch pad on top not working properley
When I touch the sound adjustment black circle area on top of the radio the channels change. When I touch the forward backward arrows for channel changes nothing happens. The touch pad seems to responding intermittantly. Radio less than 2 years old and was bought new in David Jiones store in Adelaide
  • Anonymous Nov 03, 2008
    Boesound 3 work crazy from 2 week.
    Probably is sufficient an hard reset, but exist an key sequence to reset without put to service center repair?
  • Anonymous Nov 27, 2008
    Yeagh mines touch top doesn't work but the sound ring kinda works. The thing just says LOAD.
4 Suggested Answers
otacon
  • 1944 Answers
SOURCE: 'Beocenter 9000' sounds problem
Did you check the cables including the power? Maybe some wires are overlapping causing interference/maybe some wire got damaged. Check also the outlet you are using (try another outlet).
Posted on Jan 08, 2008
SOURCE: owners manual
Below are links to the manuals. I also have this system with the original manuals.
Basically, press the "load" button to open up the CD mechanism, put a CD on the spindle, and press load again to close the CD mechanism. Press the "CD" button to start playing the CD. Page 12 in the User's Guide has instructions on configuring the radio presets.
http://www.beocollectors.com/usermanuals/beosound4000.zip
http://www.beocollectors.com/usermanuals/beosound4000guide_en.zip
Posted on Jan 10, 2009
  • 122 Answers
SOURCE: Beomaster 2400-2 jumps radio station
Check the r/c is not causing this fault.Clean around the no4 pad.A b&o dealer should still be able to look at this unit assuming all their technicians are not youngsters given its age!
Posted on Jan 22, 2010
How do i program my eton fr 800 radio to come on automatically. Thank you.
  • To get your alert radio to come on when there is a weather alert first you needed to find the right NOAH frequency to turn on automatically to.
  1. Extend the antenna fully.
  2. Turn on the radio.
  3. .Press the "WB" button at the top of the radio.
  4. Turn up the volume and press the ^ or v button to cycle through all 7 of the weather channels.
  5. WB and CH will appear at the top of the display., with 1-7 next to CH.
  6. Select the strongest channel you can hear (if you can hear more than one channel. Usually only one channel is heard).
  7. The strongest one is the broadcast from your area.
  8. Now adjust the volume you want the radio to turn on in the event of an emergency.
  • Now once you have the weather frequency set for the radio to turn on to, we need to make it able come turn on in an emergency.
  1. Press the ALERT/WB button at the top of the radio.
  2. The alert light shines in the upper left corner of the radio.
  3. The audio will disappear but the radio is still on.
  4. It will monitor Noah until an emergency occurs and at that point a siren or a voice will alert you. Then you press the WB button to hear the alert.
Regards, Tony
Apr 27, 2011 | Audio Players & Recorders
My cb on uk40 has a problem, i get a strong signal on chnl 1 but a weak on chnl 40 it is a homebase airiel do i need to lengthen or shorten the airiel or is it cause i need to earth the airiel and is ther...
To ground the antenna you want to put a ground rod in the ground and use a copper braid strap between the antenna and the ground rod. Make sure no gas pipes or lines are in the area you are driving that ground rod into the ground. Put a couple round circles in the coax in a couple places too and make sure they stay. This will stop lightning from traveling into your home should there be a strike. You need to match that antenna to your radio. You want to hook an SWR/watt meter in line with your radio to get the best consistent reading. If you get a stronger signal with your CB on lower channels then I'm led to belive your antenna is to long. You really should put an SWR/watt meter in line to be sure of the SWR. If the SWR on channel 40 is higher than that on channel 1, your antenna is too long. If the SWR on channel 1 is higher than that on channel 40, your antenna is too short. Adjust the tuning coils according to your findings.
Mar 20, 2011 | Uniden PRO510XL 40-Channels Base CB Radio
How do i replace front dash power point in my f-150 2005 model
You will need to pull the center trim panel from around the radio.
Open the ash tray, and pull on each lower corner to release the spring clips. Once the 2 bottom clips are released, work you way up to the top, there are 3 spring clips on each side ( circled in black in the picture below ).
Be cautious when you get to the top of the center trim panel, the Passenger Airbag Deactivation ( PAD ) indicator has very small AWG wire on it, and if you pull too hard they can be damaged ( circled in Green )
Once you have the released from the spring clips, you can jsut set it off to the side or remove it ( HVAC clamp over connectors and the cigar lighter circled in blue, could also have the Park Aid button and traction Control button if equiped ). The Power point can be reached from the area below the radio, tabs lock it into place.
Mar 10, 2011 | 2006 Ford F-150
LN826510 works fine w/ DVD. Air channels where
Your antenna is inadequate.
You need to upgrade to a better antenna.
Jun 12, 2010 | Televison & Video
Can't finish the game
After returning the generator part to the power plant, go to the radio tower in Lavander town, talk to the guy in the brown suit and he'll give u the radio card EXPN. after u get it, go to ur radio, take the little blinking white dot, and drag it to the center star at top. its not a item its in the pokrgear, click on the radio, then move the circle up in the middle in the center.
You can get to the PokéFlute channel on your PokéGear once you've Kanto Radio stations. Manually move the cursor to the upper area of the touch screen radio, and exit. Talk to Snorlax and it should wake up however in order to get the Kanto radio stations added to your PokéGear you need to visit the Radio Tower in Lavender Town after you have completed the Machine Part quest.
Jun 01, 2010 | Nintendo Pokemon Silver
Channel selector , part of digit burned out!like on ch. 19 it looks like 13!!
The LED channel displays on these radios are replaced as a unit. Look on eBay for replacements. They are usually available quite cheap and are rather straight forward to replace.
Jan 25, 2010 | Cobra 29 LTD CB Radio
My radio is recieving a signal from other cber's but i don't think they can hear me
Go on a channel where people are talking and when some one stops transmitting key up and say, "breaker breaker, can I have a radio check please?"
that is how you call for a radio check to see if people can hear you.
breaker breaker, or break break means kind of like, "excuse me, I would like to talk on the channel please."
If they hear you the will most likey say, "its working." or "Checks in the mail." You can then ask them after that how the radio sounds.
Also make sure your mic gain is up.
If you get no response then there may be another problem. Make sure you followed the instructions that came with the radio on how to tune your antenna for best SWR. This is important.
Dec 08, 2009 | Cobra 19 DX IV CB Radio
How do you remove the dash board of a 2000 saturn sl1 to change the radio?
The procedure to replace the radio is given below:
1.On both the right and left sides of the black housing that goes around the radio and air controls, there is a circle with another circle inside of it, push in the middle circle, this will release the clips, remove those.
2. the three buttons on top of this piece can be disconnected from it by squeezing the clips underneath.
3. remove plastic shroud.
4. there should be two bolts at the near the top, remove these.
5. slide radio out, disconnect clip, and antennae.
6. done
Sep 28, 2009 | 2000 Saturn SL
THE WIRES IN MY DAD'S OLD MIDLAND 77-106 MIC. HAVE BROKEN LOOSE
first check out the front for a circle with 27/81 this is the 40 channel (FM). if you cant find the circle it is (AM) and not used as much in the uk. if it means alot to you and your dad post it to cb communications shildon DL4 1HE and i will will see want i can do.
Jul 23, 2009 | Midland 4001 40-Channels Base CB Radio
No antenna lite when transmitting
Antenna light should be a warning indicator for high VSWR..... simple rule of thumb for CB antenna.... the lower the frequency "channel" the longer the antenna length, higher the frequency "channel" the shorter the antenna length. Your vehicle is a ground plane, where you mount the antenna will also affect its operation and tuning. A properly tuned antenna will have lower reflection on the midband channels and gradually rise as you near the upper and lower end of the band. Some base loaded antennas will be noticably narrow in bandwidth, if you have that problem then tune it for the channel you use most!
K40 has always been good for easy tuning and band coverage, center it on the vehicle top for good omni coverage!
PS... always make sure your connectors are secure, a loose shield will ruin your day when adjusting SWR!
Dec 20, 2008 | Cobra 29 LTD CB Radio
133 people viewed this question
Top Bang and Olufsen Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Bang and Olufsen Audio Player and Recorder Expert? Answer questions, earn points and help others
