Yamaha HTR-5170 amplifier shutting off & not powering up
Hi there - I have an Yamaha HTR-5170 amplifier that has been shutting down on me intermittently& I can not figure it out. After checking all the connections, speaker wires on the all 5 Bose speakers & impedance it still will power off on its own. Sometimes it will not even power up & stay on it just keeps shutting off. This unit was taken to an authorized Yamaha repair shop & it was worked on for a week & it never once shutdown on them. They said they ran it through many tests/loads & it is working well. Well, no it's not...I can not listen to the radio, play a DVD or watch a movie on the satellite dish in 5.1 surround. Maybe this information will help solve my problem, I just recently bought a Samsung 60 inch DLP HDTV & since then this has been my life with my amp. Please help, Sammy
  • Jango Fixit
    Jango Fixit May 11, 2010
    Does it trip when all electrical connections to the DLP HDTV are removed?
    Scholar:
  • 54 Answers
I agree with Jango. Go back to the setup when it last worked. If adding the DLP is the problem, you may have some sort of a ground loop formed between the TV and the receiver. good luck...Rob
Posted on Mar 03, 2008
How to connect bose 901 to yamaha htr -6090
Sorry, it doesnt look like you can hook up an external EQ while still using the amplifier section of the yamaha. Instead, You would have to use the preamp out to go to 901 EQ, out of the EQ into another stereo amplifier, then to the 901 speakers. Personally, to power the 901's properly, I'd use another external amplifier. You will barley get 35 watts per channel out of the receiver to power the 901's
Oct 07, 2014 | Yamaha HTR-6090 Receiver
How to connect a turntable connected to a yamaha a450 stereo amplifier...can I attache the a450 to the htr-6130 ?
If the turntable is newer kind you can connect it in any Stereo input like CD, VCR , etc.
If the turntable is older model you can only connect it to PHONO input (if amp has one) and make sure earthing cable is connected on Amp
Remember input is only stereo (unless your model has digital input) and select sound effect eg Pro Logic for enhanced sound,
Aug 26, 2014 | Yamaha HTR-6130 Receiver
My rx-v367 turns on then shuts off immediately
YAMAHA RX V367 HTR 3063 SM Service Manual free download schematics eeprom...
bad or leaking capacitors or shorting somewhere first disconnect power amplifier a variable powersupply variac it can be very helpfull
Jan 25, 2014 | Yamaha RXV367 Receiver
My yamaha htr-5640 receiver will turn on for a sec then a small click and then shuts down....no speakers hooked up....what is the deal?
With the power off, try to disconnect every component and then power on the receiver. If it still shuts down, then it is an indication of an internal error and the unit needs to be serviced.
Regards,
Yamaha Support
Nov 28, 2011 | Yamaha HTR-5640 Receiver
Yamaha RX-V3000's front channels quit working
The front channels could still go out if one of them
is going out as the relay will shut em both down if it senses a problem! Check also for bad solder connections too!
Apr 13, 2010 | Yamaha HTR-6030 Receiver
I have a yamaha htr 5890. I would like to hook up
You are probably connected to the pre-out jacks. These are not amplified. Connect them to the B speaker outputs(screw down connectors). If that won't work (and it should), you can connect to the "Presence" speaker connections(spring loaded connections).
Feb 02, 2010 | Yamaha HTR-5890 Receiver
Yamaha HTR-6130 Receiver will not stay on! Shuts
One last try with everything disconnected!
Other than that I suspect internal surge damage.
Aug 04, 2009 | Yamaha HTR-6130 Receiver
HTR-5740 Subwoofer Hooking Up Issue
You can use a hi-level to low-level adapter. Just remember, the Yamaha does not send power (wattage) to the sub, just signal. You need to use a subwoofer that has an amplifier either externally or built in.
Jun 26, 2009 | Yamaha HTR-5740 Receiver
Yamaha HTR-5830 Video shut down.
You have having a problem with the video amp clipping the signal after it get hot. You have one way to try to temporarily solve this problem. Try putting more air flow over your receiver and cooling down the temperature inside the receiver and see if the video amplifier starts working correctly. If it does then you must put a fan on it somewhere that will keep the air flowing so the video amplifier is not allow to overheat. If this does not solve the problem, then you will need to have the amplifier replaced for it to work correctly. If the unit is under warranty then call this number 1-800-492-6242 to locate a service center in your area. Call them for help with your problem. You can also try looking on the www.yamaha.com website. Put in you model number and check in the frequently asked questions and troubleshooting sections for people who have had similar problems with this unit and see if they printed a solution for the problem. I hope this helps you with your problem.
Mar 05, 2009 | Yamaha HTR-5830 Receiver
HTR-6130 will not turn on
Remove all speakers from the receiver and try powering it up again. If it still shuts down odds are it needs repair of one of the output channels.
Jan 31, 2009 | Yamaha HTR-6130 Receiver
175 people viewed this question
 Grubhead
Grubhead
