Question about Aqua -Vu Perch Underwater Camera with 100-Ft. Cord GPS Receiver
Wires coming out of monitor are; RED, BLACK, BLUE and YELLOW. wires coming from camera are; RED, GREEN, WHITE, BLACK and BARE. the WHITE, BLACK and BARE wires are rapped in a blue tin foil type material. my camera has a light on it also. so what wires do i connect so i can get an image on the monitor?
Where can I find the wirring diagram for 12 volt reversing camera
i think it goes
Polaris Red-Camera Yellow Polaris Black-Camera Black Polaris white-Camera white and polaris Green-camera bare hope this helps
Nov 24, 2014 | Car Audio & Video
I have a ccd color camera with a broken cable, the unmatched colors are red, white yellow, black and bare copper. the end line it needs to connect to has red, white, yellow, blue, green and bare copper,...
sorry partner you have a prob. no changing wires will ever work in the corder . try the shopping for systems that are compatible to the tv monitor hook up .. looks like a really nice camera too .
Aug 21, 2013 | Clover Corporation Home Security
Martec ceeling fan/light wiring diagram needed or step by step guide for connecting wires.it was a mess and all not workin so need to get sorted asap.someone help.
depends on how your ceiling box is wired. if your box has a black, white, or green or bare ground you need to twist your blue and black wires together and connect to the black wire in the box connect white to white and green to the green/bare wire. if you have a three wire connection (black,red,white,green/bare) you connect red to blue black to black white to white and green to green/bare
Apr 05, 2012 | Home
HOW DO I CONNECT A JENN AIR MODELE C 202 C COOKTOP HAS 5 WIRES
Hello Ken,
What color are the wires i suspect they are red,black white,green or bare copper??
connect all the reds to the reds from the house wiring same for the black and white and connect the either green or bare to the green or bare wires
Nov 05, 2011 | Jenn-Air Cooktops
We are experiancing probems with our agua view. The light comes on on the moniter but there is no video coming through. Is there a fix for this issue
i was having the same prob. so i cut the male conector part off the the camera cord and cut like 4" of the black cord part off to expose the wires. there will be 4 colored wires and 1 bare wire cut the bare wire off as close as you can to where you stripped off the black part, then expose the top inch of each color wire. OK now open up the back of the monitor, take the black female connector off you dont need it. you will see a 4 prong female connector part inside cut that off too, then conect the wires black - black / yellow - white / red - orange (i think it was orange) / blue - green . it sounds kinda complicated, but really easy, and now it works great! make sure you use electrical tape or something over bare wires
Jan 16, 2011 | Aqua -Vu Perch Underwater Camera with...
Only have two wires to connect to
What timer are you installing?
Intermatic battery-operated timer with red, blue, black and green
Green connects to bare ground
Red is capped off.
Blue connects to one wire
Black connects to other wire
Push on-off button: if light comes on, timer wiring is correct.
If light does not come on, then reverse blue and black wires.
Other in-wall timers except Aube have red, black, white and green
Green goes to bare ground
Red connects to one wire
Black connects to other wire.
White: in back of electrical box are white wires twisted together and covered with wire nut. Connect white white to these other white wires.
If box does not have white wires described above, then connect white wire to bare ground along with green wire.
Push on-off or override switch: if light comes on, timer wiring is correct.
If light does not come on, then reverse red and black wires.
Dec 13, 2010 | Intermatic Inc. ST01C Digital In-Wall...
Response tv 2000 camera 4 wires red yellow blue black can i use a serial plug or usb or a yellow vidieo lead
Hi all. I stumbled on this site, & it seems pretty much what I'm looking for. I have a response3 TV2000 camera, but with only bare wires coming from the cam. White, red, blue, green & black. I'm assuming the red is + and the black is -. From the above post, I thought the green may ALSO (in my case) be composite video, may not be. But I'm lost on the other 2. Any help would be appreciated guys. Also, what connectors are needed, to go straight into a PC. Also, would a PC power the camera....
Thanks in advance.
Karel
May 28, 2010 | Cameras
The 3-way dimmer switch has 4 wires; 1-red, 1-yellow, 1 green and 1 black. Hot wire coming in is black, ground is bare and neutral is white. Wires going out are red,black,bare and white. What does each of...
Incoming white - outgoing white This is the neutral, which just passes through without connecting to the switch
incoming black - switch black the hot wire provides power to the switch
switch red - outgoing red a traveler, will have power when toggle is one position
switch yellow - outgoing black
the other traveler, will have power when toggle is in the other position
incoming bare - switch green - outgoing bare the switch is grounded and it passes through
If this was helpful, please vote.
Mar 21, 2010 | Cooper Wiring Devices Three Way Grounded...
Micromark wiring diagram
hi have the same issue found it to be red power black negative yellow video white audio and bare wire is the shared ground for the yellow and white hope this helps
Feb 09, 2010 | Swann Communications DVR4-Pro-Net...
Cooktop - maytag cse9000 - wiring
white goes to neutral, bare copper to ground, red and yellow to one phase ( red L1 wire) and the black and blue to the other phase ( black L2 wire)
Dec 20, 2009 | Maytag 30 in. CSE9000 Electric Cooktop
GPS Logo
135 people viewed this question
Top Aqua GPS Experts
Will Halftowaite
Are you an Aqua GPS Expert? Answer questions, earn points and help others
