Question about Brother HL 5250DN Laser Printer
Brother HL-5250DN Laser Printer Problem
I'm having a problem with the HL-5250 laser printer. When you take the front cover off, you should be able to stick a written document in to the slot where there is a paper, and an arrow in front of it. It should print that identical written document. It's not working. If you would try to find a solution, that'd be great.
Thanks
    Genius:
  • 3,587 Answers
Hmmm...so, your laser printer has a copy document feature? Is that in the printer management software settings, perhaps?
check here for latest print drivers
Posted on Mar 02, 2008
HL-5250 report shows fuser and laser life at 0% and PF kit 1 at 12%
The fuser is a separate component to the drum and toner in this printer. It has a much longer life than them but will run out eventually. Sadly a fuser unit is not a commercially available consumable for this printer either. I would recommend contatcing a printer technicain or Brother directly for a quote on replacing this part.
Apr 12, 2013 | Brother HL 5250DN Laser Printer
HL-5250DN Laser Printer: We have a brother 5250 laser printer. Trying to...
The problem coming because there is some paper jam in side the printer. Remove the toner cartridge and look inside the printer for any paper jam.
I hope it will help to solve your printer problem.
May 18, 2010 | Brother HL 5250DN Laser Printer
Brother HL-5250 printer toner Light on but Cartridge has Toner it
Try this....
1: Turn off power and remove toner/drum
2: Tape the little spring loaded lever just inside the printer on the upper left hand side in the *DOWN* position! Do not replace drum yet and...
3: Turn power on to printer and let it cycle. Status/Toner lights will come on as usual.
4: Turn off printer, remove tape from lever, replace drum and turn back on.
Mar 08, 2010 | Brother HL 5250DN Laser Printer
Brother HL-5250DN Laser Printer making noises and not printing
some gears are not in proper position , pull out the paper tray and closed it strongly .
Nov 17, 2009 | Brother HL 5250DN Laser Printer
I have a Brother HL-5250, drum light on, not printing
When the drum light is on solid, it's time for a new drum, if you have a new drum, just open the front door and hold the go button til all lights flash and the drum is reset. Press the go button 3 times and it will print a sheet showing the drum status.
Sep 15, 2009 | Brother HL 5250DN Laser Printer
Brother 5250DN Printer Toner light
Try resetting the toner counter manually;  * Turn off the printer and open the front cover * Press and hold the Go-button down * Turn on the machine while still holding button down, when all three LEDs are lit, release Go-button * Press the Go-button twice, and all three LEDs should be lit again. * Press the Go-button five times (six times if you have the High Yield toner) * Close the front cover and the toner counter should be resetted.
Jun 02, 2009 | Brother HL 5250DN Laser Printer
Replaced toner cartridge and light stays on the printer will not
how do i set the toner reset lever on a brother hl 5250 printer
Mar 31, 2009 | Brother HL 5250DN Laser Printer
Brother hl-5250dn fuser unit faliure
I have 2 printers that dosn´t work. Brother HL-5250 dn One with fuser that dosn´t work. Can I take thee fuser from the other and attach it into the first one. Or do you ned spcial tools and knowldge to do it?
rolf@edeborg.se
Jan 19, 2009 | Brother HL 5250DN Laser Printer
SOFTWARE DOWNLOAD NEEDED
Need software for Laser HL-5250 DN
Apr 27, 2008 | Brother HL 5250DN Laser Printer
HL 5250 dn
first you most clean the printer carefully then you most change the drum unit
Feb 28, 2008 | Brother HL 5250DN Laser Printer
Brother HL 5250DN Laser Printer Logo
144 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
