Question about Alpine CDA-9827 CD Player
How do I re-enable "AUX" option, which is off by default?
My car battery just died and now I can no longer use my iPod via the "AUX" option. Last time this happened I ended up bringing it into a shop and they told me that "AUX' needs to be re-enabled because it's not available out-of-the-box. Anyone know how to do this?
THanks!
  • sherriem240 Apr 07, 2009
    can not get aux to work i hooked up the cable but can not switch to it
Tip
How to make a high battery percentage iPod Touch 4.0
<p>By default, the iPod Touch gives you the remaining battery life with an animated image of a battery. When looking at the battery icon, you can estimate your rate is available and decide whether to load it. For a more accurate indication of your battery life, you can assess the use of the battery, which tells you the exact percentage of battery life you have available. IPod touch with 4.0 IOS software you can enable this feature in a matter of seconds. <br /> <p><br /> <p>1. Tap the Settings application on your iTouch 4. From the main menu, locate the application on the first page. By default, it appears near the bottom of the screen, indicated by a gray icon. <br /> <p><br /> <p>2. Tap "General". It has a small version of the same gray icon that you have already entered. <br /> <p><br /> <p>3. Tap the "Use" option, you can find near the top of its "General" options screen. You will see a list of relevant information about the battery life, including the extent of use since the last load and the amount of waiting time since your last payment. <br /> <p><br /> <p>4. Touch the cartoon "Battery Percent" switch on top of the screen. Tap the button to toggle between "On" and "Off" options. By switching to "On", the percentage of your battery available in the upper right corner of the screen. Tap again to "Off" position when you want to remove the percent sign, the battery of your screen. <br />
on Aug 05, 2011 | Computers & Internet
MP3, IPOD, CD doesn't appear when I press "Source"
Easy.
If you read your owner's maunal, page 26, the USB is designed for a flash drive (up to 4GB), not an Ipod.
If you would like to play your iPOD, purchase the IPC008 (Ipod Lead) and you're done!
Feb 24, 2009 | Eclipse CD1200 Car CD/ MP3 Player
My car died now the AUX1 doesnt show on my radio
there is a reset switch which needs to be pressed once mains are disconnected (as your car died down).do press it once.
The AUX control to which the ipod is connected is to be switched ON .It is not automatically ON.
once you put the AUX "on" you can hear your ipod.
Sep 02, 2008 | Pioneer DEH-P80MP CD Player
AUX OPTION NO LONGER SHOWS UP
I have the same problem dude. I think there is a setting somewhere. and you have to turn it on somehow?
Aug 28, 2008 | Pioneer DEH-P6800MP CD Player
Hook up IPOD
I am not sure if the model you have supports iPod control, but if it has an input jack in the front, you can use a cable from the headphone jack into the Aux jack in the front of the stereo and when there is a cable inserted into the jack you will be able to select Aux with the source button.
The other option is to get a kit installed at your car stereo place that will allow you to connect it via 3rd party hardware.
Cheers
May 30, 2008 | JVC KD-SX840 CD Player
Ipod cable will not work with the DEH-P3000
Hi, On a slightly different model and only if you would venture to try: with the iPod via cable plugged to the iP-Bus port and the unit powered off but the powersupply on - 1. press and hold for a couple of seconds the Function button (FUNC) or till the clock starts to flash; 2. the arrow keys (left/right) will move you through the different menu settings; 3. the arrow keys (up/down) will move you through the different selection for each setting; 4. look for source, external, AUX, iPod or whatever will be displayed which may refer to an external input; 5. soon as you have enabled/set the AUX, press and hold the FUNC button while turning the unit on. This will save the current setup. Hope this also work for your DEH-P3000. Good luck and kind regards.
Sep 23, 2007 | Pioneer DEH-P3000 CD Player
Can't get into AUX source
Are you sure it is an AUX input? According to the Manufacturers Specs, the AUX, is an optional accessory. There is a Pre-Amp connection, which would be an output, hence causing the problem you are having. Best of Luck.
Sep 13, 2007 | Kenwood KDC-MP232 CD Player
Auxillary option not available in menu
Try putting the unit in standby via the "SRC" button FIRST..., then press the menu button and cycle through to the "AUX 1" option and activate this....then press menu button again. When the unit is next switched on, you should have an "AUX" option accessible via the "SRC" button which will cycle through all of the availale modes ....standby-tuner-cd-aux etc etc.
Jul 01, 2007 | Kenwood KDC-MP628 CD Player
Alpine CDA-9827 CD Player Logo
1,842 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
