Question about Coby TF-DVD7100 Portable DVD Player
Coby TF-DVD7100 7" portable flat screen...keep getting "Wrong Disc" Error
I recently purchased a used unit from ebay and can not locate the orginaly owner or any instructions on how to use it. I seems to turn on fine...can see the DVD turning and it says it's loading, then, it gives me a "wrong disc" error. Can anyone help me?
  • jatm May 21, 2008
    We bought a 2003 Lincoln towncar with the navigation system. My uncle did not check out the navigation when he bought the car. When we checked it, it kept giving the "wrong disc" error. It is the dedicated dvd player just for the navigation system. The audio is another 6 disc cd player in dash. Would the same solution apply for this case? If so, could you give me some tip on removing the dvd player from the car to check? Anything I need to pay attention to so that I won't make the matter worst? thank you very much for your help!
  • alissaann Jun 24, 2008
    I keep having the same problem with this same exact player with cd's or dvd's and can't fix it have you fixed yours yet?
I have seen this problem on several Yamada & Xoro brand DVD players. If you remove the lid after powering down with the disc tray closed and a disc in it you may well find the ribbon cable to the read head is rubbing on the disc. The ribbon cable is held to the base of the box by a sticky pad under a 45 degree bend in it and a piece of sticky tape !!!. Power up unit, open disk tray, power it down, retape cable to base securely with small strips of duct or gaffer tape (using tweezers helps) and hey presto it will work again. The cable rubbing slows the disk spin speed hence "data read error" unit assumes "bad/faulty/wrong type of disk". All that technology screwed up by using a cheap bit of tape in the factory assembly, amazing eh !.
Mark
Posted on Mar 13, 2008
2 Suggested Answers
  • 3 Answers
SOURCE: download manual for coby tf-dvd7100
Go to www.cobyusa.com
Click on Support.
Go to FAQ's.
Under DVD's, click on the question that gives you the PDF of the manual.
It's about 24 pages in length.
Posted on Oct 26, 2008
Coby DVD Player wont play
try running an optical disk cleaner it worked for me but I have to clean often.........a cheap fix if it works.
Jan 26, 2009 | Televison & Video
My coby portable dvd player keeps saying wrong disc
You may need to clean the laser in the unit. You can purchase a cleaning disk at Radio Shack or Best Buy. They are normally less than $20.
Nov 06, 2008 | Coby TF-DVD7107 Portable DVD Player
COBY TF-DVD6200
I work for Coby technical support. Our customer service phone number is 1-800-727-3592.
Thanks for using FixYa.
If the unit is showing "no disk" on every disk that you try to play, unfortunately, the unit has developed a defect and needs to be replaced. It can not be repaired. Our warranty is 90 days from the date of purchase. If you received the unit as a Xmas present, please call the number above for instructions on getting the unit exchanged.
If you feel this solution doesn't deserve a good rating, please let me know why so that I may better assist you. If there is anything more I can do to help, I will!
Oct 26, 2008 | Coby TFDVD5000 Portable DVD Player
"another wrong disc"
I too do not understand how to check the motor or change the wire
Jun 29, 2008 | Coby TF-DVD7100 Portable DVD Player
COBY TF-DVD7307 Portable DVD player
anybody can help my dvd player with broken wire connected to the LCD many thanks by aruiel_mirabueno@yahoo.com
May 13, 2008 | Coby TF-DVD7100 Portable DVD Player
Dratted Coby TF-DVD7100 Portable DVD player not working!
Its defective. Coby doesn't repair the units. The lense is off balance which is causing the laser to not read the dvd/cd.
Apr 17, 2008 | Coby TF-DVD7100 Portable DVD Player
Coby Model Number TF-DVD7005
Paul Sim, coby portable dvd player model TF DVD7005 keeps coming up with an error message that says NO DISC regardless of whatever disc you put in, the player comes up with the message LOADING on the screen and then stops after a little will and comes up with the NO DISC message
Dec 10, 2007 | Coby TF-DVD7005 Portable DVD Player
Problem
I have also had the misfortune of owning one of these substandard pieces of trash. I corrected my wrong disc error by manually moving the laser towards the center. The laser seems to jump off track and gets stuck on the outer edge for some reason. I'm still battling a software issue that keeps reverting to the set-up screen.
Oct 12, 2007 | Coby TF-DVD7005 Portable DVD Player
COBY TF-DVD7060 SAYING WRONG DISC
In Remote Control:
1) Press SETUP
2) Press Fwd (»)
3) Press Rwd («)
4) Press Fast Forward (»|)
5) Press Fast Rewind (|«)
Original region number (1 to 6) will appear - uses arrow keys (Navegation) to change to 255 (ALL Regions).
A couple notes:
- The keys referred to in the above hack are on the remote control (not on the front panel). But, if you want, you can use the front panel to implement the hack – just use the key equivalents (i.e., for SETUP, press Mode twice; for », press and hold »| for 2 seconds, and so on ).
- When the Region Number appears, it is in the upper right corner of the Set Up window without any label. In other words, if your player is currently set up for Region 1, look for the number 1 to appear in the upper-right corner of the Set Up screen (once you've pressed the correct sequence of fast forward and reverse keys). Then use the arrow keys to toggle the number to 255.
If you remove the main battery, you might have to do the trick again.
Enjoy.
Sep 05, 2007 | Coby TF-DVD7060 Portable DVD Player
Wrong Disc
If the unit is showing "wrong disk" on every disk that you try to play, unfortunately, the unit has developed a defect and needs to be replaced. It can not be repaired. Our warranty is 90 days from the date of purchase. If you received the unit as a Xmas present, please call 1-800-727-3592 for instructions on getting the unit exchanged.
Aug 09, 2007 | Coby TF-DVD7005 Portable DVD Player
Coby TF-DVD7100 Portable DVD Player Logo
820 people viewed this question
Top Coby Televison & Video Experts
Are you a Coby Televison and Video Expert? Answer questions, earn points and help others
