Question about LG enV VX9900 Cellular Phone
Ringer and picture Id
Just bought the phone, ringer and picture id will not work. only the default ringer works
  • chromose Sep 20, 2008
    Just bought this phone and niether Picture ID or Ringer ID work. They are both turned on and yet, still do not work.
    Any suggestions?
The first thing you have to do is go into the settings and tools menu. Once there got to option 6, call settings then ringer ID make sure it's set to on and then do the same for picture ID. That should take care of the problem. Hope that helps!
Posted on Mar 03, 2008
How do I turn the ringer on, on the handset?
Press program/mute button to confirm and you may program the following items: Set Language, Handset Name, Ringer Tone, Ringer Volume, Message Alert, Ring To Answer, Security Code, VIP Melody, Key Tone, Audio Predial, Vibrate Ringer, Area Code, Tone/Pulse, Registration, Deregistration and Default Setting.
Ringer Volume
From the Handset Setup Menu:1. Press the caller ID-volume ( 6 or 5) button to scroll to the RINGER VOLUME sub-menu.
2. Press program/mute button to enter the menu. SET RINGER 1HI 2LOW 3OFF shows in the display.
3. Use the touch tone pad on the handset to select 1, 2or 3, or use the caller ID-volume ( 6 or 5) button to scroll to your selection. HI is the default setting.
4. Press the program/mute button to save your selection. You will hear a confirmation tone and the new volume setting shows in the display.
NOTE: If you turn the ringer OFF, the ringer off icon shows in the display.
May 27, 2016 | Uniden Cordless Phone
My phone ringer is off and I don't know how to turnit on
You may follow the steps below.
2. Press mute/program button to enter the menu. SET RINGER 1HI 2LO 3OFF shows in the display.
3. Use the touch tone pad on the handset to select 1, 2 or 3, or use the caller ID-volume
4. Press the mute/program button to save your selection. You will hear a confirmation tone and the new volume setting shows in the display.
May 12, 2011 | GE Lands Phones
If I turn off the ringer does this also turn off caller ID?
Turning off the ringer won't affect the caller ID display. All that happens when you turn off the ringer is that the phone doesn't make noise any more. The ringing signal and caller ID information from the phone company still will reach the phone.
Oct 29, 2010 | Avaya 700340193 Corded Phone
Ring tone changed tonight--it is too loud and awful.
The Ringer ID, Light Up ID, Picture ID and Custom Ringer settings cannot be assigned via the software, nor backed up, restored or transferred to another handset.
3. The USB connection cannot be plugged in while the phone is being charged - it is also physically impossible to do so. Kind of dumb given the USB connection sucks a lot of battery power.
4. In fact the USB should plug in to the base/charger so the phone is instantly connected (like a PDA) once docked, with two-way synchronisation. This is not as important though, as #2 above.
5. It is possible (as I learnt the hard way) to inadvertently wipe out the existing phone book and all its hard fed Ringer ID, Light Up ID, Picture ID and Custom Ringer settings merely by attempting to add new entries thru the software without first retrieving the existing entries from the phone. On the positive side, re-sending the same entries does not overwrite the already set up Ringer ID, Light Up ID, Picture ID and Custom Ringer settings.
Jan 20, 2009 | Panasonic KX-TG5673 Trio Cordless Phone
I have a motorola bz60. just went on line to download music and wallpaper.but i dont know how to get it from my messages to my media gallery music and pictures
Here is how to set your default ringtone:
Main Menu Settings Audio __ Detail (2nd line .. if style:loud then line 2 will say Loud:Detail .. if style:soft then line 2 will say Soft:Detail) Now you'll see
Ring Volume: Calls: IM:  Messaging: Voicemail: Calendar Alarm: Data Calls: File Transfer: Ringer IDs Key Volume: Reminders:
Click on Calls  Click on Music
Now you can set the default ringtone.
To set a specific ringtone for each person in your address book:
Main Menu Address Book Click Options Click Edit Contact Scroll down to Ringer ID Music
Now you can set ringer ID for that contact.
Aug 08, 2008 | Lands Phones
Caller id
I can not turn on the ringer on hand set
Apr 13, 2008 | Panasonic KX-TG1033S Cordless Phone
Motorola W 490 individual ringtone
To assign a ring alert (ringer ID) to an entry:
Phonebook > entry, then press
Options > Edit Contact > Ringer ID > ringer name
Note: The Ringer ID option isn’t available for
entries stored on the SIM card.
To activate ringer IDs:
Settings > Ring Styles > style Detail
> Ringer IDs > On
Dec 13, 2007 | Motorola Mobility RAZR V3
Ringer ID won't work
If this doesnt work then your phone must be possesed..
1. Go to your phone book.  Choose a contact.
2. Go to options. Then Edit Contact.
3. Now scroll down all the way to Ringer ID:__ and hit select it.
4. You should see a list of songs  and sounds like silent, Vibe Dot.. etc
5. Scroll down until you want the ringer for that contact.
6. Once you found the ringtone hit select it.  You should now have the ringtone for that contact.  NOW hit "DONE" or it will not work!  If you dont hit done it will use the DEFAULT ringtone provided by the phone.  Also, if you have a memory card in your KRZR k1 and all your songs are on the memory card you wont be able to use it, move them to your phone memory so you can choose it from the list.  mobiles24.com also can give you free ringtones too.. check it out.
Jun 23, 2007 | Motorola Mobility MOTOKRZR K1 Cellular...
Ringer id
If you have an SD card it might be stored there. You might have to copy or move it to the phone storage from trans T-flash.
May 03, 2007 | Motorola Mobility RAZR V3
LG enV VX9900 Cellular Phone Logo
77 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
