Question about Frigidaire ATF6000ES Front Load Washer
How to change drive belt on ATF7000ES
How do I change a belt on a Frigidaire ATF7000ES?
    Genius:
  • 3,587 Answers
Disconnect the unit from power, and water...
move away from wall
easiest access is from underneath, by tipping it back around 45 degrees. I don't recommend placing it on it's back, for a variety of reasons
you should see the belt right there. you'llneed to loosen the clamp holding the pulley wheel that belt goes around, and then it should slip off nicely..
make sure to tension the pulley again snug, but not too tight..there's a torque spec for it, but it's tough to get a torque wrench in that small of a space
hope that help you and thanks for using Fixya
Posted on Mar 02, 2008
Why is my affinity dryer not heating and showing error code 56
Good Afternoon Friend,
I understand your Frigidaire dryer, model# ATF7000ES, is not heating and showing an error code 56. The E56 code means there is high motor current, meaning it is possible something is going on with the motor. The other possibility is this is a false error code. Please try resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and try any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jul 06, 2014 | Frigidaire Affinity ATF7000ES Front Load...
Our dryer says it locked how do I get that off
Good Morning Friend,
I understand that your Frigidaire Affinity dryer, model# ATF7000ES, states that it locked and you want to know how to get it off. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 23, 2014 | Frigidaire Affinity ATF7000ES Front Load...
DRYER WONT SPIN
Can you hear the motor run after you attempt to start dryer? If so, check for a broken belt. If not you will need futher troubleshooting, Could be motor, timer, etc.
Mar 29, 2014 | Frigidaire Affinity ATF7000ES Front Load...
Front loader hums instead of starting
Try to get ahold of a qualified service technician that specializes in washing machines and dryers.
My guess is it could either be if its belt driven the belt has broke and the drive motor is turning freely or the drive motor is possibly burnt out or in need of replacement.
Its not much but I hope it helps
Sep 27, 2013 | Frigidaire Affinity ATF7000ES Front Load...
My dishwasher is liking water.I am under the warranty. What should I do?
Sorry but your post is a bit confusing. You have 'Problem with the Frigidaire Affinity ATF7000ES Front Load Washer' as the title but then go on to say 'My dishwasher is liking water'!
Anyway whichever it is, and I presume it is your washing machine, you say it is still under guarantee so clearly you should invoke that guarantee anyway. No-one else should touch it.
Firm advice ;-0)
John C
Feb 16, 2011 | Frigidaire Affinity ATF7000ES Front Load...
Washer pumps out water but won't spin.belt is on
We are having the same problem. It is one of the two:
control panel or speed board.
Mar 07, 2010 | Frigidaire Affinity ATF7000ES Front Load...
Frigidaire ATF6000ES Front Load Washer Logo
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
