Question about Nintendo DS Lite Console
How to open ds lite
My son wet his ds lite i want to open and clean any corrosion?
  • passport Mar 03, 2008
    my ds lite intermittent during the charging lights on and off for 1 sec
  • Anonymous Oct 11, 2008
    I have to clean the corrosion on the recevier.
    Sniper:
  • 64 Answers
There are two cross head screws under the rubber feet at the slot1 side, there are two tri-wing screws on the left (stylus side) and inside the battery cover (under the battery) there is a cross head screw at the top and a tri-wing screw at the bottom (in the corner).
The screen is held together by 4 screws under the ruber pads and then the outer case slides up about 5mm and then pulls clear.
Take great care when putting it all back together to line up the volume and power switches and plastics as the power switch breaks quite easily.
HTH
Posted on Mar 02, 2008
I spilt a bit of soap and water on my ds lite
You'll need to open your ds and clean it with alcohol and a small brush. this should help your system go back to normal, you should do it ASAP as it can built corrosion on your system.
Here is a link on where to open your system: http://www.techrepublic.com/photos/cracking-open-the-nintendo-ds-lite/171256
Thanks
1RepairStop.com
Feb 15, 2012 | Nintendo DS Lite Console
What is the correct way to remove the green corrosion on my sons games? im assuming it's inside the console also, can i safely remove it from there also?
Hi, you need to get a cleaning kit, it can help you clean the contacts con the cartriges and the consoles. This green corrosion comes from humidity, and can be caused by blowing at the contacts.
Mar 01, 2011 | Nintendo DS Lite Console
Sons DS lite does not hold in place when open,help
your hindge is worn out you can order a replacement hidge from nintendo 15 buck i think
and if it belongs to your child make sure he is not opening it like a revolver with a flick of the wrist that kills the hindge
ds's are pritty easy to dis and re asseble
so dont get scared when you have to open it just keep eyes on it and remmeber where things go hope this helped rate high
Oct 22, 2009 | Nintendo DS Lite Console
DS lite Top screen got wet this morning
Go into the ds and dry off the top screen it does work.
Jan 28, 2009 | Nintendo DS Lite Console
Nintendo DS not reading games
Some pins were bent in my son's DS. I used a mini LED light and an open paper clip as a pick to bend them back into line.
I then got an Emory board (nail file) and wet the tip in alcohol, the board is the right thickness to just reach the copper pins. I went in and out gently as I worked my way across the lot and kept wetting the file with alcohol. All the games worked like it was new. be sure to do this upside down so the alcohol drips out the slot along with the filings. good compressed air blow after you are done to get all the strays out of there.
The pinds are copper and they do oxidize and the games left in gets moisture trapped between the game and the pin causing some corrosion. Maybe diddimilar metals by alloy but wither way this fix works ! : )
Sep 21, 2008 | Nintendo DS Lite Console
My son's nintendo ds lite was dropped into water
if you go onto ebay you can buy the correct screwdriver for 50p it is called a triwing screwdriver my daughter did the same to my ds she poured juice into the back i opened it up gave it a good clean with some cotton buds left it open for a couple of days and it works fine now hope this helps.
May 17, 2008 | Nintendo DS Lite Console
Nintendo ds lite slight water damage in the game insert areas...
i WOULD SUGGEST AN ELECTRCAL CONTACT SPRAY CLEANER APPLIED TO A Q TIP
Jan 16, 2008 | Nintendo DS Lite Console
Problem with new ds games
try cleaning the connectors of the game with a qtip don't use any solvents just a dry qtip.
Dec 27, 2007 | Nintendo DS Lite Console
Ds lite
Components may have come loose on the board, or damaged solder joints. Water damage can sometimes only appear after water has had time to seep, unless knock helped throw some residual water around inside, onto things it shouldn't touch.
Dec 02, 2007 | Nintendo DS Lite Console
Nintendo DS Lite Console Logo
1,837 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Zhenya Ogorodnikov
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
