Question about HP PSC 950xi All-In-One InkJet Printer
Fax unable to get dial tone after I switched phone service from verizon to comcast digital
Comcast put in a new cable modem, ran a standard phone line to face plate in wall with two receptacles (essential a splitter); then used the foxconn hp 8120-8344 cord from the fax to the other receptacle in the faceplate. Fax capability was lost.
After switching every possible wire and plugin configuration, comcast tells me they think I need to order another hp 8120-8344 cord and use it from the modem to the wall as well as using the other one from the fax to the wall. They also said I could try putting both cords (standard and proprietary) into an external splitter plugged into just one receptacle.
Help.
    Genius:
  • 3,587 Answers
Splitters by their nature are flaky..i'd recomend you get a good phone line cable, since they are cheap, and simple..you have another phone line somewhere, to test the fax/cable combination, just to make sure?
Posted on Mar 02, 2008
I have a 854 AT&T 4 LINE PHONE SYSTEM IT WORKED GREAT UNTIL I changed providers i switched fro Verizon to Comcast now when I pick up or answer a call the lights appear only on that phone the other...
If the Comcast people changed the equipment in the phone room they probably ran direct lines to each phone or put filters in the lines. The reason you're not seeing the lines light up is the phones are not wired correctly now. The cable box that all of your lines are coming from must have a 1 to multiple line adaptor for each line. The adaptor feeds all of the phones. Communication for the intercom and the line in use lights goes down the phone lines so ther has to be a direct connection between all of the phones. If there are filters in the lines they must be put between the cable box and the line splitter. You can get the line splitters at Radio Shack (Model 279-435 for 1 to 3 adaptor).
Feb 14, 2012 | Lucent PARTNER18 Corded Phone
I've recently switched to charter as my providerand they installeda modem ( sbv51220) which works fine, but the monthly charge of five dollars irks me. I bought another modem from Bestbuy at the urging of...
Do you have phone service with Charter as well? If so the modem you have been provided is made to run both the phone service and the internet. If you purchased your own modem from best buy the phone portion would not be present so that is why those connections are not on the new one.
To cut to the point the new modem will work just fine for you internet but bear in mind it will now require another splitter for the coax cable line and each time that you add a splitter you will loose a portion of the incoming signal and this may affect your services.
Thanks,
Robert
Jan 03, 2011 | Arris (SB5101U) Cable Modem
Hp c309a printer/fax/scan/copy - fax's sent not being rec'd and cannot receive incoming. Ran fax test and shows "pass" on all items.
hate to ask, but is the phone line from back of printer in the correct port, the one for 1 line, next check the connection to the wall or splitter, if you are using a splitter, radio shack type, try the other side, and last, if you have a single hand set, check to see if you have dial tone at that connection. now if you are using cable modem for your phone and fax, you will need to contact them for assistance.
Sep 22, 2010 | HP Photosmart Premium C309A All-In-One...
Comcast Digital Voice/ADT alam system
The 2 jacks on the back of the Arris modem are labeled "1/2" & "2". The first jack labeled "1/2" means that the jack is capable supporting 2 different phone numbers, a line 1 and a line 2. The second jack labeled "2" means that it is capable of supporting only a second phone number. Therefore your 1 phone number is working correctly from the port labeled "1/2".
There are different types of phone splitters. It is possible that the one you used may have been to split lines 1 & 2 on a single jack into two seperate jacks. Take a closer look at the splitter and see if the 2 ports are labeled differently.
Hope that helps.
Nov 03, 2009 | Arris Touchstone 450a (CM450) Modem
I have Comcast bundle service for my home that includes tv, phone and internet which is digital. Can I use the Sensaphone 400 with this digital system?
This model may not be used on a digital system. It can be used on a standard phone line only, only engineered to handle standard phone line with pulse or tone dialing. I hope this helps!
Sep 20, 2009 | Sensaphone Computers & Internet
Siemens gigaset se587 wlan dsl
HI
A flashing ADSL light on the router means its not getting constant broadband signals. Make sure it is connected to the adsl filter without any extensions and the filter should be directly connect to the main phone socket and not to an extension socket. Also check if the phone socket has 1 or more than 1 ports on it. If it has two port its most likely a SSFP socket which does not require a filter as it is inbuit.If all the connections are fine try changing da filter.
Sep 07, 2008 | Siemens (120-5830-001) Modem
Problems with my new TP-Link 108 wireless ADSL2+ router modem + splitter filter
sounds like you are using a splitter...does your modem run off a splitter without a dsl filter on it?
Feb 21, 2008 | Computers & Internet
Vonage Again
Just use a splitter and connect the phone line direclty to officejet 7310 All-in-One line 1 port.
Then make below changes :
Press Setup on the All-in-One. Navigatet to Advanced Fax setup - Fax speed. Set the Fax speed to Slow. Also set the ECM (Error Correction Mode) to Off.
Thanks
Dec 22, 2007 | HP OfficeJet 7310 All-In-One InkJet...
I can't receive and send fax
The splitter the technician is referring to goes on the wall jack. One should have come with the "modem" installation package.
Take a regular telephone cord and plug one end into the splitter and the other into the line jack on the Fax/printer.
When your done you should have two phone cords connected to the splitter - one going to the "modem" and the other to the printer.
Nov 11, 2007 | Office Equipment & Supplies
Installation
If your internet or cable light is blinking then you probably have a cabling issue.These modems are designed to be ran with an RG6 home-run line to the cable box outside.You cannot have any splitters in between.A home-run is a cable that runs to the service box on the outside without any splitters.
Nov 03, 2007 | Arris SURFboard SB5120 Modem
HP PSC 950xi All-In-One InkJet Printer Logo
130 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
