Question about Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator
Ice forming on coils
My freezer hasn't been working as well as it should. It's only about 6 years old and when I removed the panel in the back of the freezer, it was as if there was ice all over the coils. I used a hairdryer to remove all of the ice and am now letting the freezer run, hoping that it will work. Is this something that a novice would be able to fix or do I need to get someone to look at it? Any assistance is greatly appreciated.
    President:
  • Whirlpool Master
  • 2,651 Answers
You defintaly have a defrost problem , bad heater( not likely), bad defrost timer/defrost board ( maybe). faulty defrost thermostat (most likley)... when you defrost coils thers a small thermostat clipped to upper portion of coil, usually an orange and pink wire leading to it. so long as your comfortable about wiring in a new one you can do it yourself. .UNPLUG UNIT clip out old thermostat bring to local part house and get a replacement. simply wire back in new thermo and your good, wires dont matter as to which goes where.(thats most likely cause of defrost problem)
Posted on Mar 02, 2008
Samsung refrigerator is freezing up on back panel of refrigerator . Will defrosting the whole unit do any good? The unit is 2 years old
well yes and no , defrosting it will temporally make it work , but main problem is there isn't proper air flow over evaporator coils id clean them with soap and water while defrosting out unit , if low airflow is allowed to continue then refrigerant gas will build to high press and escape and render unit a total replacement
Sep 29, 2016 | Samsung RB215ACBP 20.0 cu. ft. Bottom...
Automatic ice maker stopped working, Checked water supply to back of freezer, and the water supply is on. Arm on ice maker seems to be in correct position. there is no water in ice maker. can feel the...
Assuming you have active water supply to unit, either water valve or ice maker is bad. If Ice Maker is sending power to valve during Ice cycle, then valve is bad. If no power to valve during Ice cycle, then ice maker is bad.
Sep 11, 2017 | Amana ARB2557CSR / ARB2557CSL Bottom...
Water collects at bottom/Ice forms in top
The defrost drain is located just under the cooling coils in the back of the freezer. You will need to unload the food and remove the shelves from the freezer. Take the back panel off from inside the freezer and you will see a hole just below the coils. Flush it with hot water using a turkey baster or small hose. See the link below for more details.
Defrost Drain
Jul 21, 2010 | Hotpoint HTS16HBR Top Freezer Refrigerator
Ice forming on the back of side by side 17 yr old fridge
You have a bad defrost heater . To access , you will have to remove the inside rear freezer panel . The heater is located at the bottom of the coils . Take your model number when ordering the part so you get the correct part .
May 02, 2010 | GE Refrigerators
Our Refigerator is forming ice in the freezer. It
Probably has lost the defrost function and excess ice has formed clogging air flow and shutting down ice production. Remove the access panel and inspect the evaporaton department for signs of failed defrosting.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 22, 2010 | Refrigerators
I had a huge block of ice on the bottom of my freezer that I got rid of yesterday. Over night the ice started to form again. What could be wrong? The unit is only about 8 years old and we've already had...
This can be caused by the drain hole below freezer coil being blocked by ice. You MUST remove all ice in drain under freezer coil. Use turkey baster to squirt hot water into hole and use hairdryer to defrost. Possible defrost thermostat is defective. Unit never goes into defrost, ice forms on coil and in floor of freezer. After defrosting may work OK for a week or two but gradually gets warmer because ice is blocking ports where cool air gets to refrig. May also have water in refrig box. Can also be caused by defective defrost timer.
Aug 19, 2009 | Refrigerators
I have a 7 year old Kenmore Upright Refrigerator/Freezer on top. I am losing the temp in the fridge part only. The back up the freezer gets a thick layer of ice buildup and when i remove the back panel the...
After you taken the back panel off and see a lot of ice forming on the coil before you use your hairdryer you should locate the timer and turn the center of the timer manually into defrost cycle. If you can see or hear the ice melting then your problem is the timer defective. Change the timer and that is all. But if it doesn't do anything then you will need a little bit more on electrical knowledge to deal with the rest on defrost temperature control and the element itself. Hope this help, God Bless.
Jul 13, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
GE GSS25WGMCC, Ice Forming On Freezer Interior Surfaces
i had the same problem and i replaced the defrost heater and it worked fine for about one month but now having the same issue. Most of the time from what I have heard it is the defrost heater (about $60 part). I might have another issue going on with mine like a defrost thermostat. Your defrost heater is right under the panel on the inside of the freezer section. remove white panel on back side of freezer section and remove two screws and two wires and replace it and you should be fine.
Apr 15, 2009 | GE Refrigerators
Kenmore Elite 795 75542401
I replaced my "entire" ice cube maker (tube,hoses,water pump, ice maker) and it still pooled water at the bottom. I removed the back panel in the freezer and noticed the ciols go through a defrost cycle and water forms in tray under coils. I removed the lower panel on rear of fridge -and found a drain hose near the water solenoid/pump. I blew compressed air into the hose and hopefully unblocked it so it can drain into the pan not the freezer.
Jul 16, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator Logo
48 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
