Question about Audio Technica AT-LP2D Turntable
The turntable turns too fast. We just set it up and recorded the first song. When we switched to the next LP, it turned at too fast a speed and I can't get it to go back to normal speed.
  • 1 more comment
  • Anonymous Feb 14, 2009
    I have an audio-technica AT-LP2D-USB Turntable, I recorded several LPs at regular 33rpm. A few weeks later tried to do another 33rpm LP and it is stuck at a faster speed of 52rpm at the 33rpm setting. I checked the checked the drive belt and it is properly seated.
  • joeyjoel Feb 14, 2009
    I recorded a couple of 33LP records just fine. A few weeks later hooked it up again and on the 33rpm setting the turntable spins at 52rpm. I have reset the drive belt.
  • Anonymous Apr 21, 2009
    I'm having some trouble with that too. It seems like it's turning at 35 and 47 rpm or something. Just a little too fast.
Mine had the same problem. It was under warranty and Audio-Technica replaced it promptly.
Posted on Jun 20, 2009
Sony ps x45 tone arm wont move back to the cradle?
First off, is this a Sony or an Audio Technica? There can be many mechanical issues causing this. For more information, or should you have any further questions, please visit my website at audioserviceclinic.com. You may contact me through the website. Thank you
Aug 26, 2013 | Audio Technica AT-LP2D Turntable
My SounDesign Player Turntable System will power up but the platter won't spin.
Try to lift the table (it might have a "c" clip lock in the center) and check the belt or idler tire on the bottom of the table.
Feb 07, 2011 | Audio Technica AT-LP2D Turntable
Why can't I hear any sound when I record from my turntable conver
hi, you need first a pre amp phono or mixer before you patch into the computer to amplified signal in to your vinyl..
Jul 03, 2009 | Audio Technica AT-LP2D Turntable
Turntable spins too fast at both speeds
this is belt driven turntable....have you tried adjusting it via the pitch control or even getting another belt for that turntable....
Apr 12, 2009 | Audio Technica AT-LP2D Turntable
One channel vocals drop out
yes, it is very likely the stylus. the stock needle is conical shaped like a ball point pen. You might have a tonearm that is out of alignment but usually it's the needle. It is possible it is just dust on the tip but if it occurrs in consistent areas of the record, then it is likely that the music is just too demanding for the LP2D you will either have to use your old technics which is likely better quality or you could try upgrading the stylus on your LP2D.
If you do a yahoo search for "4-211-DE-GUARD" with the quotes, the 1st result will take you to an elliptical upgrade over the stock needle. The elliptical tip will pull more info out of the grooves and into your computer for further processing.
Jan 16, 2009 | Audio Technica USB Turntable
LP audio recording seems to be at the wrong speed
1- The turntable is set to 45 rpm and the album is recorded at 33 rpm. Press the 33 rpm button the red light should come on turn the and be fine.
or
2- This turn table has a fast record mode where you can record a 33 rpm LP faster by spinning it at 45 rpm. If you are trying to use this mode you will have to make a software setting to tell the TTUSB10 digital converter program what mode you want to run.
Nov 29, 2008 | ION Audio TTUSB10 Turntable
No matter what I do, I can't eliminate the occasional skip...
Try cleaning that lp with an anti static felt record brush, and look for either groove glide or d4 cleaner....Sounds odd, but ive ad records kept in tip top, climate controlled, and funk still gets in the groove.
Oct 29, 2007 | Audio Technica AT-LP2D Turntable
Audio Technica AT-LP2D Turntable Logo
472 people viewed this question
Top Audio Technica Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Paul Bade
Are you an Audio Technica Audio Player and Recorder Expert? Answer questions, earn points and help others
