Question about Daewoo DV-6T955B DVD Player/VCR
Daewoo DV-6T955B VHS/DVD player problem
The player does not start when a DVD disc is inserted. I can give the disc a spin with my finger and it will sometimes start that way. But it's very unreliable.
  • 1 more comment
  • Billc123 Mar 04, 2008
    It was helpful to the extent that the motor starts on its own. At the beginning of playing a DVD the music is choppy then things seem to even out and it plays for 15 minutes or so and then the video will start and stop. Each time it stops there is an audible rubbing noise and sometimes I can actually see the disc slow down. The WD40 did not seem to help as much as a tiny drop of oil worked down the shaft of the motor. Are there sources for the motor? And if so is it an expensive part to buy?
    Bill123
    The player was given to me because it would not play DVD and they thought I might be able to fix it. I do have a bit technical/mechanical/electronic expertise and usually the problem is finding parts rather than fixing something although the tinier components are harder to repair or replace.
    The rubbing sound comes on after 15 minutes or so so I would rule out something being warped. Before I applied the WD40 and oil it would make the rubbing sound in the first minute or so of starting playing.
    Bill123
    Bill
    Thanks. I knew it was a cheaper VHS/DVR player when it was given to me. I saw it as a challenge to learn something new, not something that I really needed. I hate to see something junked that could be fixed. But I am ready to give up.
    Bill
  • 934 Answers
It's likely the spindle motor needs to be replaced. You can sometimes get a bit more mileage out of them by placing a tiny drop of WD40 down onto the shaft below the table and working that into the motor.
Bill
Posted on Mar 02, 2008
  • William Rayburn
    William Rayburn Mar 04, 2008
    Bill,
    There are sources for just about every part in that unit. That said, it's probably cheap enough to simply replace the unit with something a bit more better built.
    The rubbing could be the laser alignment, warp in the play table assembly or railing or any number of possibilities... In any of these events you would need some technical equipment and expertise to repair it and the repair itself is again probably not worth it in terms of cost verses replacement.
    As a point of reference: when DVD's combos first became popular the repairs would consist of anything from power supply to pick-up table replacements. After about 7 years the cheaper ones hit the market and repairs were more focused at components vs electro-mechanical - cost being the issue. Now it's likely that if they are more than 2 years old and/or inexpensive to begin with they're not likely worth the repair.
    Bill
  • William Rayburn
    Bill, as I said it could be a number of things and don't rule-out warping.. The spindle, which is the disc platform that the DVD rides on can tilt or become off-balanced or even slide down further on the spindle shaft causing these problems. We call that warping... Not so noticeable at start-up since the disc is read from the inside out. But as the pick-up table (laser) starts to get further from the center in can begin to rub on the disc itself or on the tray. This is only an example and one of many probablities. Rails are another. We've seen units in here that have had loose rails allowing the pick-up table to rise as it reads further into the disc and eventually make contact with the disc.
    My point is that the people who gave you the unit probably had the right idea - replacement was probably less expensive than repair. That is not a really high-end unit you have there.
    Bill
Daewoo DVD-T "copy not possible - this media cannot be copied" when trying to copy from VHS (tape is not copy protected) to blank DVD-R and +R media. Same problem with all DVDs and VHS tapes
You can only copy non-commercial VHS tapes that you have recorded yourself to DVD. You can\'t make copies of most commercially made VHS movies due to copy-protection.
Dec 29, 2013 | Daewoo DV-6T955B DVD Player/VCR
When a dvd is inserted, "no disc" msg appears in led. I have removed the cover and used canned air to blow out dust, to no avail. any ideas? Linda
Open the top again but use a Q-tip with alcohol and clean the laser. Make sure the dvd is spinning too because it could also be a bad motor.
May 23, 2011 | Daewoo DV-6T955B DVD Player/VCR
When I load a dvd on the screen it shows loading but it never starts to load
try to check if the player can read multi types of dvd disc if not play only the required disk or check the region setting of the player and set it to multi region
May 21, 2011 | Daewoo DV-6T955B DVD Player/VCR
Whenwe try to use dvd it reads bad disc used dvd
Hi did you try cleaning the washer that spins the cd they often get glazed and slip causing the cd to spin at a low rpm causing the bad disc error.
Feb 01, 2010 | Daewoo DV-6T955B DVD Player/VCR
Prgressive Scan
Check with this turn on the combo check there is no disc on the tray push the stop button for 6 seconds
Aug 03, 2009 | Daewoo DV-6T955B DVD Player/VCR
The vhs tape will not eject or play it keeps reading Err.
the sensor that tells the VCR there is a tape in the player is bad or might need alined! (may cost more to fix then a new one!
Dec 08, 2008 | Daewoo DV-6T955B DVD Player/VCR
Bad Disc Error
you want to clean your player lens. with the help of lens cleaner cd! dont use dirty disc inside the player! it spoil the lens!
Jul 07, 2008 | Daewoo DV-6T955B DVD Player/VCR
Daewoo DV-6T955B DVD Player Problem
If your DVD is less than a year old, still under manufacturers warranty.
The problem you have "no Disk" is because the laser is not reading the DVDs.
Call the Main support number at 800-323-9668
Support FAX 973-384-9250
Email support service@e-daewoo.com
Mar 06, 2008 | Daewoo DV-6T955B DVD Player/VCR
Daewoo DV-6T955B DVD Player/VCR Logo
190 people viewed this question
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
