Xantech IR repeater
I have a Xantech IR repeater controlling 3 components. Some times the red light on the IR receiver stays on for a while and during that time it will not receive any signals. I have not been able to reliably repeat the problem and I haven't been able to work out what makes it stop other than waiting for a while. Any suggestions?
  • sburgett Mar 30, 2008
    I have the same problem, but it did not start until I connected a second IR receiver to the same connecting block. Xantech's manual for the 291-10 Hidden Link IR Receiver shows that to connect multiple receivers, you just connect corresponding wires to each other, which is what I did. If I disconnect one of the receivers, the other one functions normally.
  • acg101 Jun 15, 2008
    i have the same problem with a 791 44 amplified connecting block. It is primarily due to sunlight.
Which receiver do you have?
If you have a 29110, it may be that you have a florescent light or natural sunlight interfering. This may also attributed to an LCD or Plasma TV.
If you have a 29180 it may be plasma or sunlight interference.
If either one of the above is true you may want to consider the 29195.
This may also be true with the two receivers connected together.
Hope this helps.
Posted on Apr 01, 2008
Hope this helps.
Will a 3.4 IR remote work in place of a 3.1 IR remote
It should work, provided has setup codes for your device. Check whether there is setup codes for the device do you want to programme with it. You can get this information from the code list of the remote control; you have purchased. If there is no code found, you can just search for a code.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
Mar 30, 2012 | DISH Network IR Remote Control
Tip
Setting Your Timer
1. Move the control lever to the OFF-CLEAR position for about 20 seconds. The red indicator light will go off and any previ- ous time settings will be cleared from memory.
Program Using "Quick" Method:
2. Move the control lever to the ON position. The Red indicator light will start fashing.
3. Rotate the time dial clockwise at least one click, stopping at the half hour nearest to the present time.
NOTE: During programming, be careful not to press the dial while turning it. If you press the dial, you will ac- cidentally set a wrong time.
4. Press the dial once to set the present time. The Red indicator light will go off.
5. Rotate the time dial clockwise to the frst desired ON time. The Red light will pulse momentarily with each click.
6. Press the dial once to enter the ON time. The light controlled by the switch timer will turn ON.
7. Rotate the time dial clockwise to the desired OFF time.
8. Press the dial once to enter the OFF time. The light controlled by the switch timer will turn OFF.
Repeat Steps 5-8 for each additional ON/OFF setting. Continue to rotate the time dial until the Red indicator light comes ON and stays ON, indicating that the switch timer is in AUTOMATIC mode
on Oct 06, 2009 | RTO Intermatic Inc Ej351c Timer Night...
HP TSGH-IR02 Remote Control how to install
This document pertains to HP Media Center computers with Windows XP, Media Center Edition.Use this document when the remote control does not work correctly with the Media Center software.Troubleshooting the remote controlUse the following items to troubleshoot when the remote control does not respond or when the remote control does not work properly. For example, when a key is pressed the selection moves all the way to the top or bottom of a list, or moves a selection many different places instead of the item you were trying to select.Before attempting these steps, make sure that PC has been updated with all of the latest Windows updates. Many updates for Media Center, like Update Rollup 1 for eHome Infrared Receiver, can be downloaded easily through the Windows Update software Tool.
Make sure that the batteries for the remote control are installed correctly and charged.Make sure that the front of the remote sensor is unobstructed, within a 45-degree range, and is less than 26 feet (8 meters) away. Disconnect all devices that use a USB connection except to the receiver, keyboard, and mouse. Restart the PC, and then try the remote again.If a pressed button repeats itself (sticks), unplug the IR receiver from its USB connection, wait one minute, and plug in the IR receiver. If the pressed buttons continue to repeat, alter the lighting conditions in the room or move the location of the IR receiver. Other remotes and HP Media Center PCs within range can also cause this issue.Try pressing the Enter key on the remote after changing a channel.If the remote control works when using the media center software, but does not work when changing the television channels, re-configure the Media Center software settings for the cable set-top box or satellite receiver
Point the remote control towards the IR receiver and press a button. A faint red light should appear on the IR receiver. If the light appears, then the problem is probably in the software that is using the remote control (most likely the configuration of the Media Center software). Close the software, restart the computer, and then re-open the software to solve this issue.
Troubleshooting the IR receiverThe IR receiver is the small device that receives the signals sent by the remote control. Use the following steps to test and reset the IR receiver.Disconnect the IR receiver from its USB port on the computer, maximize the Media Center window if it is open, and then reconnect the IR receiver. Test again.Point the remote control towards the IR receiver and press a button. A faint red light should appear on the IR receiver. If the light appears, then the problem is probably in the software that is using the IR receiver (most likely the Media Center software). Close the software, restart the computer, and then re-open the software to solve this issue.Click Start , right-click My Computer , and then select Properties .Click the Hardware tab and then click the Device Manager button.Click the plus sign next to Universal Serial Bus Controllers.If the eHome Infrared Receiver is listed under Universal Serial Bus controllers, Windows is properly detecting the IR receiver. If eHome Infrared Receiver is not in the list, or there is an exclamation mark or a question mark on the device, perform the following until eHome Infrared Receiver appears correct in Device manager:Unplug the end of the USB cable on the IR receiver from the computer and plug it into the same USB port.Plug the end of the USB cable on the IR receiver into the front USB port on the computer.Disconnect all other USB devices, leave the IR receiver plugged in, and then restart the computer. Plug in other USB devices after the IR receiver shows up in device manager.Figure 1: IR receiver listing in Device Manager
Testing the remote controlUse the following steps to check the responsiveness of the remote control:
  1. Open the Media Center software by double-clicking the Media Center icon the desktop or by pressing the green Start button on the remote control.
  2. Click Settings , and then click General .
  3. Click Check Your Remote , and then click Next .
  4. Press the numbers on your remote control. The corresponding numbers on the numbers on the screen should glow when each button is pressed. A faint red light should also glow inside the IR receiver each time a button on the remote pressed.
  5. Click My control is working properly , and then click Next . Do not click I am having problems with my remote control as this will not do anything.
  6. Click Finish after you are done.
Dec 17, 2011 | HP Computers & Internet
How do I program my remote to my tv without the booklet
Hello
You can do it by code search method.
Try doing a search of the code library for your code by following these steps.
OK.
May 05, 2011 | RCA RCR311B Remote Control
How to program a rca rcr451 remote
1. Manually turn on the component
you want the remote to control
(TV, VCR, DVD, satellite receiver
or cable box).
2. Locate the enclosed Code Lists.
Find the list for the component
you wish to program. Find your
component’s brand. You will see a
listing of four-digit codes for each
brand. If your brand isn’t listed,
use the Manual Code Search
method to program the remote
control. (Refer to page 6 for
Manual Code Search method.)
3. Press and hold the component key
(TV, VCR, DVD, SAT·CBL) you
wish to program. The LED
indicator light turns on and remains
on. If you release the component
key any time during the Direct
Code Entry procedure, the LED
indicator light blinks four times,
and the process is exited.
4. While holding down the component
key, consult the Code Lists for the
four-digit code that corresponds to
your component’s brand and use the
number keys (0-9) on the keypad to
enter it. While you are pressing the
numbers, the LED indicator
light turns off.
5. After the fourth number is entered,
the LED indicator light turns on. At
this time, release the component key.
If the LED indicator light turns off,
you have entered a valid code and
have followed the correct procedure
for Direct Code Entry.
If you enter a code number that is
not in the Code Lists or you do not
follow all of the steps for Direct
Code Entry, the LED indicator light
blinks four times when the
component key is released. This is an
indication that a programming error
has occurred. In that case, repeat the
Direct Code Entry process from step
3 and try the next code listed.
Throughout the programming
of each key, be sure to keep the remote
pointed at the IR sensor of the
component you are currently
programming the remote to control.
6. To confirm that the component key
is programmed with the correct
code for maximum functionality,
test the component. Attempt to
control a variety of the
component’s functions with the
remote. If some of the features of
your components do not work, try
programming the remote with a
different code in the list until you
find the code that allows the
remote to control the majority of
your component’s functions.
Different codes can provide
different levels of functionality.
DOWNLOAD the full manual with codes for free at: http://www.replacementremotes.com/RCA-Manuals/Download-FREE-RCR450C-MANUAL-OPERATING-MANUAL.html
Aug 11, 2010 | RCA Universal Remote Control
Need codes for rcr 460 remote
or cable box).
Note: If you press an invalid key
during the Manual Code Search,
the remote does not respond and
the LED indicator light does not
blink. If you do not press a valid
Manual Code Search key (TV,
VCR, DVD, SAT·CBL, ON·OFF,
GO BACK), the search times out
after two minutes. When the
search times out, the LED
and turns off. The last
programmed code under that
component key is retained.
2. Press and hold the component key
wish to program. The LED indicator
light turns on and remains on.
3. While holding the component
key down, press and hold the
ON·OFF key. The LED indicator
light turns off.
4. After holding down both keys
for three seconds, the LED
indicator light turns back on.
5. Release both keys. The LED
indicator light remains on.
Throughout the
programming of each key, be sure
to keep the remote pointed at the
IR sensor of the component you
are currently programming the
remote to control.
6. Press and release the ON·OFF key
repeatedly until your component
turns off. Each time you press the
ON·OFF key, the LED indicator
light blinks, and the next code in
the list is sent. This process
continues until all of the codes in
the Code Lists have been searched.
If your component turns off, you
have found the correct code. (If it
cycles through and the LED
and turns off, all codes have been
searched. The Manual Code Search
method is exited.)
Press Stop when TV turns off.
Mar 06, 2010 | RCA Universal Remote Control
I need code for rca rcr461 universal remot my tv is a ilo
1. Manually turn on the component you want.
2.Press and hold the TV, DVD etc the illuminated component names turns on.
3.While holding the compnent key down simultaneously press and hold the ON.OFF key - the illuminated name turns off.
4. After holding down both keys for 3 sec, all components name stay on.
5.Release both keys. the component name remains lit.
6.Press and release the PLAY key, wait for 5sec, the component will turn off. If component does not respont continue to press PLAY every 5 sec until component turns off.
7.When the component turns off, then the correct code is blocked. Press REVERSE key wait 2 sec to see if component turns on again.
8. Once component turns on then use STOP key - now code is stored.
Note: use FORWARD KEY AND REVERSE KEY to go front and back on the code search.
(sorry for the typo (if any) I dont have a scanner to scan the manual and I am typing out from the manual)
Feb 13, 2009 | RCA RCR460 Remote Control
Where is the IR sensor on a Bose 3-2-1 Series II?
I believe I've found the IR sensor. By shining a flash light on the various parts of the normally opaque shield over the front of the Bose, I was able to spot what I believe to be the sensor on the extreme right end of the shield, vertically centered. Later today I hope to verify this by connecting everything and using the remote through the Xantech. If it turns out that I'm wrong, I'll post again.
Feb 13, 2009 | Bose (321GS) System
I'm missing the instruction manual for my RCA RCR460 remote control. I need the manual set-up instructions, and a list of all the potential codes to sync up to a Toshiba or Mitsubishi DVD player. Any help...
1. Manually turn on the component you want the remote to control (TV, VCR, DVD, satellite receiver or cable box). Note: If you press an invalid key during the Manual Code Search, the remote does not respond and the LED indicator light does not blink. If you do not press a valid Manual Code Search key (TV, VCR, DVD, SAT·CBL, ON·OFF, GO BACK), the search times out after two minutes. When the search times out, the LED indicator light blinks four times and turns off. The last programmed code under that component key is retained. 2. Press and hold the component key (TV, VCR, DVD, SAT·CBL) you wish to program. The LED indicator light turns on and remains on. 3. While holding the component key down, press and hold the ON·OFF key. The LED indicator light turns off. 4. After holding down both keys for three seconds, the LED indicator light turns back on. 5. Release both keys. The LED indicator light remains on. Throughout the programming of each key, be sure to keep the remote pointed at the IR sensor of the component you are currently programming the remote to control. 6. Press and release the ON·OFF key repeatedly until your component turns off. Each time you press the ON·OFF key, the LED indicator light blinks, and the next code in the list is sent. This process continues until all of the codes in the Code Lists have been searched. If your component turns off, you have found the correct code. (If it cycles through and the LED indicator light blinks four times and turns off, all codes have been searched. The Manual Code Search method is exited.) Press Stop when TV turns off.
Jul 06, 2008 | RCA RCR460 Remote Control
IR frequency determination
The remote could be using RF, which is why your Niles equipment cannot handle it. There is no way to duplicate the RF or convert it to an IR signal.
If the remote is using IR, make sure the batteries are full and the light is low when you are learning the codes with tne Niles equpment. There is no way if it's IR that the freq is > 100.
Apr 22, 2008 | Televison & Video
Televison & Video Logo
520 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
