Question about Chicco 3WD Tech - Canarie Stroller
Fixating mechanism in handle is broken
The airline broke the handle (probably by throwing too much weight on it), and the handle now won't stay in a fixed position (adjusted for height). Since it hangs loose, I cannot push the stroller with one hand (have to use both hands to place above the two buttons, that we press to adjust the handlebar for height). I don;t see any screws around that area to take the handle apart and see if something can be done. Looks like I would have to replace the entire frame? This is a $700 stroller, really would like to keep it around for child # 2 :-)
  • maria Apr 03, 2012
    I have exact same problem now i cant adjust the height. hoping for some answer
  • 749 Answers
I can't figure out where your stroller handle broke! if there's a possibility that you could send me an image (close catch) on the broken part and rear view of the stroller, email it to me in jpeg or pdf type..... here's my email address... jyzomnix1@yahoo.com
we'd like to help you much...
Posted on Mar 02, 2008
  •  Claittymarie
    Claittymarie Jan 16, 2012
    that email its not working! i have the same exact problemmm....
    Sergeant:
    Champion:
  • 209 Answers
Ok, how is the frame broken ?
what is it made off ?
please reply with more info.
  •  Claittymarie
    hiii... i wish u can help me...
    my Quinny Buzz Handle Bar Broke (not the cable!) just the frame!
    here i send you some pics to see if you can help me!
    this is how it looks! the airline baggage broke it....and i need to replace it!
    aprecciated your attention! send me ur mail so i can send u pics of it
    i will b waitting for your answer soon..
    thanks!
    Att: Claitty Marie
What is the weight limit on Spirit Airlines for a check in suitcase?
hi deborah.
Checked bags: Maximum of 62 linear inches (length + width + height; 158 cm) including handles and wheels and maximum of 40 pounds in weight (18.1 kg). Any bag that exceeds these dimensions or weight limit is considered oversized/overweight and has a corresponding charge.
What are the size and weight limits for bags? - Spirit Airlines Support
https://customersupport.spirit.com/.../202096476-What-are-the-size-and-weight-limits-fo...
What is the weight limit on Spirit Airlines for check in suitcase Google...
Nov 07, 2017 | The Computers & Internet
Seat back won't stay up
Probably has a broken or jammed lock When you position the seat try pulling/pushing the handle instead of relying on the spring to engage the lock. If the seat frame is broken remove it for repair or replace with another seat back
Feb 22, 2013 | 1998 Toyota Corolla
Back door won,t open on my 02 avalanche
door handle broke depends on what door handle it is.if door cant be open on out side out side door handle broke.if cant open door on inside inside door handle broke.door handle clip that connects to latch rod broken.when you try open door handle not engage to latch rod.door not going open.have to replace door handle with new clip holds latch rod in place.
Jan 09, 2013 | 2002 Chevrolet Avalanche
1998 Isuzu Rodeo Drivers Outside Door Handle doesn't work
The door skin needs to be removed you will need 1/4" drive ratchet, extensions, metric box end wrenches, a long needle nose pliers, screw drivers,a pro pick set and some mechanical ability, verify the linkage is intact, if it is you probably have a broken handle, if the outer handle is broke E-Bay has them new and used or you can go the dealer route. the time to repair is usually 1 to 2 hours. GL
Aug 18, 2012 | 1998 Isuzu Rodeo
Why does the light / safety switch stay on when the door latches shut ?
Most likely there is a part missing from the door latch mechanism that you need. This probably broke off when the handle failed. It would be a tab or wedge shaped piece of plastic that strikes the door switch and pushes the switch closed when the door is completely shut. You will need to find that piece and glue it back on or get a new handle assembly from Samsung.
Aug 01, 2012 | Samsung Microwave Ovens
Tailgate won't open on my 1995 F-150
Joe, your probably right and the handle is broken, the rest of the mechanism maybe just fine, you should see an access panel that can be removed so you can undo the broken handle and replace it. Hope this helps, let me know
Dec 09, 2009 | 1996 Ford F150 Regular Cab
The liftgate handle broke
It is possible to open from the outside. Remove the plastic piece that broke off from the outside of the tailgate. Use a penlight and you will see the mechanism. Get a small screwdriver and place into the hold...You can feel it spring when you have it in the right place...Push down on the screwdriver to make the mechanism pull the release cable. Make sure the vehicle is unlocked..It should work...My mechanic can open it in 10 secs with this method.
Aug 24, 2009 | 2003 Toyota Sequoia
Rear Seat on C Class coupe will not release think I ned to take the seat backing off to look at the mechanism
i beleive the release handles are in the trunk. Unless the release handle broke or cable is broken it is probably out of adjustment. Try having someone lean into the seat backrest and then pull release handle. I'm assuming your talking about your backrest release. If you are refering to the seat cushion-they can be tough but try putting some weight down on the cushion and then try pulling the release handle at each side of the seat.
Jul 14, 2009 | 2001 Mercedes-Benz C-Class
Malber WD1000
door handle broke at plastic insert. Looking for replacement parts.
Jul 05, 2009 | Malber WD1000 Front Load Washer/Dryer
Broken handle
Ooo, an airline damaged my handle of my Maclaren XT last year. If you go to your local baby shop and ask if they act as Maclaren agents, they can order you 2 new handles, here in Australia they quoted my $39. I had to get my husbands work to pop the existing rivits and then Maclaren supplied screws to attach the new handles sent.
Hope this helps.
Feb 22, 2009 | Maclaren Techno XT Wisteria Umbrella...
Chicco 3WD Tech - Canarie Stroller Logo
393 people viewed this question
Top Chicco Baby Gear Experts
Rommel Balcita
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Chicco Baby Gear Expert? Answer questions, earn points and help others
