Question about Toshiba Satellite M35X-S349 Notebook
Synaptics touchpad not working
Hi i have had my toshiba equiim laptop for 11 months now and it was working fine. It has now stopped working, moving or anything. It stays in the middle of the screen and does not movee even on the startup user page.
My touch pad and buttons stopped working all of a suddent. I have already been to the Device Manager in the Systems folder and everything is in order. I have also been into Program Files and there is a dll that cannot be changed, and there is PadExe file that does nothing. Thanks!
    Problem Solver:
  • 19 Answers
In a TOSHIBA LAPTOP - When the Synaptics Touchpad stops working in Windows Vista. You should download the 'Toshiba Value Added Package' and then launch 'Flash Cards' utility. There is a setting to enable the Function Keys, and thus enable the Touchpad! Voila.
Posted on Nov 16, 2008
    Genius:
  • 3,587 Answers
That can happen..there's a connector under the keyboard, that may have come loose or disconnected
Posted on Mar 02, 2008
Touchpad not active
Press the "Fn" and "F9" keys simultaneously.
Test your touchpad. If it works, it was simply disabled. Press the same key combination any time you want to toggle your touchpad on or off.
Plug an external mouse into a USB port on your laptopicon1.png if the key combination didn't work. Follow onscreen prompts to install the mouse driver--if necessary. You can also move the cursor using the "Tab" key and the arrow keys, as well as click by pressing "Enter" until the mouse is operational.
Click the link in the Resources section if you are using a Toshibaicon1.png Satellite with Windows Vista. Follow the onscreen prompts to download and re-install the driver.
Open a web browser and navigate to Synaptics.com if you have a different Toshiba model or operating system. Synaptics brand touchpads are used in all Toshiba laptops, and this site provides a generic driver.Hover your mouse over "Support" on the top menu, then select "Drivers" from the drop-down menu.
Select your operating system from the list provided and download the generic driver
Follow the onscreen prompts to install your new driver, and then test the touchpad again. If it still does not work, take your laptop to a licensed repair technician.
Jan 06, 2014 | Toshiba SATELLITE 1905-S301 TOUCHPAD AND...
Dell Inspiron N5040 touchpad not working while charging
If battery works and ac adapter has problems that means electrolytic capacitors maybe dried up(not supplying the current needed to run the laptop) and has to be cured by using the laptop more often.
Apr 13, 2012 | Dell Inspiron Computers & Internet
A135-4257 touchpad stopped working
Check to see the make of your touchpad (in most cases it would be a synaptics one.) If so, go to http://www.synaptics.com/support/drivers and download the corresponding driver according to your operating system.
NOTE
I'm assuming you already went through the basic steps such as checking if there's a dedicated touchpad button which might be turned off, checking if from control panel\mouse the device is not disabled, etc.
Nov 13, 2009 | Toshiba Satellite A135-S4527 Notebook
My acer 3690 touchpad not working
HI
go at the manufacture's website and download the Synaptics Touchpad Driver at
http://gd.panam.acer.com/home/
select your aspire model and select the driver your need which is the synaptics touchpad driver
Download it
Run it and reboot your laptop
this should work just fine
Good luck
Jun 30, 2009 | Acer Aspire 3690-2196 Notebook
Toshiba a300 synaptic touch pad scroller stopped working
Hi there.
The touchpad drivers could be corrupt, try reinstalling the touchpad drivers again.
Go here to Toshiba Support fill in the details of your model laptop and download the synaptics touchpad driver and reinstall it, see if that helps.
http://uk.computers.toshiba-europe.com/innovation/download_drivers_bios.jsp?service=UK
Good luck and thanks for choosing FixYa!!
Jun 01, 2009 | HP Pavilion dv4000 Notebook
Synaptics touchpad mouse will not move cursor
Update synaptics driver from Hp.com that should fix the issue
May 16, 2009 | HP Compaq nc6220 Notebook
Synaptics Touchpad Enhancements stops working
Hi!
I resently had the same problem on my HP laptop and search Google for possible solutions. No solution works until I tried Windovs Update and then got 5 alternatives - Synaptics PS/2 port TouchPad was one of them. I update and restart and finally solve this problem.
Terje
Jan 09, 2009 | Acer Aspire 3610 Notebook
Can't set up touchpad,x250
Most laptops work fine with default Synaptics drivers: http://www.synaptics.com/support/drivers
Very useful for people who keep bumping their touchpad with their palm.
Nov 02, 2008 | Toshiba Computers & Internet
Touch pad not working
That's a sign that the synaptic touch pad needs to be replaced. Eventually they wear out.
Jun 13, 2008 | Toshiba Satellite A105 Notebook
Have you looked at the Device Manager to see if there's a problem with the touchpad?
Start -> Control Panel -> System -> click on Hardware tab -> click on Device Manager button. Do you see anything that indicates a problem with the touchpad?
Also, you might want to check the BIOS to see that the touchpad is still enabled. I doubt that this setting would have changed, but it's worth checking. When you boot the computer you should see a message that says something like: "To enter setup press XXX" where XXX is the delete key or some other key. Once you're in the BIOS poke around to see if you can find the settings for the Touchpad. Different manufacturers use different BIOS' so I cannot tell you exactly where to look.
Good luck.
Dec 19, 2007 | Toshiba Satellite A20 Satellite A25 Series...
Open Questions:
See all Toshiba Satellite M35X-S349 Notebook Questions
Toshiba Satellite M35X-S349 Notebook Logo
573 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
