Question about Frigidaire GLTF1670A Front Load Washer
Frigidaire front load washer model GLTF1670ASO
Hi...During high speed spin cycle, the machine shakes, rattles and almost rolls! A loud clanging noise is also heard, and sounds as though solid pieces are hitting each other. Opened the top panel and cant see evidence that anything is loose or worn. Ran spin cycle with top open and still cant see whats causing the noise. Also can you suggest how to determine if shocks and springs need to be replaced.
  • Anonymous Mar 22, 2008
    Exact problem,,it's the bearing, which is attached to the tub, I called Frigidaire, $179 for the part.
  • captdmt Mar 10, 2009
    very loud noise when in final spin sounds like something broke started all at once no noise before no grease leakage from rear bearing, shocks and springs seem alright drum doesn't seem loose
Check the shocks on the bottom of the drum. I had the same problem and had to replace the shocks because they were broken in half.
Posted on Dec 07, 2008
    Sergeant:
  • 351 Answers
Is the inner drum loose check to see if it moves if so may need bearings/inner drum.are the schocks rusty from water leaks.
Posted on Mar 02, 2008
    New Friend:
There is a part called a spider on the back of the tub inside the drum. The spider breaks and the tub needs to be replaced. +/- $250.00. Cannot buy the tub or spider separately. Do not run the machine too long in this condition as there are screws that will cut thru the drum and it will leak and need replaced too.
Posted on Mar 07, 2013
SOURCE:
Kenmore - high pitch noice during spin cycle
Sounds like bearing squeal,providing no leaks or shake leave meantime
Jul 01, 2012 | Kenmore Washing Machines
Water leaking and loud noise and rattling on final spin cycle
Turn the drum by hand and if you hear any noises it is the rear bearing. If there is no noise then remove the front bottom panel and take out the coin trap on the pump and check those hoses.
Eric
Aug 27, 2009 | Whirlpool GHW9150 Front Load Washer
Washing machine makes a clanging sound during agitation/spin
Without being there to physically see what it's doing or hear the sound, I would say there's 3 possibilities. 1) drive block is slipping on basket drive / brake assembly. 2) basket drive assembly is worn where drive block seats onto it. 3) clutch slipping.
Sep 26, 2017 | Whirlpool Washing Machines
Rattling noise during spin cycle
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Nov 12, 2008 | Maytag MAH2400A Front Load Washer
Rattling noise during high speed spin
sounds as if you might have a bad rear bearing, real obnoxious almost painful to listen too kinda sounds. big job, but might have some part warrentee depending on age of unit
Oct 21, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Noisy spin cycle on washing machine
hi there,
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping/or sound
Dec 11, 2007 | Zanussi FLE1416W Front Load Washer
Loud Noise - Spin Cycle
If the washer is making a squealing noise, the problem is more likely to be the basket drive. If it is more like a rattling sound, the centerpost bearings are probably worn out. Open machine's rear panel and spin the basket manually by turning the drive pulley, to find out from where exactly the noise come from. Defective part should be replaced. Good luck !!
Jun 29, 2006 | Kenmore 43042 Front Load Washer
Frigidaire GLTF1670A Front Load Washer Logo
2,059 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
J. Bradshaw
Archie Ferrarini
Archie Ferrarini
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
