Question about Whirlpool Duet GHW9150P Front Load Washer
Control Locked I was going to dry a load of clothes, but the only light on is "Control Locked." I don't know how to turn it off. I tried unplugging the dryer, but when I plugged it back in, the "Control Locked" light was still on. This dryer is less than 2 years old. What does "Control Locked" mean?
  • Anonymous May 21, 2008
    same problem
    President:
  • Whirlpool Master
  • 2,651 Answers
Push and hold in far right button on conrtol panel( look closly you see control lock) hold for 3 secs and it will turn off
Posted on Mar 02, 2008
    President:
  • 1,294 Answers
It is to prevent children form meddling with the machine.
Posted on Mar 16, 2008
I purchased a new WED9400SU electric dryer and it work fine for a few cycles but all of a sudden the start button does not light up and therefore it will not start no matter what I do. I've unplugged all...
alright, make sure that the door switch/sensor isn't broken and that it is closing all of the way. Try turning the dial on the dryer around a few times and seeing that it clicks and try it in a different cycle and see if it starts.
let me know if this still doesn't work and we can try a few other things. If it is new and you find something that is damaged then it can probably be taken back and swapped. Also, your warranty might also cover a house visit to check it out if it still won't work after doing the above which I would look into by giving the place a call.
Please let me know what you do and check and whether it helps or not and I will give you a few other things you can do, thanks
May 12, 2008 | Dryers
How do you dry clothes in this machine please
A fairly common problem! The official instructions are
Before using your dryer, wipe the dryer drum with a damp cloth to
remove dust from storing and shipping.
1. Load clothes loosely into the dryer and close the door. Do not
pack the dryer. Allow space for clothes to tumble freely.
2. Turn the Cycle Control knob to the recommended cycle for the type of load being dried. Use the Energy Preferred Automatic Setting (,) to dry most heavyweight and medium weight loads. See "Drying, Cycle, and Temperature Tips."
3. Select a temperature setting on models with a Temp/Fabric selector. The cycle descriptions include temperature setting suggestions.
4. Push the START button.
Stopping and Restarting
You can stop your dryer any time during a cycle.
To stop your dryer
Open the dryer door or turn the Cycle Control knob to OFE
NOTE: The Cycle Control knob should point to an Off area when
the dryer is not in use.
To restart your dryer
1. Close the door.
2. Select a new cycle and temperature (if desired).
3. Press START
Extracted from
http://www.manualslib.com/manual/511763/Whirlpool-Lte5243dq.html?page=10#manual
Nov 14, 2015 | Whirlpool AWZ410 Front Load Washer/Dryer
Clothes aren't drying...
First check and clean the lint trap. Next turn on the dryer and go outside to the dryer vent and make sure you have good airflow coming out. If you don't have good airflow then there is a blockage in the vent system somewhere.
Jul 26, 2012 | LG DLE7177 Dryer
I own a 4 yr old whirlpool duet dryer and controls locked light came on and can not get it to go off
Look for the End of Cycle button at the extreme right hand side of the console then press and hold it for 3 seconds or until the Control Locked light turns off. The instruction is actually printed right below the button. The control lock is a safety feature of the dryer to prevent settings manipulation during the drying cycle.
Unplug the dryer for at least 15 minutes to reset the central control unit if the control cannot be unlocked using the End of Cycle button. Let us know if it's still cannot be unlocked even after the machine is unplugged.
Apr 11, 2010 | Whirlpool GEW9250 Electric Dryer
Hi I am trying to clean my drain unsder my washer. I do not know how to pull the cover off.?? It appears I need special alan wrenchs for two little screws..?? any ideas??
Though the idea of repairing a clothes dryer can be pretty intimidating, the truth is that some types of repairs are surprisingly easy. Yes, dryers appear to be built like huge, impervious metal boxes, but they are typically pretty easy to open and relatively simple to fix.
As shown at How Clothes Dryers Works, a clothes dryer has a motor that turns a big drum containing the clothes, a heat source for blowing warm air into the drum to dry the clothes, and controls for operating the motor and heat source.
Some dryers have an electric element to do the heating while others utilize a gas flame; the latter must be vented.
Clothes dryer problems generally occur because the heat source doesn't heat properly or the motor fails to turn the drum.
If a gas dryer doesn't dry properly, the first thing to check is the pilot light or igniter--it may not be lighting the burner. The second thing to check is the dryer's vent-if it is clogged with lint, the heating system won't work properly.
Pay attention to basic safety measures when working on a dryer. Always unplug the dryer, and turn off the gas supply to a gas dryer at the appliance shutoff valve.
As with most appliances, maintenance will keep your dryer purring. Clean the lint trap after every load, and clean the vent system once a year.
Dec 13, 2008 | Whirlpool LTE6234D Top Load Stacked...
Whirlpool duet dryer
Activate the diagnostic test mode.
1. Within 5 seconds, press more time-less time-more time-less time.
2. All indicators should now be on and "88" displayed.
3. Press dryness level button. All LEDs in group should turn off.
4. Press control on button. Control locked should turn off.
5. Open door. Press cancel.
Oct 01, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Control lock stays on and nothing else works on the panel. No other lights, no other controls. Disconnected power overnite but nothing changed.
The sound button is the button that you wish the sound to go on when the load is finished drying. Thanks for the advice, I was worried I just bought them and already broken.
Nov 17, 2007 | Whirlpool GEW9250P Electric Dryer
Whirlpool Duet GHW9150P Front Load Washer Logo
247 people viewed this question
Dan Webster
Dan Webster
Sal De
