Question about Toshiba Satellite A105-S4004 Notebook
Laptop will not stay powered on.
My laptop will not stay powered on. If I move, the lapdown shuts off. The battery light is orange. I purchased a new power adapter because I thought maybe my adapter had a shortage, but I still have the same problem.
  • rodza1 Mar 02, 2008
    Yes our laptop also a toshiba satellite has the same problem.We replaced the power adapter and leads which made no difference.Also purchased a brand new battery for laptop which also didn't help.The fault is inside the laptop itself,with something to do with the main power board.We have been told that to have it fixed it needs to be sent back to toshiba.
    Genius:
  • 3,587 Answers
Try this without the battery installed, just to make certain that the power supply is working.
then, on some batteries, there is a button on bottom, with a scale for reading the charge level.
check on that, you may find the batteries really weak or fully discharged, which can make the laptop work oddly.
check your computers warranty here 4 FREE
Posted on Mar 02, 2008
I have dell c840. Suddenly only the left most light of the three lights gets orange when power is switched on and then there is no activity and screen remains blank. Bty light when plugged in also remain...
hello
shut down computer - unplug power cord from laptop - remove the battery from laptop - plug Ac adapter into computer and Ac outlet (wall)
turn on computer
if computer does not turn on, replace the AC adapter and cord - then place battery back into computer
plug in new Ac adapter and cord - recharge battery - if orange light stays on after 4-6 hours of charging battery, you need new battery as well - replace battery, charge it up and it should be fine
if you have attempted these steps before and no change occurs, then you may have issue with power connection in computer - locate a service centre to replace power connection on computer
Nov 07, 2010 | Dell Computers & Internet
Dell Inspiron 1525 laptop, no power light, battery light flash orange, wifi light flash blue and orange I bought the Dell Inspiron 1525 laptop in 2008. I use the laptop as a desktop, so I never plugged...
Since it sounds like an issue with the Power first try to release flea power.Disconnect the charger,remove battery,press and hold down the power button for 30 seconds.Reconnect the battery and charger.Turn on system and check if it turns on. For further help please check Dell Inspiron 1525 Manual. Also confirm if the light on the charger stays on,when connected to the system.
Mar 06, 2017 | Dell Inspiron 1525 Notebook
Compaq Presario laptop C300 - issues (orange light)
Sometimes when a PC gets stuck in hibernation mode, the only way to reset it is to remove the CMOS battery for 10 minutes and replacing it. It resembles a large watch battery and is usually located near the center of the motherboard.
Dec 16, 2009 | HP 435768-001 - Compaq Presario C300...
Laptop shuts down when moved around. I have a Toshiba A135-S4467 and yesterday when I went to pick it up and set it on my lap it shut down leaving the power button flashing orange. when I pressed the...
Sounds like a Battery - AC Adapter problem. Do you have an Icon showing your battery level?
Do you have Windows XP? I'm guessing you do because of the memory upgrade.
If you have XP, go to Control Panel - Power Options and check you battery. Choose to show in task bar.
If you have a AC Adapter, the BIOS on your laptop will NOT charge the battery, but it will show that you are on AC (unless it's completely dead)
I'm guessing that if you only had 1g of memory, you have a pretty old laptop, and you probably should purchase a new AC Adapter, and a new Battery.
Apr 09, 2009 | Toshiba Satellite 1805-S274 Notebook
I bought a new battery, laptop won't boot
The new battery is defective - It needs to be repacked. If you're still close enough to date or purchase(even for an ebay purchase), you should be able to do a swap.
Feb 10, 2009 | Acer Aspire 5050 Notebook
Orange blinking power light on inspiron laptop
I recommend purchasing a new Dell Inspiron battery.
The code 4 blinking orange or amber and one green, means a defective battery.
Thank You, Raphael
Jan 24, 2009 | Dell Inspiron 5160 Notebook
My Dell Inspiron 8200 won't boot up. The battery is dead (the latch broke shortly after purchase), and the laptop is plugged in to the wall using the original power cord. There are three indicator lights...
Since it has sat dead for so long, it's certain the bios battery is drained. The bios battery is a small rechargable Nimh inside the laptop, and if you leave the laptop plugged in for a day or two it may come to life for you. I can't say for sure though if that battery will prevent the unit from booting at all or not, but I would try it.
Dec 15, 2008 | Dell Inspiron 8200 Notebook
Laptop won't turn on/stay on
Is the fan blocked?
If no air goes in, CPU could overheat.
Aug 26, 2008 | Toshiba Satellite 1135-S125 Notebook
Open Questions:
See all Toshiba Satellite A105-S4004 Notebook Questions
Toshiba Satellite A105-S4004 Notebook Logo
87 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
