DVD home theater system
Phillips HTS3400 - Insert disc and it reads 'no disc'. Have used cleaner per Phillips. Pushing play doesn't do anything, still reads no disc. Any help?
  • Parisattic Mar 15, 2008
    The can of air followed by the disc cleaner did restore the DVD's capabilities! yeah, but the tv screen now says 'no sync detected.' It's wired correctly and on the correct source. The blue screen actually went out when I followed the manuals instructions of pressing open/close on the DVD player and #1 on the remote. Poof the blue screen was gone and the same procedure does not bring it back. Phillips doesn't have a clue. Any solutions? Am referring "FixYa" to all my friends.
  • Anonymous Mar 28, 2014
    it doesnt want to play anything with dvd
    Problem Solver:
  • 3 Answers
Disc is either to scratched or may have a hairline crack on disc. If this happens to all of your disc's, then you have a laser read problem. This can be caused by high humidity as well as dust and debri. Try blowing the unit out with canned air.
Posted on Mar 10, 2008
My Phillips HTS3400/37 Home Theater System came with a remote control, as usual, but it just has stoped working.. I've been trying to make it work by replacing the batteries and it still appears to be...
Try this first on the original remote. Insert the batteries backward and make sure that they make contact with the terminals in the remote control(stick a piece of metal in there to make sure all the posts make contact), then take them off and install them correctly and see if it works, it's a long shot but i've had some luck using this method. now, for the question regarding if the new remote will work, well, i couldn't find the correct code for your receiver using the RCA universal control. The receiver brand(Phillips) is not listed so it probably won't. Here's the RCA control's codes. Just copy and paste the link. http://www.remotecodelist.com/remotes/rca/rca_rcu404.html
Aug 23, 2011 | Televison & Video
"No Disk" message
Your dvd lense need cleaning .
For that buy lense cleaner disk from nearest computer shop then put that disk into cd/dvd rom then play it then it clean dust from lense then you can use it again .
But if still same issue then you need to replace your dvd lense .
Let me know if you need further assistance.
Thanks for using FixYa.
Feb 24, 2010 | Sony Bravia DAV-HDX265 Theater System
Philips hts3400 will not play dvd
first clean the laser lens if this donçt solve the problem change the motor disc spindle because are on bad conditions
Jan 09, 2010 | Philips HTS3400/37B System
Does not read dvd
Your problem is that you bought a Phillips instead of a Sony.  Quality vs. Quantity my friend.
Anyways, your DVD player is set up to play region 1 and the disc you inserting is probably some other region.  Look on the back of the DVD case and it will say what region you can play the disc on.  Also, clean off all the smudge marks on the disc with some glass cleaner and this disc won't play if you got a lot of scratches on the thing.
If the above didn't help, then your fuc..d, cause your laser pickup is dirty or defective.  Run a DVD laser cleaning kit through it, which is available at all the big box stores.  See if that helps out any.  If not, then your truly fuc..d and you need to call the manufacturer if this thing is still under the 1 year warranty.  If your under 30 days, then just take it back to the store and exchange the thing out.
Oct 26, 2009 | Philips HTS3400/37 System
Panasonic sa-ht95 dvd home theater sound system no read discs.
You might try taking the back off and using a can air on it.do not use the can of air up close. Use it in short bursts. Also use a dvd cleaner the laser eye may be dirty. You can clean it off with a q-tip and alcohol. Make sure it is dry before use. Wait at least 5 minutes to be safe. Un plug it first. Be careful not to touch anything in there especially the boards, They are sensitive to electricity in your body. Most techs wear a static wrist starp.
Jul 19, 2009 | Panasonic Home Theater System System
What recordable dvds will play in philips HTS3400??
it might be the programs your using to burn your dvds try using windows dvd maker if you have the operating system vista or convert x to dvd if you have xp that should work
May 30, 2009 | Philips HTS3400/37B System
No Disc
Run a dvd cleaner through system, and try again. If that fails, unplug the HTS from the wall outlet for 10-15 seconds, and replug it. If that fails, it will need to be repaired.
-Tha Mp3 Doctor
Feb 08, 2008 | Philips HTS3400/37B System
Reads NO DISC Philips HTS3400 Home system
-Tha Mp3 Doctor
Jan 27, 2008 | Philips HTS3400/37B System
Insert DVD and screen says "No Play"
try to clean first with lens cleaner
Jan 04, 2008 | Sony DAV-BC150 System
Computers & Internet Logo
123 people viewed this question
David Payne
David Payne
