Whirlpool washer Hi, I have a tenant with a whirlpool washer that will only allow the water to fill up to the small load setting. It doesn't matter which load size she selects, it only fills to the small setting. It washes perfectly fine and does not over flow. What could be the problem? Thanks so much for your advise. Angela
  • Angelatee Mar 03, 2008
    Thanks so much for your speedy response!
  • 770 Answers
The Pressure switch is bad (also called Water level switch) there is a small hose from the tub that runs up to it ..The tub will need top be empty when this part is changed
Posted on Mar 03, 2008
  • Gary Davd
    Gary Davd Mar 03, 2008
    No Prob let me know if you need anything else
Whirlpool washer letting both cold and hot water in when I only ask for cold water...
The water valve is working. It only does as told. Faulty water temp switch or yank out the small board and clean the terminals then re insert it and see if maybe corrosion was all that it was. That is what I would try if it was mine.
Dec 22, 2016 | Whirlpool Washing Machines
Washer only fills on rinse like it is on small load no matter what you put the selector to. This is only on rinse< wash works normal
If it is the whirlpool low water high efficiency washer purchased in the last 3 years. That's how it works. On the lid some models even show a picture to explain this or also look at the owners manual.
Nov 06, 2015 | Whirlpool Clothes Washer Control Panel -...
My Whirlpool Ultimate Care II Washer doesn't stop filling with water
If this only happens when the machine is turned on,the tube from the tub to the water level switch is pinched or broken. If the clear plastic tube is not pinched or broken,the water level switch in the control console is bad. If the machine lets water through when it is in the OFF position,the water valve where the hoses connect are bad.
Dec 27, 2012 | Whirlpool Ultimate Care II LSQ9564J Top...
MY whirlpool WASHER MACHINE FILLS WITH WATER BUT DOES NOT WORK AFTER THAT. IT DOES MAKE SMALL NOISE LIKE MOTOR BUT DOES NOT WORK.
Maytag LAT3600A Top Load Washer
1 Points
Nov 27, 2012 | Maytag LAT3600A Top Load Washer
I set the water temp setting to cold, but it keeps filling with hot water. No matter where I set the dial, it fills with hot water.
check whether the hoses are mismarked when they come out of the wall.
the same thing kept happening to us (whirlpool cabrio) and i checked the temperature on the hoses coming out of the wall - cold was mislabeled as hot by the builder, and vice versa.
Aug 31, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
How do you set the Cabrio to wash a small load?
this one only has 1 setting on water level. same size uses same level
Feb 25, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool washing machine (WTW5200SQ0) temp problem
I turn off the cold water during the fill up, and then turn it back on after it has filled. I hate this washer too because of that.
Jan 07, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
77 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
