Question about Hyundai ImageQuest L50S 15" LCD Monitor
Flickers and goes black
When you turn it on it flickers for a millisecond and goes black. It doesnt flicker white or anything its trying to work but it will only stay on for a second. I was doing a little research and I think it may be the backlight. Is this my problem and if so where do I get one and how much? Thanks
  • 558 Answers
No it is not a backlight it is the inverter board which sends power to the backlight most likely cause is bad capacitors on the inverter board. this wil require soldering to repair backlight is even worse it requires you to disassemble the lcd unit. if you are gong to ope up the lcd monitor look on all pcb boards for deformed (blown) capacitors replace those with identical ones from yur electronics shop9they must be exactly the same mfd (Microfaradays) and Voltages
Posted on May 08, 2008
Lights flickering
You could have a loose or a burned wire connection at the switches. If there is more than one thing not working correctly unplug the unit and check the black wire from the lead in cord. It goes to the switches and jumps from one switch to the next. That's where I would look first?
Feb 20, 2014 | Star Kitchen Appliances - Others
HP5066 flickering
Return it to the dumpster. It is a lost cause.
May 03, 2017 | Televison & Video
I have an HP compaq presario cq71-230sa. Laptop worked fine a few hours before, and then when I lifted the lid, the screen was black with 2 lines of white dots running down the left hand side, and the...
Can you check the function buttons and make sure the primary display is set to show the output on the laptop. Try repairing your OS. If not then re-install the os. As you are saying till the time windows gets loaded, all works fine so it seems the issue isn't really the hardware.
Jul 18, 2011 | Compaq Presario 700 470024-192 Notebook
Screen flickers black and white when i open game
use a can of air duster to clean ur game. If that doesnt work try getting a new game.
Feb 06, 2010 | Ubi Soft Entertainment Assassins Creed:...
White horizontal lines flicker and screen goes off.
check the wiring inside the monitor, pull the sceen out and move the wires with the screen on so you can see when it's working. then tape the wires where it works.
Dec 16, 2009 | Proview PL926WBi 19" LCD Monitor
Monitor flickers then goes to black/blank screen.
have you tested it for gone conponments
Aug 14, 2009 | Computers & Internet
Flickering Black and White Up and Down
press PAL/NTSC from your remote or from dvd player.
May 30, 2009 | GPX D2816 DVD Player
Dell monitor is flickering
If you have another computer, try hooking to it and see if it flickers on it too.
If you hit Ctl-Alt-Delete and choose Task Manager, does the box flicker there?.
Adjust the monitor ratio in the Display Settings/Display/ Display Adapter Properties, Monitor Tab, see drop down (increase screen refresh ratio to higher number).
Nov 10, 2017 | Dell E207WFP LCD Monitor
Acer al2002w flickers and goes black
Hi....there,
Well, you've got a busted backlight inverter... Need to replaced a new one...
Nov 30, 2008 | ViewSonic VX2025wm 20.1" LCD Monitor
Notebook lcd screen flickers and goes white
The refresh rate may cause this problem sometimes...
Try this
Right-click anywhere on desktop->Properties->settings tab->advanced button->monitor tab->screen refresh rate drop down list..Chose the refresh rate at which the screen will not flicker(try em' one by one)
If it doesn't work please post a comment and await reply before rating...
Oct 19, 2007 | Audio Players & Recorders
Hyundai ImageQuest L50S 15" LCD Monitor Logo
442 people viewed this question
Top Hyundai Computers & Internet Experts
Marvin
Marvin
rhodesworks
Randy Schumann
Randy Schumann
Are you a Hyundai Computer and Internet Expert? Answer questions, earn points and help others
