Question about Dell 1704FPTt 17" TFT LCD Flat Panel Monitor
No power.
how to remove cover?
    Novelist:
  • 138 Answers
I used to repair LCD monitor from Dell. There are 4 screws for rear panel and no screw for front frame. If there is no visible screw, you have to look for "capped" screw holes (little covers that fit flush with the case to hide the screws). If you don't see these neither, this must be a tension fit case. So, face the screen up and look for "rectangular hole" on the side edge (usually at the bottom edge of the screen). This will be a challenge to open without breaking it. You'll need a very thin flat screw driver and wedge it into that narrow rectangular hole. You can use any prybar if you don't have screw driver. It is not too deep. You may stab something important inside and pry it. Once it starts to spread, start sliding it along the seem and you should feel the tension tabs start "popping" open. Continue to work your way around until it's off. Hope this will help you to get the rear panel off. If there is anything I can help you with, feel free to let me know.
Thank you,
Posted on Mar 18, 2008
Hi this is moiz khan from jeddah, Saudi Arabia as you know latest flood in jeddah on 26 january,2011 we suffer almost we have computer shops our shops almost drown in the water we need your help some LCD monitor went water inside monitor please help me how drythe lcd monitor
Posted on Jan 28, 2011
Usb ports dont seem to work
In order for the usb ports to work you must have 1 usb from the computer connected to the monitor. The monitor may have a specific input port from the pc in order to activate the other ports on the monitor
Mar 22, 2014 | Dell 1704FPTt 17" TFT LCD Flat Panel...
Hit power button, powrers up for a few seconds, then goes off. Dell 1704FPTt Flat Panel.
Please see my pictures here and look for bad caps as shown in my pictures.
http://s807.photobucket.com/albums/yy352/budm/Dell%201704FPT/
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed DELL monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Replacement board: http://www.lcdrepair.us
Nov 10, 2010 | Dell 1704FPTt 17" TFT LCD Flat Panel...
The monitor went dark, seems to have no power.
Totally darken the room your computer is in, and see if you can see a very-dim image on your computer.
If so, it could be the "inverter" part inside the LCD that has failed (about a $20 part, but will take a technician about $50 to $75 to disassemble/replace/reassemble/test).
Try connecting the monitor to a different computer, to see if the monitor is OK.
Try connecting a different monitor to your computer, to see if the video-card is OK.
Jun 23, 2010 | Dell 1704FPTt 17" TFT LCD Flat Panel...
Why don't the ports on the monitor work?
This monitor has 8-port USB hub that the USB input of the monitor must be connected to the PC USB port. There are fuses for the USB port also to protect the 5VDC output at the USB ports.
Document:
http://support.dell.com/support/edocs/monitors/1704fpt/en/about.htm#Specifications
May 12, 2010 | Dell 1704FPTt 17" TFT LCD Flat Panel...
My Dell flat panel monitor #1704FPTt will not stay lighted for more than 1 second. It started fading when first turned on about 2 weeks ago, otherwise it has been fine. Can it be fixed (it is about 8 years...
Fist place to check will be the power supply, look for bad caps with bulging tops, check to see if you do have 12vdc feeding the back light inverter circuits, see example of failed monitors (90% are due to bad caps): http://s807.photobucket.com/home/budm/allalbums
Jan 20, 2010 | Dell 1704FPTt 17" TFT LCD Flat Panel...
No Power LED and Nothing on the screen
Check your power supply to your screen cause it should at least show a amber light at the screen to show that there is power but no proper signal from the computer.
So below are step to check the power supply to your monitor. Assuming if you use a different monitor on your pc it works
1. Check your fuse both internal and external
2. check if power is receipted by the LCD
Mar 24, 2008 | Dell 1704FPTt 17" TFT LCD Flat Panel...
Dell 1703 FPi 17" TFT LCD Flat Panel
you have snap frame around the screen itself use flat screw driver fine edge, theres about four locations that snap into slots work them away and remove frame, then remove screws on back will seperate ,you will have to remove monitor button panel board to, once inside, four screws around screen itself once in side,this will lead you to power connection inside main screen frame, the board and the connections
Sep 06, 2007 | Dell 1703FPt 17" TFT LCD Flat Panel...
Dell 1704FPTt 17" TFT LCD Flat Panel Monitor Logo
404 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
