Home | Coffee and Espresso Makers | Espresso machine pro...
Problem for Coffee and Espresso Makers
Generic problem for all Coffee and Espresso Makers
Espresso machine problems
By Pappadunk on Mar 02, 2008
I have a Faema, two group head machine, I believe its a E87. Hard to tell, markings are worn. Anyway...I had trouble with the auto fill water valve. It was opening, however no water was passing trough. So, I took apart and cleaned the valve. It did have a lot of calcium build up that was clogging the ports. Great, found the problem, however now I have another. I put it back together and now water trickles by (uncertain, which port) eventually filling up the boiler causing it to overfill the boiler. So consiquently water leaks out of the pressure relief valve on top of the boiler. The valve has three seats with springs, so is it possible I crossed any of the parts? Do you have any suggestions? Should I replace all the parts in the valve? And if so, where could I purchase the parts? I would also like to find a manual... This would help out also. Your help is greatly appreciated. Rick
Same Problem
Jan 28, 2009
-   I love my Rancilio.. It is wonderful.  Last night I was up way late, & I went to go & make a shot of Expresso, & the Digital Thermometer is stationary.  It is not blinking as it should be.  Please help me!  I need my Expresso!!!  I have three kids, & my Hubby is away in Iraq!  I NEED MY EXPRESSO!!!!! -   amshodgin
Solution #1
posted on Aug 20, 2009
Not Rated)
toantantan
Rank: Apprentice
Rating: 0%, 0 votes
I had bought coffee machine FrancisFrancis! X2 Espresso & Coffee Maker.When I turn on two group not heating up,I try wait about 15 minute but it reached temperature not yet,i checked every thing,however evrything is ok but gren light didn't come on.Please help me,show me how i can fix it.Thank's alot
Was this helpful?
Yes
No
Solution #2
posted on Mar 02, 2008
Not Rated)
Trifect7
Rank: Guru
Rating: 90%, 107 votes
You may want to have a close look at the seats. There may have been irregular wear on one or more causing the leak. Try and make sure each one is back in its original location.
http://www.faema.com/eng/contatti_rete.asp
Found a manual for you (closest match) It's only for a Faema Family. Well, what the heck, it's free!
http://picasaweb.google.com/Grendelpics/FaemaFamily
Hope you come right, cheers.
Was this helpful?
Yes
No
Popular Solutions for Coffee and Espresso Makers
Questions and Unsolved Problems for Coffee and Espresso Makers
Answer
Where in North-Central London can I purchase a replacement gasket for a 1-2 cup vigano stovetop... (More)
Answer
Need an instruction manual for Krupps espresso machine Type 992
Answer
how to clean the thermal pot. coffee stains in metal don't come out. also pouring water into the... (More)
Answer
I have a delonghi magnifica rapid cappuccino machine and the 2 green cup lights keep flashing why?
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Coffee and Espresso Makers:
Top Coffee and Esp... Experts
Rank: Guru Guru
Solutions: 632
Experience: im jack of all trades but a master of none! and being an old f*rt you get to learn a fair old bit
Ask Me
Find more Coffee and Esp... Experts
Top Small Appliance Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
