Stop 0x0000007F Error - it indicates that there might be something wrong with the hardware of your computer and usually has something to do with the MEMORY ,motherboard . To fix this try to check and see if you have downloaded and installed the most recent BIOS and driver updates, check to see if the memory installed in your computer are at identical speeds. it can also be because of registry problems so try to perform a registry scan.
You are having a non compatible memory frequency. foe you to stop having blue screen of death, you should ensure that the memory frequency matches the MOBO frequency. sometime you can change the settings in certain BIOS by pressing Del key.
Have you re-installed Windows after you installed the new motherboard?
