Question about Intel Motherboard
Mother board driver issues
I went in to change the boot seq. I disabled the mother board, now the mother board is not reconizing the montor, so it won't allow me to boot up windows with my disk what do I need to do? Thanks Ziggy
Please Iwant web site for software msi 7309 ver 1.0
Posted on Apr 09, 2008
Msi motherboard supports amd9500+ procecers
  • 32 Answers
Don't panic. If you take the cover off the side of the computer and look at the motherboard you will find a jumper that says cmos. You can switch the jumper and wait a minute or so then switch it back and it will boot up its defaults. If you cant find the jumper just take the battery out of the motherboard and wait a couple minutes and then put it back in. that will do the same thing and it should boot up fine.
Posted on Mar 02, 2008
HARD DRIVE NOT RECONIZED , SOMETIMESIT SHOWS IN BIOS SOMETIMES IT DOES NOT
First please try to connect this hard drive to other computer and check if it working fine there or not. Then, take your decision of purchasing a new hard drive. It could be an issue with the connecting point between hard drive and mother board.
Jun 03, 2013 | Computers & Internet
My vaio screen is green with green lines and multi colors
Try booting in VGA mode to disable the Nvidia drivers, see if this works ( also try safe mode)
Try connecting to an external monitor, see if lines vanish
If the problem goes away in vga mode, Nvidia drivers are the problem
If the problem remains on the external montor, the issue is with the graphics chip
If it vanishes using an external, issue is with the screen being damaged or vga cable damaged
Jan 11, 2011 | Sony VAIO Notebook
Will not boot cannot get to safe mode if I do a recovery will I lose all data files, not going to do advanced
from my exp recovery CD is of no use at all....if ur OS is corrupted.....use a WinXP install CD and boot from that. to do that...insert the CD in the CD/dvd drive and switch on...if the boot seq in BIOS is set to CD drive then it will boot first from that else it will boot from HD...so if u can get into BIOS by pressing the F1/F2/Del key etc and change the boot seq to the foll:
1st boot CD rom
2nd boot Floppy
3rd boot HDD0
u can even just disable 2nd and 3rd apart from keeping 1st boot to CD rom
if u have more than one HD or more than one partition in ur HD then u can install a new fresh Win XP in that and once that's done then change the boot seq back to HDD0 from CDROM drive in the 1st boot order
it will get back ur machine live then u can copy all ur imp files to a pen drive or CD then once u r safe of ur data u can do a low level format of the full HD and then aprtition that as per ur requirment
Feb 11, 2010 | HP Pavilion a1610n PC Desktop
Can we install fedora 11 on Intel d102gcc2 mother board ; I tried couple of time earlier to install various fedora versions , but all went in vain, I think the problem is with sata drivers , please advice!
If you've used live CD Boots, you could try and add nomodeset to the kernel line in the grub boot menu. This would disable kernel mode setting, which causes problems on some graphics cards.
In the BOOT Menu, Press TAB while highlighting "BOOT" Option
Just add "nomodeset" to the end of the text..This disables Kernel Mode Setting and F11 will be up and running....
Oct 21, 2009 | fedora Linux Operating System
I have a HP PC. the compouter does not boot. A vendor tested it and said the sound card is gone bad. The sound card is on the motherboard. wat to do?
Unless you love this computer you have to take this mother board to the manufactuer for componant repair.
Could be anything. Diode issue or transister unless you have the schematics for this item you can fix it your self and test, however if you don't love this mother board as you do... might just have to replace the mother board
Sep 07, 2009 | Computers & Internet
AMD Motherboard with, on board video card has voltage short no video available on monitor. I would like to disable and add a AGP card.
When the Computer is off install the AGP card and put it together next start the computer when it starts up hit Del key before it boots up go into bios go to devices and disable onboard video, then hit F10 say yes to save changes and reboot it will then detect the card and will ask for drivers for the card. Be sure you read the directions for the video card You may have to install the drivers first, since you did not mention the card brand names and what mother board you have. Asus has many mother boards.
Jul 09, 2009 | Computers & Internet
Comp not reading montor
It sounds like the on board video has failed. I would try installing a video card on the motherboard. Then in the bios at start up, disable the on board video, so it will use the video card instead.
I hope this helps and thanks for using FixYa,
Eric
Jan 25, 2009 | eMachines T6534 PC Desktop
Graphic Card
jumper settings for old graphic needs to be disabled or in the bios settings the on board vga settings need to be disabled this will allow the other new card to be ran as the dominent only video card
jumper settings are tricky
but bios settings are easy just find vga and disable on board video thats it save and boot
Jun 04, 2008 | E-Machines EMA IMPERIAL GV (845GV) TG3...
No Beep but boot up fine
possibly the on board speaker is disabled in the BIOS ?-
May 16, 2008 | Intel D865GBF Motherboard
MY MONTOR HAS POWER AND IS NOT WORKING.
Hi, dont loose faith. If you look on your mother board along the edge closest to the front of the case you will see a series of pins, usualy about 10 pins. Printed on the board will be the names of the plugs that match. The wires from the front of the case have corresponding names. The power and reset switch will work no matter witch way around you put them. The HDD led and the pwr led will only work one way so if these lights dont work, just reverce the plugs. If desperate you can bridge two pins together at a time until you get the on/off switch. Note you cant hurt anything unless you use a hammer. Regards mistyman
Sep 03, 2007 | FIC FR33E Motherboard
Intel Motherboard Logo
170 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
