Question about Coby TF-DVD7005 Portable DVD Player
Porttable dvd player
When we put in a dvd it says loading then it says wrong disc have tryed music disc same thing have read the manual have not come up with anything to fix problem
  • 57 Answers
If the manual have not come up with anything to fix that problem, you may want to try a CD/DVD laser cleaner for it.
If you still have problems, please contact the following website:
www.cobyusa.com
If you the website does not give you solutions, you may want to take this product to a customer service representative or something.
Posted on Aug 03, 2008
My dvd player has just stopped playing disc's? I insert a disc, it loads up as the little circle comes up, saying loading. Then it says bad disc.It stops. Does anyone know what could be wrong here?
Couple things could be. I've found : the disc can be dirty, wipe it off. Or if its damaged the lens won't read it.
What usually helps the most is to put a lens cleaner in the player. they sell them. I only have a CD cleaner ( prob called lens cleaner). It still fixes it for me.
Jul 20, 2015 | Televison & Video
We have a spectroniq pdv-768. When we put in a disc and it try to load it it come back and says WRONG DISC. How do we get it to read the disk and play?
If your dvd player on your flat panel tv says "wrong disc" then it usually means that the format used to create the disc is not compatible with your player. Read the manual that came with your tv to figure out what file formats are acceptable for burned discs. Try another disc. Verify with a store bought disc that your player works. If it plays regular discs and not home made or burned media, then you will know that its just the file format used when the disc was created that is causing the issue.
Jul 17, 2011 | Televison & Video
My Curtis dvd player 1046 won't play dvd's, it says its loading then it says bad disc
First, try playing a regular music CD and see if that works. Next step would be to get a laser lens cleaner disc and run that in the machine. They come in both CD and DVD styles. You most likely won't get a DVD version to work since it's not reading DVDs, but you might get lucky and get a CD version to work, thus the reason for trying a music CD in the player.
If the cleaning doesn't work, or you can't play a CD either, then something has most likely died. There are really only two things that could go wrong with a DVD player, either the spindle motor (spins the disc) dies, or the laser dies. Both are somewhat common problems on low-end electronics. They can be fixed, but with low-end units, like those made by Curtis, it would cost you less to toss it out and buy a new unit.
Apr 05, 2011 | Curtis Televison & Video
Keeps saying wrong disc
first i downloaded the manual and read it through... it mentioned wrong disc but did not give any solution so i rang Teac and they told me it was a malfunction and by the time i paid for them to look at it i could buy a new dvd..... so i am going to buy a new dvd..... not really a solution but the only one available
Jul 06, 2009 | Teac DV-3500 DVD Player
Audiovox D1998 portable DVD player will no long read disc.
This of course may not be the exact same thing, but mine did the same thing. Sounding like it was loading, but in fact pressing the open button it I could see the disc not spining at all (normally you would.) With the power off of course. I took all the bottom screws out (where ever the arrow points to a screw) including to the display. There is one ribbon cable easily disconnected. I lifted the mount the DVD sits on and reseated it. I put a disc in it, turned on the power and the disc turned. Great I thought. I reconnect the cable, put the screws back in - and its working.
Apr 22, 2009 | Audiovox D1917
WILL NOT PLAY A DISC
With the power turned off, open the DVD Player, and then open the top where you load the DVD into the player. Locate the laser lens and notice that the laser is attached to a transport assembly that moves the laser diagonally outward in a slot. 1. Slide this assembly outward to the end of its track. 2. Slide the assembly back inward to the closest inward position. 3. Repeat the process of sliding the assembly outward and then back inward.4. Put in a music CD and let it play all the way through. This helps to calibrate the laser head assembly movement. When the music CD is finished playing. 5. Put in a DVD, and you should have a working unit again This is a factory solution from Mintek that was given to a customer who ask for help with the forever loading disc problems. This solution may work on other models of portable DVD players. Most portable DVD players use this type of transport mechanism. Try this solution it might work for you.
Apr 03, 2009 | Mintek MDP-1770 Portable DVD Player
Toshiba D-VR4 DVD recorder/VCR player
you can get the cleaning disc at any electronic store or even at some other stores like drug stores and even at the dollar store , but if the laser lens is probably to dirty to even see that disc if your player will not even read a music disc, have you tried a music disc? can it read it ? if so the cleaning disc will work.
if not then taking the player apart and manually cleaning the lens will be required
Dec 29, 2008 | Toshiba D-VR4 DVD Recorder/VCR
After loading every disc displayes "wrong disc'
are they bootleg dvd's? if not try getting a lense cleaner because wrong disc means it's reading your dvd's as .mov files which only play on quicktime in a computer. if it reads your cleaner as wrong disk too then get yourself a refund cuz it has a motherboard malfunction.
Dec 02, 2007 | Cyberhome CH-DVD 300 DVD Player
Screen reads NO DISC
I had the same problem but I solved buying "Laser Lens Cleaner " Philips Magnavox after 3 attempts the DVD starts to work fine again. First only 3 min, then 10 min and now the entire CD cleaner and after I left the CD cleaner for 15 min I tried to play the DVD and WORKS!!! perfect!!!
Nov 08, 2007 | Audiovox D1420 Portable DVD Player
No disc
Sorry no luck with a manual yet best I could come up with is e-mail address; Tech-support@Farenheitusa.com They should help. It does sound though as if you have to either get it serviced (try your local repair shop) or replace it - I will keep looking for a manual and post anything i find; Hope this helps :)
Mar 18, 2007 | Farenheit DVD34 Car DVD Player
Coby TF-DVD7005 Portable DVD Player Logo
142 people viewed this question
Top Coby Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Coby Televison and Video Expert? Answer questions, earn points and help others
