Question about RCA RP5420 Clock Radio
Alternating time and radio setting
This clock radio display keeps alternating between the time and radio frequency setting. I do not use the radio to wake me up...only the chime.
Can anyone tell me how to stop the alternating and only show the time?
Thanks,
  • Anonymous May 27, 2008
    I have model RP5435 that is doing the same thing. I've done the same thing. . . turn the radio on then turn off. It seems to do it more in day time than night time.
  • 3 Answers
When the display was doing this to me tonight (I just got the thing, so fat lot I know, huh? I try), I pushed the "OFF" button 2 or 3 times. The OFF button is on the top of the clock, next to all of the alarm buttons. It quit alternating for me.
Posted on Apr 03, 2008
My GE Clock radio doesn't keep time. Radio is working. Have I pressed a wrong button ??
There are basically three types of electronic clock.
Quite old-fashioned are those that use the frequency of the mains electricity it is plugged into as a means of approximately keeping time. For practical purposes this type is more accurate than most mechanical types but may lose or gain a little and need adjusting from time-to-time.
If this type becomes unreliable there is nothing the user can do about it and an engineer would be needed or perhaps the garbage or recycling would be a better place.
The second type is the now very common quartz type where the clock circuitry keeps time by being triggered by a very accurate quartz crystal oscillator.
These types are generally so accurate it is worth providing battery back-up in case of power failure as well as preserving alarm and reminder settings.
If this type becomes inaccurate it indicates a problem with the circuitry and again recycling is probably the most practical option, though accumulated damp and dust inside can affect the delicate circuitry which might be restored to accuracy after a thorough internal clean.
I once had similar trouble with my clock radio which was caused in this instance by me forgetting how to operate it correctly. Spending a half-hour playing around with it refreshed my memory so in future I will remember when I have set the alarm to return the display to the clock.
The third type of clock is the radio controlled type that is set and keeps time by receiving a radio signal from a national atomic clock. They can do strange or unusual things if the signal is not being received properly or the clock is faulty but there is usually a function for setting the time manually though in my limited experience these aren't clocks for everyone and they aren't suitable for every location.
Feb 08, 2015 | GE Audio Players & Recorders
Losses Time
what frequency does Jordon use on their power is it 50 hz are the clocks 60 Hz designed power usage.
may need a device to convert 50hz to 60hz
search google for
50 hz to 60hz frequency converter
Apr 15, 2014 | Sanyo R-6800 2-IN-1 ALARM CLOCK AND RADIO...
Directions for Resetting the Daylight Savings Time (DST) Start & End Dates on the Emerson Research Smartset Dual Alarm Clock Radio on CKS1850
Unfortunately, you can't reset the firmware of the clock for those built before Jan 2006; you can work-around the issue. You will need to change time zones for the few weeks between the current daylight savings start and end dates and the ones that were built into the clock. For details see: http://www.emersonradio.com/dst.htm ; click on the link for Group 1.
If the unit was built before Jan 2006 (the serial number will start with a value less than 6), switch the time zone to the next one further east on the second Sunday of March, then set it back to your correct time zone on the first Sunday of April. Repeat this on the last Sunday of October and the first Sunday of November. (If you are in the Eastern time zone (zone 2), set the switch to zone 1.)
If the unit was built between Jan 2006 and July 2006 (serial numbers that start 601 to 606), then you can change the start and end dates for DST. See: http://www.emersonradio.com/dst.htm then choose the Group 2 link. Press and hold the Alarm 1 button then press the Month/Date or Calendar button. After three seconds the unit will display the start date for daylight savings. Press and hold the Alarm 1 and Month/Date or Calendar buttons. When the display is flashng (within 5 seconds from the press and hold step), press the Down or Set button (depending on the SmartSet mode) three times until the display reads 3 and F2 (alternating with the date of that Sunday).
For the end date, press and hold Alarm 2 then press the Month/Date or Calendar button. Then press and hold Alarm 1 and the Month/Date or Calendar button. Again within 5 seconds, press the Up button or Set until the display shows 11 and F.
If the display stops flashing, repeat and set the new dates faster.
You'll have to repeat this is the battery is removed or replaced.
I hope this helps.
Mar 15, 2011 | Emerson SmartSet CKS1850 Clock Radio
SETTING CLOCK ON JENSEN PHASE PCD120U
Display Selector (DSP)
This unit can display either the clock time or
radio frequency/CD player functions. Ordinarily,
the radio frequency or CD player track
indication is displayed, but the unit will display
the time when the DSP button (18) is pressed.
The time will display for approximately 5
seconds then return to the radio or CD player
function display. The correct time-of-day can be
set by pressing and holding the DSP button.
Setting the Clock
To set the clock, perform the following steps:
1. Turn the vehicle ignition and radio on.
2. Press and hold the DSP button (18) until
the time display flashes.
3. Within 5 seconds, turn the MULTI/JOG
control (3) clockwise to adjust the minutes
to the desired setting.
4. Turn the MULTI/JOG control counterclockwise
to adjust the hour and the “AM”/
Jan 28, 2010 | Vehicle Parts & Accessories
Setting the time
Setting Time
1 Press TITLE repeatedly until the time is displayed.
For details, see “Displaying the Text” (page 13)
2 Press and hold TITLE for at least 2 seconds while
The time indication will blink.
3 Turn the Rotary encoder to adjust the hours while
the time indication is blinking.
4 When the hour has been adjusted, press MODE.
5 Turn the Rotary encoder to adjust the minutes
while the time indication is blinking.
The time is automatically set 5 seconds after the minute
adjustment. The time can also be manually set by pressing TITLE.
• To synchronize the clock to another clock/watch or radio time
announcement, press and hold MODE for at least 2 seconds after
setting the “hour.” Minutes will reset to “00”. If the display shows
over “30” minutes when you do this, the time will advance one hour.
Listening to Radio
1 Press SOURCE/POWER until a radio frequency
appears on the display.
2 Press BAND repeatedly until the desired radio band
is displayed.
F1 (FM1) F2 (FM2) AM F1 (FM1)
3 Press TUNE to select the tuning mode.
DX SEEK (Distance mode) SEEK (Local mode)
OFF (Manual mode) DX SEEK
• The initial mode is Distance mode.
Distance mode:
Both strong and weak stations will be automatically tuned in
(Automatic Seek Tuning).
Local mode:
Only strong stations will be automatically tuned in (Automatic
Seek Tuning).
Manual mode:
The frequency is manually tuned in steps (Manual tuning).
4 Press or to tune in the desired station.
Holding down or will change the frequency
continuously.
Manual Storing of Station Presets
1 Select the radio band and tune in a desired radio
station you wish to store in the preset memory.
2 Press and hold, for at least 2 seconds, any one of the
preset buttons (1 through 6) into which you wish
to store the station.
The selected station is stored.
The display shows the band, preset number and station
frequency memorized.
•You will need to start from set up or you will not be able to set the mins
Dec 31, 2008 | Alpine CDE-9852 CD Player
Teac R2 clock radio--Cannot set the clock.
Press and hold the CLOCK ADJUST button for more than 3 seconds.
"SET" and "CLK" appear alternately in the display.
Turn the MULTI JOG knob to adjust time.
Press the CLOCK ADJUST button again to finish.
Dec 29, 2008 | Teac R2 Clock Radio
Wrong time on Emerson Smart Set clock
This is a problem with the clocks tuning crystal. Digital clocks have a crystal that is tuned to run at a certain frequency to keep the clock working correctly. These clocks have a problem with that crystal keeping the frequency locked at the correct working frequency. This problem will sometimes cause the clocks to run fast due to a running frequency higher than the regulated frequency and sometime slow due to a running frequency running lower than the regulated frequency. The only way to fix this problem is to either adjust the crystals frequency to the correct frequency and lock it. Or change the crystal. Both these types of service require tools and test equipment to fix the problem. This is usually best handled by a service center. The Emerson customer support telephone number is 1-800-898-9020. Give them the make and model number of your clock radio and ask them for assistance. I hope this information helps you with your problem.
Nov 18, 2008 | Emerson Smartset Clock Radio
Alarm clock won't change time with daylight savings
unless it is an automatic , atomic clock none I have ever owned do the change automatically
Feb 27, 2017 | RCA Audio Players & Recorders
Clock runaway
You are right on, the clock is using the 50 hertz to keep time expecting it too be 60 hertz.
Dec 27, 2007 | GE RP4842 Clock Radio
Daylight savings time adjustment
Go to:
http://www.emersonelectronics.ca/emerson/en/product/details/VLJT600
or
http://www.emersonelectronics.ca/emerson/en/category/list/694
The solution appears to be common for all recent Emerson SmartSet(tm) radios (BTW it's not the clock fault, it's the law).
Remarkably Emerson foresaw this, so here we go.
Short version (may require three hands :-) )
DST start:
Press and hold MONTH/DATE and ALARM 1 buttons for at least 3 seconds until the display changes to something like "4 F" (Fourth month, First week) alternating with something like "4. 1" (April 1st, for 2007) or "4. 6" (April 6th, for 2008). While holding down the MONTH/DATE and ALARM 1 buttons, now press the DOWN or "-" Set button (3 times) until "3F2" shows (Third month, second week) alternating with something like "3.11) (March 11th, for 2007) or "3. 9" (March 9th, for 2008). Let go of all buttons and we are now half done.
DST end:
Press and hold MONTH/DATE and ALARM 2 buttons for at least 3 seconds until the display changes to something like "10 L" (Tenth month, Last week) alternating with something like "10.28" (October 28th, for 2007) or "10.26" (October 26th, for 2008). While holding down the MONTH/DATE and ALARM 2 buttons, now press the UP or "+" Set button (1 time) until "11 F" shows (Eleventh month, first week) alternating with something like "11. 4" (November 4th, for 2007) or "11. 2" (November 2nd, for 2008). Let go of all buttons and we are now done.
This should remain until either the lithium battery fails or Congress undoes its work.
BTW the Emerson addendum has a history error. The time change in the first Sunday in April and the last Sunday in October did not start in 1966, but in 1987. Before that starting in 1966 the standard was set at the last Sunday in April and the last Sunday in October. Except for 1974, when it was January 6th, 1974 (DST start) and October 27th, 1974 (DST end) and in 1975 when it was February 23rd, 1975 (DST start) and October 26th, 1975 (DST end). Before 1966, state and local governments had many different rules. Source: http://webexhibits.org/daylightsaving/e.html
Oct 28, 2007 | Emerson CKS3029 Clock Radio
RCA RP5420 Clock Radio Logo
147 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
